查看: 1839|回复: 0
[其他相关] 振动分析师最讨厌听到的16句话
发表于 2017-12-14 15:58 | 显示全部楼层 |阅读模式
  每一位振动分析工程师在工作期间都有一些不愿意听到的话语,这些话语通常表达了对其负责的设备维修工作的不满、抱怨,亦或是对工程师分析能力的质疑,今天我们盘点一下振动分析工程师最讨厌的16句话。
  1、It has always run like that!
  2、It really was making a noise before you arrived.
  3、We don’t have time to change the bearings. Just balance the machine so we can run it.
  4、How long will it last?
  5、Those bearings are brand new so I know they’re good.
  6、“Yeah, we just use a torch to heat bearings to install them.” Use an EDDYTHERMinduction heater with automatic demagnetizing to properly install your bearings.
  7、“We don’t have a bearing heater so we use a pipe and hammer to drive the bearing on.” Use an EDDYTHERM induction heater with automatic demagnetizing to properly install your bearings.
  8、All we collect are overall vibration values, they tell us everything we need to know.
  9、“It doesn’t take us long to change belts cause we just roll them on.” Very bad practice! Use a laser tool like the SHEAVEMASTER and loosen the feet of the motor before installing the new belts.
  10、“We don’t use no fancy alignment tool. All we need is a straight edge.” A recipe for disaster! Get a good laser shaft alignment system like the SHAFTALIGN —the money this will save in lost production and unnecessary repairs will more than pay for itself, not to mention the time saved for the analyst who can now dedicate himself to finding other more complex vibration problems.
  11、My screw driver does not confirm your analysis!
  12、You found the problem. Now go fix it.
  13、“I didn’t realize you needed training.” Sign-up for a LUDECA vibration analysis trainingclass.
  14、I didn’t realize that this CM technology would create so much work.
  15、We need you to stop using that CM technology and turn wrenches this week.
  16、We didn’t realize you had identified and created a work order to fix that problem before it failed.
  原文链接:http://ludeca.com/blog/maintenan ... alyst-hates-to-hear
  来源:Ludeca Blog
GMT+8, 2024-11-28 18:44 , Processed in 0.049578 second(s), 17 queries , Gzip On.
