查看: 1750|回复: 2
[其他相关] ls-dyna中一些材料参数K文件
发表于 2017-6-8 10:40 | 显示全部楼层 |阅读模式
1.紫铜(johnson_cook)    EX=1.19        cm-g-us
*MAT_JOHNSON_COOK0 f, z, ~! J# `# C. _( b
         1   8.96000      0.46
0.900E-03 2.920E-03     0.310 0.250E-01      1.09 0.1356E+04       210 0.100E-05
0.383E-05 -9.00E+00      3.00       0.00      3.00      0.00      0.00     0.00
      0.00
*EOS_GRUNEISEN
         1    0.394     1.489      0.00      0.00      2.02      0.47      0.00    4 p1 f8 i& n0 P0 @
      1.00 ; ]. F! ~. R3 a( G8 j! a
2.高能**(LS-DYNA中无此材料模型,任取以模型代替,修改k文件)1 M8 ~! K- z0 S
*MAT_HIGH_EXPLOSIVE_BURN
  1 1.7870001 0.8390000 0.3400000 0.0000000 0.0000000 0.0000000 0.0000000
*EOS_JWL
  1 5.8140002 6.8010E-2 4.1000000 1.0000000 0.3500000 0.0900000 1.0000000
) s2 V) f; q/ O. }; w' q
---------------------------------------------------------------------------------------( f  T  w5 {$ c4 c$ W/ z9 a" ?
或者:4 U2 [: j, Z9 O
*MAT_HIGH_EXPLOSIVE_BURN4 l/ M; e, ?" m6 R1 W  w7 R
         1 1.6400000 0.6930000 0.2700000 0.0000000 0.0000000 0.0000000 0.0000000
*EOS_JWL
         1 3.7400000 3.2300e-2 4.1500001 0.9500000 0.3000000 0.0700000 1.0000000; t* [+ b. \! V0 Z7 A, i
: K4 ?% H6 ?3 @8 U  t6 w4 p
3.高导无氧铜
(Steinberg):/ X5 e8 u. g! E; v2 H# R+ [6 i
*MAT_STEINBERG4 J  X# [. l/ m! c, @: x7 H
  2       8.93     0.477     0.120E-02  36.0     0.450      0.00     0.640E-028 q) _5 a% t% E. g7 n# j# E5 b! j
  2.83      2.83     0.377E-03 0.100E-02  63.5     0.179E+04  2.02      1.50    ) p( x$ K0 [3 O. r9 ]$ A5 X' G' g
-9.00      3.00     0.00      0.00      0.00      0.00      0.00      0.00
  0.00      0.00     0.00      0.00      0.00      0.00      0.00      0.00    * Z- v* W/ e# x' P. R) H5 J
*EOS_GRUNEISEN
  2     0.394      1.49      0.00      0.00      2.02     0.470      0.00
  1.00   $ V% f* y# h; {1 |8 a4 {/ O
(plastic_kinematic):
*MAT_PLASTIC_KINEMATIC& x( F% m" V) X  }" b$ x  p" |
         1  8.93      1.17      0.350000 0.400E-02 0.100E-02  1.00
  0.00      0.00      0.00
========================================================================================7 P9 `) B8 E; I1 I6 g5 a, l
4.钢(johnson_cook):cm-g-us     EX=2.0( V. A$ [; X; |5 H
*MAT_JOHNSON_COOK
         1   7.83000      0.77
7.920E-03 5.100E-03     0.260 0.140E-01      1.03 0.1793E+04       294 0.100E-05
0.477E-05 -9.00E+00      3.00       0.0      5.00      0.00      0.00      0.00
      0.00
*EOS_GRUNEISEN
      1.00 ' U) j5 l* u  f- U, y& R
---------------------------------------------------------------------------------------8 B2 R! v2 h& `- j; c" M/ J) R, m
         1  7.83      2.07      0.300000 0.400E-02     5.00E-02  1.00    ; ~5 x3  C. O0 U( X# j$ O$ y+ [
  0.00      0.00      0.00 , m: @8 W& J" ]. ^, H) T+ q& V9 F
5.混凝土(solid_concrete)6 t& P* f. F) B7 W9 o- y" ~
*MAT_SOIL_CONCRETE
         2     2.500 1.250E-01 1.667E-01         1         2         3         4) {  U2 u" n0 P( E0 y9 F
-2.00E-05       0.0       0.3         1: u0 h( H8 P6 L  c2 y, `
*DEFINE_CURVE
         1         0 0.0000000 0.0000000 0.0000000 0.00000008 h& O8 H1 @) G  z
                 0.0                 0.0
              0.0953           0.230e-01$ L& x: j  K# P4 |6 W1 U' l0 Z
              0.1823           0.650e-018 g8 u' ~/ X0 I! y3 ]" O9 g. H
              0.2624           1.300e-01
              0.3365           1.750e-01- |6  f& h8 u( m' _, j5 l; ~
              0.4055           2.250e-01
              0.4700           3.500e-015 {) ~- l4 Y+ Z6 l1 ]* a1 l
*DEFINE_CURVE3 E' f0 @3 ^, X) M6 ^; C; j6 s
