查看: 1973|回复: 0
[阅读写作] 英文学术论文写作中常用的主动动词
发表于 2017-10-26 09:58 | 显示全部楼层 |阅读模式
  在写作的时候,我们经常用类似'show' 'deal with'这种万能词,但是在一篇文章中,这样的词使用的越多,就越没有意义。如果你能选择一个意义更明确的词表示,也就是主动动词,就不要用这种万能动词。比如 将 'Chen dealt with' 和 'Figure 1 shows '表达成 'Chen hypothesized' 和 'Figure 1 represents' 意义变得更加明确。
  1. 当你准备文献综述的时候,需要用简要,明确的术语来描述其他人的研究时
  Phillip Chang proposes a mechanism explaining increased silica solubility in the presence of two small organic acids.
  2. 当你解释你自己的实验研究,需要解释观察到的趋势时
  The results of this study challenge findings from studies about analytic concentration varying with sample location.
  3. 当你进行客观陈述,需要预测信息的时候
  This study characterizes wetlands by their water chemistry and postulates that water chemistry varies with water source and wetland type.
  4. 当你涉及到某幅图,表或公式,需要定义该图,表或公式的目的
  Figure 4 depicts grain growth that occurred after the ceramic was sintered for three hours.
  下面的单词列表在写论文的时候,随时查看
  描述研究或者分析思维的主动动词
  yield   illustrate   illuminate   reveal   employ   mean   suggest   clarity   indicate   represent   prove   insist   propose   imply   assert   postulate   consider   infer   state extrapolate   estimate   define   classify   invoke   analyze   compare   hypothesize   synthesize   summarize   disagree   generalize   narrate   evaluate   simplify   measure note   predict   introduce   report   construe   challenge   delineate   depict   interpret   provide    acknowledge   distinguish   inform   specify   restrict   determine   detail sum up   designate   point out   set forth   deduce   derive   characterize   guide   maintain   believe   speculate   present   organize   investigate   assess   determine   calculate   support   devise   construct   evaluate   attribute   obtain   assume   argue   reiterate   discover   decide
  描述现象的主动动词
  discharge   overlie   emanate   radiate   scatter   exchange   separate   surround   combine   eliminate   emit   transmit   carry   bombard   exert   exude   interact   behave exchange   absorb   converge   extend   constrain   force   elongate   contract   trend   plunge   occur   fracture   continue   mix   slow   quicken   produce   bond   interlock  fuse   deteriorate   migrate   encompass   access   traverse   join   dominate   deposit   underline   overlap   originate   isolate   invade   permeate   evolve   divide   sinter reclaim   restore   abandon   contain   accrue   precede   influence   saturate   circulate   forecast   orient   distribute    allow   lag   terminate   activate   cease   record   form  transect   condense   enrich   invert   convert   alter   link   superimpose   rotate   rupture   streamline   appear   require   ascend   descend   collapse   superpose   crystallize  bisect   cede   coalesce   disperse   disseminate   disintegrate   propel   repel   accelerate   transfer   penetrate   halt   curb
  来源:简书《学术论文写作3——写作语言》。
GMT+8, 2024-12-27 22:33 , Processed in 0.097581 second(s), 18 queries , Gzip On.
