查看: 2085|回复: 4
一电机振动频谱,帮忙解读下,为什么在FFT 400处有个高峰?
发表于 2017-11-14 06:06 | 显示全部楼层 |阅读模式
Bearing frequencies : NU 2217 ECM
窗体底端
Input parameters
ni
  Rotational speed of the inner ring
1500 r/min
ne
  Rotational speed of the outer ring (only used    to calculate the bearing  frequencies)
0 r/min
Result
fi
  Rotational frequency of the inner ring
25.0 Hz
fe
  Rotational frequency of the outer ring
0.0 Hz
fc 滚动元件和保持架组件的旋转频率
Rotational frequency of the    rolling element and cage assembly
10.601265822784809 Hz
fr 滚动元件绕轴旋转的频率
  Rotational frequency of a rolling element about its own axis
80.39293248945147 Hz
fip 过滚动内圈上的一个点的频率
  Over-rolling frequency of one point on the inner ring
244.77848101265823 Hz
fep 过滚动外圈上的一个点的频率
  Over-rolling frequency of one point on the outer ring
180.22151898734177 Hz
frp 过滚动的滚动元件上的一个点的频率
  Over-rolling frequency of one point on a rolling element
160.78586497890294 Hz
B Bearingfrequencies : 6314frInput parameters
ni
1500 r/min
ne
0 r/min
Result
fi
25.0 Hz
fe
0.0 Hz
fc
9.613636363636363  Hz
fr
51.2474946313529  Hz
fip
123.0909090909091  Hz
fep
76.9090909090909  Hz
frp
102.4949892627058  Hz
 楼主| 发表于 2017-11-14 06:07 | 显示全部楼层
为什么FFT最大量程在500?
发表于 2017-11-14 12:13 | 显示全部楼层
横轴是时间????
发表于 2017-11-23 11:17 | 显示全部楼层
应该与电机的结构有关。主要对应于电极数及其倍数
发表于 2017-11-28 04:16 | 显示全部楼层
这个图是在是太模糊了
GMT+8, 2024-12-28 13:59 , Processed in 0.101941 second(s), 22 queries , Gzip On.
