查看: 3490|回复: 8
[求助]帮忙啊!要疯了!Ansys输流管耦合
发表于 2006-5-30 20:59 | 显示全部楼层 |阅读模式
<P>在论坛上看到不断有人得到帮助,很是羡慕~我的问题一直没有得到解决,不知道能不能行行好,给我解答一下,小人先在这里叩头了!<br>Ansys输流管耦合边界条件的加载..<br>/BATCH,LIST <br>/PREP7 <br>/TITLE,vibration of pipe with fluid in </P>
<P>!单元 </P>
<P>et,1,42,,,3 <br>et,2,45 <br>et,3,29 <br>et,4,30,,0 ! structure present <br>et,5,30,,1 ! structure absent <br>r,1,0.0036 </P>
<P>!材料 </P>
<P>mp,ex,1,69e9 <br>mp,dens,1,2700 <br>MP,DENS,2,1030 <br>MP,SONC,2,1460 </P>
<P>!建模、分网 </P>
<P>cyl4,,,0.0228,,0.0248 <br>lesize,all,,,8 <br>mshkey,2 <br>mshape,0,2d <br>aatt,1,,1 <br>amesh,all </P>
<P>cyl4,,,0.0228 <br>asel,s,,,2 <br>lsla,s <br>lesize,all,,,8 <br>mshkey,0 <br>mshape,0,2d <br>aatt,2,,3 <br>amesh,all <br>allsel </P>
<P>!由面单元生成体单元 </P>
<P>asel,s,,,1 <br>extopt,attr,1,1,1 <br>extopt,esize,200 <br>extopt,aclear,1 <br>type,2 <br>vext,all,,,,,0.849 <br>allsel <br>asel,s,,,2 <br>extopt,attr,1,1,1 <br>extopt,esize,200 <br>extopt,aclear,1 <br>type,4 <br>vext,all,,,,,0.849 <br>allsel <br>nummerg,all <br>!单元属性修改 </P>
<P>esel,s,type,,4 <br>nsle,s,all <br>csys,1 <br>nsel,s,loc,x,0.0228 <br>esln,s,0,all <br>esel,inve <br>nsle,s <br>emodif,all,type,5 <br>allsel </P>
<P>!流固耦合单元标识 <br>nummrg,node <br>csys,1 <br>nsel,s,loc,x,0.0228 <br>esln,s,type,,4<br>sf,all,fsi,1 <br>allsel <br>finish <br>就是这段程序,在计算机上进行模态的分析,为什么运行事,计算机出现<br>*** WARNING ***                         CP =       2.578   TIME= 20:50:59<br>ANSYS..  Is not a recognized BEGIN command, abbreviation, or macro.     <br>  This command will be ignored.                                          </P>
<P>*** WARNING ***                         CP =       2.672   TIME= 20:50:59<br>The /BATCH command must be the first line of input.                     <br>  The /BATCH command is ignored.                                         </P>
<P>*** WARNING ***                         CP =       7.938   TIME= 20:51:41<br>Real constant 1 referenced by at least element types 5 and 4.           </P>
<P>*** WARNING ***                         CP =       8.172   TIME= 20:51:42<br>Element 1 (SOLID45) uses material 1 for which Poisson's ratio is        <br>undefined.  A default value of 0.3 will be used.  Input MP,PRXY, 1,0.3  <br>to eliminate this warning.                                              </P>
<P>*** WARNING ***                         CP =       8.188   TIME= 20:51:42<br>No constraints have been defined using the D command.                   </P>
<P>*** WARNING ***                         CP =      18.641   TIME= 20:51:55<br>Coefficient ratio exceeds 1.0e8 - Check results.                        </P>
<P>*** WARNING ***                         CP =      90.781   TIME= 20:53:16<br>There are 1 positive pivots with ratios less than 1.E-13 indicating a   <br>possible poorly conditioned stiffness matrix.                           </P>
<P>*** WARNING ***   SUPPRESSED MESSAGE    CP =     129.828   TIME= 20:54:06<br>Lanczos recursions terminated after 5 vectors.  Apply a new shift       <br>(FREQB) using MODOPT command and re-run for additional eigenvalues of   <br>the problem.         <br><br>计算到第四步后,计算机提示<br>Error messages  discontinued after 5 messages was displayed<br>到底,究竟是怎么回事呢?</P>
[此贴子已经被dushudushu于2006-6-1 18:10:53编辑过]
发表于 2006-5-30 21:04 | 显示全部楼层
到底怎么回事,你翻译一下英文就知道了<BR>建议如果不是太了解命令流的话,还是按gui操作比较好一些!<BR>毕竟gui对于大部分人来说都很清楚的知道自己的每一部是想做什么,然后清楚的知道能不能操作成功。<BR>当然,命令流是很便捷的,但是如果不知道命令流对应的gui的什么操作,往往都是事倍功半。。。
发表于 2006-5-31 08:11 | 显示全部楼层
二楼的大虾,“翻译一下英文就知道了”是什么意思?是指ANSYS里面的例子吗?
发表于 2006-5-31 08:20 | 显示全部楼层
用ansys处理流固耦合时,如果考虑流体的可压缩性,如何同时处理流体与固体之间的位移耦合与内力耦合?如果只是将其作为填充物,在ansys里将流体处理为另外一种材料类型,又如何体现流固耦合?愿闻楼主高见!
发表于 2006-5-31 08:28 | 显示全部楼层
目前小可也在做管道流固耦合方面的东西,但考虑到以上原因,一直没做深入分析!现在是自己摸索着编程,并寻求解析解,困难也是不少。传递矩阵法是处理流固耦合问题的有效方法,张立翔在这方面做出了很大的成绩。如果有充足的时间,建议楼主不妨一试。
发表于 2006-5-31 10:09 | 显示全部楼层
回复:(wj9984)[求助]帮忙啊!要疯了!
搜了一下,有兴趣的可以看看打开附件<BR>
 楼主| 发表于 2006-5-31 14:22 | 显示全部楼层
先谢谢大家!
我现在研究的是输液管道的流固耦合问题.即使按照正常的操作步骤进行建模和网格划分,但是模态也不能分析啊.上面的命令流个人认为就是先在二维分别建立管道和流体的单元,然后在拉伸成三维的实体,再改变原来划分的二维单元属性.之所以定义五个单元就是考虑到二维和三维条件下的单元属性.至于hxianping<STRONG><FONT face=Verdana color=#61b713>所说的传递矩阵法,只是求解流固耦合问题的方法之一,行波法也可以解流固耦合的问题,不过都是在建立数学模型后求解数学模型时使用的方法,现在在ansys中,是对模型进行分析,我现在考虑的是模态,不知道是不是命令流里是否有问题!</FONT></STRONG>
发表于 2006-5-31 20:43 | 显示全部楼层
<DIV class=quote><B>以下是引用<I>hxianping</I>在2006-5-31 8:11:30的发言:</B><BR>二楼的大虾,“翻译一下英文就知道了”是什么意思?是指ANSYS里面的例子吗?</DIV>
<P>错误在warning中已经说得很清楚了 </P>
发表于 2011-4-20 19:58 | 显示全部楼层
您好,在百度上看到06年您发的贴,想请教输流管流固耦合Ansys模态分析的知识,如果有,麻烦您提供给我好吗,谢谢!
GMT+8, 2025-1-26 03:23 , Processed in 0.109399 second(s), 17 queries , Gzip On.
