查看: 2460|回复: 0
[Patran专区] flightloads问题想要请教一下
发表于 2017-8-16 16:23 | 显示全部楼层 |阅读模式
打开flightloads出现错误提示
Error initializing Flightloads. The Nastran command [ c:\MSC.Software\MD_Nastran\20121\bin\mdnast20121.exe ] does not exist. This is normally defined with the [ Alocalcommand2012 ] environment variable defined in the [ P3_TRANS.INI ] file in [ p3_home ] and is used as the Nastran Server invocation.
请问是什么原因呢?怎么解决?
GMT+8, 2025-1-30 01:44 , Processed in 0.072279 second(s), 18 queries , Gzip On.
