查看: 4126|回复: 0
abaqus cae提交计算出错
发表于 2017-12-20 18:31 | 显示全部楼层 |阅读模式
The job input file "Job-1.inp" has been submitted for analysis.
Error in job Job-1: Contact field output is requested for a node-based surface (*SURFACE, TYPE=NODE) spanning multiple instances in an Abaqus/Explicit analysis. This is currently not supported. Please remove the contact field output for the contact pair in question, or split the node-based surface into separate surfaces each spanning just one instance.
Error in job Job-1: ERROR DURING PART, INSTANCE AND ASSEMBLY PROCESSING
求问题解决办法
GMT+8, 2024-12-27 22:11 , Processed in 0.080572 second(s), 18 queries , Gzip On.
