查看: 1358|回复: 2
[Virtual.Lab] 运行vl时出错,显示job execution failed是怎么回事
发表于 2017-5-26 11:28 | 显示全部楼层 |阅读模式
XPR VERSION 12
Requested task is SYSNOISE parallel computation.
Working directory on server is C:\Users\zhangfan\AppData\Local\Temp
Checking that the SYSNOISE launch script (C:\Program Files\LMS\LMS Virtual.Lab 12\VirtualLab\Sysnoise\5.6\bin\sysnoise_nogui.bat) exists on server...
OK
SYSNOISE log file on server is C:\Users\zhangfan\AppData\Local\Temp\zhangfan-195188-sysnoise.log.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxx  JOB EXECUTION START
                System for Computational Vibro-Acoustics
SYSNOISE Rev 5.6  Windows_x86_64  MAR2003 DATE: 26-MAY-2017 11:23:08
PATCH LEVEL  P  (Build Date: 03-JUN-2013)
READING THE SET-UP FILE: C:\Program Files\LMS\LMS Virtual.Lab 12\VirtualLab\Sysnoise\5.6\bin\\..\res\SYSNOISE.STP
THE SYSNOISE PROFILE FILE NAME HAS NOT BEEN DEFINED.
STANDARD GRAPHIC DEVICE SET TO DEFAULT
PLOTTING GRAPHIC DEVICE SET TO SCREENDUMP
MEMORY IN USE   =         800000
AVAILABLE MEMORY=      174475006
FREE MEMORY     =      173675006
CREATING DEFAULT SYSNOISE MODEL FILE default.sdb
SYSNOISE ANALYSIS OPTION :
      BEM INDIRECT VARIATIONAL UNBAFFLED FREQUENCY FLUID
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP USRDIR 'C:\Users\zhangfan\AppData\Local\Temp\' RETURN
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP TMPDIR 'C:\Users\zhangfan\AppData\Local\Temp\' RETURN
SYSNOISE>  SCL> ENVIRONMENT DISTRIBUTED=TRUE RETURN
SYSNOISE>  SCL> ENVIRONMENT DISTRILEVEL=FREQUENCY RETURN
SYSNOISE>  SCL> Open Model 1 File zhangfan-195188-Acoustic.sdb Original Return
OPENING SYSNOISE MODEL FILE zhangfan-195188-Acoustic.sdb.0
LOADING MODEL Exported VLModel
SYSNOISE>  SCL> Extract Summary Return
      FEM VARIATIONAL FREQUENCY FLUID
SYSNOISE SUMMARY INFORMATION
Title...Exported VLModel
Date....26-MAY-2017 11:23:08
Number of dimensions......................      3
Number of nodes...........................  12715
Number of elements........................  59273
Number of tables..........................      6
Number of material characteristics........      2
Number of transfer admittance relations...      1
Number of faces with transfer admittance..   3192
Number of load cases......................      1
Number of faces with velocity B.C.'s......     43
Number of faces with admit/imped B.C.'s...     62
SYSNOISE>  SCL> Option FEM Frequency Fluid Return
SYSNOISE>  SCL> Environment Section SETUP BELL 'on' Return
SYSNOISE>  SCL> Environment Section SETUP SOLVITER 0 Return
SYSNOISE>  SCL> Environment Section SETUP STABLEFEM TRUE Return
SYSNOISE>  SCL> Environment Section SETUP GEO_TOLERANCE '1E-006' Return
SYSNOISE>  SCL> ENVIRONMENT SECTION PFEM STRATEGY 0 RETURN
SYSNOISE>  SCL> Parameter Model 1  Physical
PARAMETER>  SCL>   Save Potentials Step 1
PARAMETER>  SCL>   Save Results none
PARAMETER>  SCL>   NoFlow
PARAMETER>  SCL> Return
Updating Model Parameters
SYSNOISE>  SCL> Solve
SOLVE>  SCL> Frequency 100 To 1000 LinStep 25
SOLVE>  SCL> Return
FREQUENCY RESPONSE MODULE
FOR   37 FREQUENCIES FROM      100.000 TO     1000.000 HZ
ANALYSIS #     1  FREQUENCY =        100.000 HZ  TYPE = NORMAL
ANALYSIS #     2  FREQUENCY =        125.000 HZ  TYPE = NORMAL
ANALYSIS #     3  FREQUENCY =        150.000 HZ  TYPE = NORMAL