         2         0 0.0000000 0.0000000 0.0000000 0.0000000
                 0.0                 0.0
           0.400e-02           0.240e-023 ?6 P# K4 [5 n  X9 C
           0.800e-02           0.550e-02% K& r2 ]: z. T4 x! q
           1.200e-02           0.950e-024 c6 [: g0  L" N1 T
           1.400e-02           1.260e-028 ?7 \3 o: a) r9 \1 ?: I
           1.800e-02           1.550e-02
           1.000e-01           1.550e-020 m; g: E# g- P
*DEFINE_CURVE  b* H# n5 d- _7 E6 P1 i
         3         0 0.0000000 0.0000000 0.0000000 0.0000000. {& i+ b+ ~+ {4 a% A
                0.00                0.00
           1.500e-04                0.00
           1.000e-03                0.04% s$ x" l1 w- S& ]# F) T
           1.000e-02                0.49" X7 {" ~$ E7 `$ J/ T
           1.000e-01                4.90
*DEFINE_CURVE
         4         0 0.0000000 0.0000000 0.0000000 0.0000000
                0.00                0.01
           1.500e-04                0.014 a! }+ z7 k# S. D7 t
           1.000e-03                0.050 t$ V3 I* q+ q
           1.000e-02                0.50
           1.000e-01                5.00
================================================================; C; Q& h" H' n; [5 i2 g" V
6.土壤(泡沫材料模型)
*MAT_SOIL_AND_FOAM( P4 n. d, X" ^: l
         2      1.80 1.601E-04 1.328E+02 3.300E-03 1.310E-07    0.1232       0.09 ~6 e0 y- M: w
       0.0       0.0; [3 k1 s$ ^. l
       0.0     0.050     0.090      0.11      0.15      0.19      0.21      0.22
      0.25      0.30- g( T1 p; j5 e6 n  F
       0.0 3.420E-02 4.530E-02 6.760E-02 1.270E-01 2.080E-01 2.710E-01 3.920E-01
5.660E-01 1.230E+00
1 7.82  2.1  0.284 0.0100 0.04 1.0 1 k: n  d$ N- P- H; R
   0.000E+00 0.000E+00  0.000E+00
1 7.80  2.1  0.300  0.023  0. 0240. 1.005 G, `2 J0  M8 Q+ E( [8 L& I/ @
   0 0 0. J9 J* L: |: O
PLASTIC_KINEMATIC
1 7.80 2.07 0.300000 0. 235  0.0700 1.00
   0.00 0.00 0.00 4 P9 k) R$ X- S% T" g- O- p3 l
B4C陶瓷
*MAT_JOHNSON_HOLMQUIST_CERAMICS, A/ _8 i9 F- R: [% t: [$ _( \
2  2510e-6   197e+3      0.927       0.7      0.005      0.85     0.67
1.0    260      0.2         19e+3    8.71e+3       1.0
0.001    0.5      233e+3     -593e+3     28e+5      0.1, D& z' ^: u  H, v# J* d% F# Q: g: Y
*MAT_GEOLOGIC_CAP_MODEL
1,2700,1.4E10,1.1E10,2.7E7,0.11,8.0E6,1.4E-7
4.43,4.6E-10,0.42,1.1E8( ^4 ], M3 ]' B0 Q1 \% {/ s
( e, \. B( G- U& u  T0 m8 ?
3 m  p( d. N$ C9 _$ j/ d
$40号砼,单位:长度mm,时间msec,质量g,力N,压强Mpa
*MAT_SCHWER_MURRAY_CAP_MODEL
1,2.3E-3,1.048E4,1.168E4,0,0,1 4 o6 t. p) [. Y. r9 N. S
5,100,1,0,0.999,0.3,0.94  4 U  Y3 O5 F0 d# g" n' {
5.0E-2,2.5E-4,3.5E-7,23,0,1,300,13.8
1,0,0,0
0.747,3.3E-4,0.17,5E-2,0.66,4E-4,0.16,5E-2
$Define Steel 4340       4340号钢
*MAT_JOHNSON_COOK 7 ]' {! y* @8 ~6 S! U0 {+ Q
1, 7.8400E+00, 0.759E-00, 2.000E+00, 0.320E+00, 0.000E+00
0.793E-02, 0.510E-02, 2.60E-01, 1.400E-02, 1.030E+00, 1.793E+03, 2.930E+02, 1.000E-05     : `; S8 g1 S& E6 R
4.400E-06, 2.000E-02, 2.000E+00, 0.000E+00, 0.80E+00, 2.100E+00, -0.05E+00, 2.000E-03
0.610E+00     8 m0 {' t* Q6 R( ]0 h0 X" w
*EOS_GRUNEISEN
1, 4.578E-01, 1.330E+00, 0.000E+00, 0.000E+00, 1.670E+00, 0.430E+00, 0.000E+00     7 P7 G; Y2 K* }5 K) a6 V
1.000E+00
$   SI unit :cm-g-microsecond / `$ i# O3  l) T
$   unit conversion factor : A! N- ?3 d- k
$   1 psi=6895 pa, 1 dyn=1e-5 n,1 bar=1e5 pa,1 g/cm**3=0.0361 lb/in**3,1  lb=0.454kg
转载:CAE技术联盟微信官方平台
发表于 2017-6-19 14:29 | 显示全部楼层
楼主这是什么啊????看不懂
GMT+8, 2024-12-28 15:41 , Processed in 0.099901 second(s), 20 queries , Gzip On.
