查看: 2610|回复: 6
[结构振动] [讨论]有做过夹层板的动态特性方面的吗?
发表于 2006-5-30 12:41 | 显示全部楼层 |阅读模式
我正在做夹层板动态特性的理论推导工作,模型是四边固支的矩形夹层板,有做过着方面研究的高手吗?关于这方面的书好象不多,能不能给推荐几本啊?谢谢先!
固支条件下的挠度函数和振型函数选择什么样的形式比较好啊?请求高手指教!
[此贴子已经被作者于2006-5-30 12:46:18编辑过]
发表于 2006-5-30 13:59 | 显示全部楼层
   这方面的文献在中文和英文检索里有很多的... ...
   夹层板结构分析有很多模型,考虑的都不一样,找篇综述性的文章研究研究。
[此贴子已经被作者于2006-5-31 6:38:56编辑过]
发表于 2006-5-30 23:38 | 显示全部楼层
好象主要考虑夹层的剪力,我也想知道
发表于 2006-5-31 07:14 | 显示全部楼层
Dynamic stiffness formulation and free vibration analysis of a three-layered sandwich beam
International Journal of Solids and Structures Volume: 42, Issue: 8, April, 2005, pp. 2181-2197
Banerjee, J.R.; Sobey, A.J.
Dynamic buckling of flat and curved sandwich panels with transversely compressible core
Composite Structures Volume: 74, Issue: 1, July, 2006, pp. 10-24
Hohe, JÃÃrg; Librescu, Liviu; Yong Oh, Sang
Axisymmetric dynamic instability of rotating polar orthotropic sandwich annular plates with a constrained damping layer
Composite Structures Volume: 73, Issue: 3, June, 2006, pp. 290-302
Chen, Yu-Ren; Chen, Lien-Wen; Wang, Ching-Cheng
Dynamic response of anisotropic sandwich flat panels to underwater and in-air explosions
International Journal of Solids and Structures Volume: 43, Issue: 13, June, 2006, pp. 3794-3816
Librescu, Liviu; Oh, Sang-Yong; Hohe, Joerg
发表于 2006-5-31 07:16 | 显示全部楼层
Dynamics of geometrically exact sandwich structures
International Journal of Mechanical Sciences Volume: 40, Issue: 5, May, 1998, pp. 421-441
Deng, H.; Vu-Quoc, L.
The penetration energy of sandwich panel elements under static and dynamic loading. Part I
Composite Structures Volume: 42, Issue: 2, June, 1998, pp. 119-134
Jones, N.; Roach, A.M.; Evans, K.E.
On the performance of higher order theories for transient dynamic analysis of sandwich and composite beams
Computers & Structures Volume: 65, Issue: 5, December, 1997, pp. 741-759
Marur, S. R.; Kant, T.
Exact dynamic stiffness matrix for flexural vibration of three-layered sandwich beams
Journal of Sound and Vibration Volume: 282, Issue: 3-5, April 22, 2005, pp. 753-767
Howson, W.P.; Zare, A.
Dynamic stability of spinning pre-twisted sandwich beams with a constrained damping layer subjected to periodic axial loads
Composite Structures Volume: 70, Issue: 3, September, 2005, pp. 275-286
Lin, Chung-Yi; Chen, Lien-Wen
Free vibration of sandwich beams using the dynamic stiffness method
Computers and Structures Volume: 81, Issue: 18-19, August, 2003, pp. 1915-1922
Banerjee, J.R.
Vibration and dynamic stability of a traveling sandwich beam
Journal of Sound and Vibration Volume: 285, Issue: 3, July 22, 2005, pp. 597-614
Yang, Wen-Pei; Chen, Lien-Wen; Wang, Ching-Cheng
发表于 2006-6-1 13:15 | 显示全部楼层
欧阳教授果然厉害
不才正在做关于constrained layer damping方面的,对sandwich beam和sandwich plate稍有研究
lz还有什么不明白可以给我发信:suesima@163.com
[此贴子已经被作者于2006-6-1 13:16:17编辑过]
发表于 2006-6-1 13:50 | 显示全部楼层
  聊聊suesima你的阻尼是怎么个处理思路... ...
GMT+8, 2024-11-30 20:45 , Processed in 0.101122 second(s), 18 queries , Gzip On.
