查看: 2270|回复: 4
[Virtual.Lab] 出现fail to sysniose process 错误 提示日志内容如下 求解
发表于 2017-12-28 15:42 | 显示全部楼层 |阅读模式
XPR VERSION 11-SL2
Requested task is SYSNOISE sequential computation.
Working directory on server is C:\Users\zhy\AppData\Local\Temp
Checking that the SYSNOISE launch script (D:\Program Files\LMS\LMS Virtual.Lab 11-SL2\VirtualLab\Sysnoise\5.6\bin\sysnoise_nogui.bat) exists on server...
OK
SYSNOISE log file on server is C:\Users\zhy\AppData\Local\Temp\zhy-8069-sysnoise.log.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxx  JOB EXECUTION START
                System for Computational Vibro-Acoustics
SYSNOISE Rev 5.6  Windows_x86_64  MAR2003 DATE: 28-DEC-2017 15:29:46
PATCH LEVEL  O  (Build Date: 18-FEB-2013)
READING THE SET-UP FILE: D:\Program Files\LMS\LMS Virtual.Lab 11-SL2\VirtualLab\Sysnoise\5.6\bin\\..\res\SYSNOISE.STP
THE SYSNOISE PROFILE FILE NAME HAS NOT BEEN DEFINED.
STANDARD GRAPHIC DEVICE SET TO DEFAULT
PLOTTING GRAPHIC DEVICE SET TO SCREENDUMP
MEMORY IN USE   =         800000
AVAILABLE MEMORY=     1010000000
FREE MEMORY     =     1009200000
CREATING DEFAULT SYSNOISE MODEL FILE default.sdb
SYSNOISE ANALYSIS OPTION :
      BEM INDIRECT VARIATIONAL UNBAFFLED FREQUENCY FLUID
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP USRDIR 'C:\Users\zhy\AppData\Local\Temp\' RETURN
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP TMPDIR 'C:\Users\zhy\AppData\Local\Temp\' RETURN
SYSNOISE>  SCL> Open Model 1 File zhy-8069-Structure.sdb Original Return
OPENING SYSNOISE MODEL FILE zhy-8069-Structure.sdb
LOADING MODEL Exported VLModel
SYSNOISE>  SCL> Environment Section SETUP GEO_TOLERANCE '1E-006' Return
SYSNOISE>  SCL> Return Environment Section SETUP BELL 'on' Return
SYSNOISE>  SCL> Environment Section SETUP STABLEFEM TRUE Return
SYSNOISE>  SCL> Modes
EIGENMODES>  SCL> Vector 30 Tolerance 1.000000e-006 Iteration 100
EIGENMODES>  SCL> BLanczos
EIGENMODES>  SCL> Return
EIGEN MODES COMPUTATION
COMPUTING THE    30 FIRST EIGENVALUES BY BLANCZOS METHOD
Shift value.......................  0.0000     Hz
Maximum number of iterations......     100
Number of iter. vect. (subspace)..      38
Tolerance for eigenvalues......... 1.00000E-06
STURM         control (subspace method)
CPU Stats --- Delta:  0:00:01 (      1.27)  Total:  0:00:01 (      1.27)
  Running Bacon and Dynam ...
CPU Stats --- Delta:  0:00:05 (      4.72)  Total:  0:00:06 (      5.99)
ERROR : GRAPH FILE zhy-8069-Structure_samcef.u60  DOES NOT EXIST !
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
  !!! Please check the *_samcef.log or *_samcef_dy.res file for errors !!!
  ***ERROR*** CANNOT PERFORM THIS ANALYSIS PROCEDURE
SYSNOISE>  SCL> Close Return
SAVING MODEL Exported VLModel
FILE NAME    C:\Users\zhy\AppData\Local\Temp\zhy-8069-Structure.sdb
SYSNOISE>  SCL> New Model 1 File zhy-8069-SignalFile.sdb Return
SYSNOISE>  SCL> Save Return
SAVING MODEL zhy-8069-SignalFile
FILE NAME    C:\Users\zhy\AppData\Local\Temp\_zhy-8069-SignalFile.sdb
SYSNOISE>  SCL> Exit
SYSNOISE Rev 5.6  Windows_x86_64  MAR2003 DATE: 28-DEC-2017 15:29:52
CPU Stats --- Delta:  0:00:00 (      0.45)  Total:  0:00:06 (      6.44)
 楼主| 发表于 2017-12-28 15:49 | 显示全部楼层
发表于 2017-12-28 16:54 | 显示全部楼层
我也是这个问题,无解。。
发表于 2017-12-28 18:41 | 显示全部楼层
ERROR : GRAPH FILE zhy-8069-Structure_samcef.u60  DOES NOT EXIST !是杀毒软件删除的吗,可以关杀毒和防火墙试试,还是可以用nastran的求解器进行模态计算
发表于 2018-1-1 15:20 | 显示全部楼层
1,重新检查下材料、单元属性设置。
2,注意防火墙不要杀掉VL的进程。
3,看截图你是11的版本,建议升级到13.6.这个是目前一个比较好用的版本。
GMT+8, 2025-1-7 22:59 , Processed in 0.065709 second(s), 21 queries , Gzip On.