ANALYSIS #     4  FREQUENCY =        175.000 HZ  TYPE = NORMAL
ANALYSIS #     5  FREQUENCY =        200.000 HZ  TYPE = NORMAL
ANALYSIS #     6  FREQUENCY =        225.000 HZ  TYPE = NORMAL
ANALYSIS #     7  FREQUENCY =        250.000 HZ  TYPE = NORMAL
ANALYSIS #     8  FREQUENCY =        275.000 HZ  TYPE = NORMAL
ANALYSIS #     9  FREQUENCY =        300.000 HZ  TYPE = NORMAL
ANALYSIS #    10  FREQUENCY =        325.000 HZ  TYPE = NORMAL
ANALYSIS #    11  FREQUENCY =        350.000 HZ  TYPE = NORMAL
ANALYSIS #    12  FREQUENCY =        375.000 HZ  TYPE = NORMAL
ANALYSIS #    13  FREQUENCY =        400.000 HZ  TYPE = NORMAL
ANALYSIS #    14  FREQUENCY =        425.000 HZ  TYPE = NORMAL
ANALYSIS #    15  FREQUENCY =        450.000 HZ  TYPE = NORMAL
ANALYSIS #    16  FREQUENCY =        475.000 HZ  TYPE = NORMAL
ANALYSIS #    17  FREQUENCY =        500.000 HZ  TYPE = NORMAL
ANALYSIS #    18  FREQUENCY =        525.000 HZ  TYPE = NORMAL
ANALYSIS #    19  FREQUENCY =        550.000 HZ  TYPE = NORMAL
ANALYSIS #    20  FREQUENCY =        575.000 HZ  TYPE = NORMAL
ANALYSIS #    21  FREQUENCY =        600.000 HZ  TYPE = NORMAL
ANALYSIS #    22  FREQUENCY =        625.000 HZ  TYPE = NORMAL
ANALYSIS #    23  FREQUENCY =        650.000 HZ  TYPE = NORMAL
ANALYSIS #    24  FREQUENCY =        675.000 HZ  TYPE = NORMAL
ANALYSIS #    25  FREQUENCY =        700.000 HZ  TYPE = NORMAL
ANALYSIS #    26  FREQUENCY =        725.000 HZ  TYPE = NORMAL
ANALYSIS #    27  FREQUENCY =        750.000 HZ  TYPE = NORMAL
ANALYSIS #    28  FREQUENCY =        775.000 HZ  TYPE = NORMAL
ANALYSIS #    29  FREQUENCY =        800.000 HZ  TYPE = NORMAL
ANALYSIS #    30  FREQUENCY =        825.000 HZ  TYPE = NORMAL
ANALYSIS #    31  FREQUENCY =        850.000 HZ  TYPE = NORMAL
ANALYSIS #    32  FREQUENCY =        875.000 HZ  TYPE = NORMAL
ANALYSIS #    33  FREQUENCY =        900.000 HZ  TYPE = NORMAL
ANALYSIS #    34  FREQUENCY =        925.000 HZ  TYPE = NORMAL
ANALYSIS #    35  FREQUENCY =        950.000 HZ  TYPE = NORMAL
ANALYSIS #    36  FREQUENCY =        975.000 HZ  TYPE = NORMAL
ANALYSIS #    37  FREQUENCY =       1000.000 HZ  TYPE = NORMAL
SOLVE PARAMETERS
MODEL:   1 - Exported VLModel
    PHYSICAL Coordinates
    Saving POTENTIALS every        1 steps
    No saving of RESULTS
    Energy Calculation Enabled
    Surface post-processing on positive side
LAUNCHING UNCOUPLED ACOUSTIC FEM (Physical Coords - Freq) ANALYSIS
NO SUPERIMPOSED NODES WITH TOLERANCE=  6.29000E-07
NO ISOLATED NODES
CHECKING ELEMENT TOPOLOGY AND DISTORTION
NO SUPERIMPOSED ELEMENTS WITH TOLERANCE=  6.29000E-07
Checking MESH Connectivity...
      2 Part(s) and     2 Sub-Domain(s) found
      4232 ENVELOPE FACE(S) REMAINING FOR PART    1
      6866 ENVELOPE FACE(S) REMAINING FOR PART    2
Occupied space:             14 Mb  (  2.06 %)
COMPUTING PART INFORMATION:
      Part       1   Volume:   4.84985E-03
      Part       2   Volume:   7.73140E-03
THIS MODEL SEEMS SUITABLE FOR A FEM FLUID APPROACH
CPU Stats --- Delta:  0:00:03 (      3.12)  Total:  0:00:03 (      3.12)
Computing MASS and STIFFNESS elements matrices
using HIGH PRECISION STABILIZED scheme for linear elements
CPU Stats --- Delta:  0:00:00 (      0.33)  Total:  0:00:03 (      3.45)
Computing VELOCITY matrices on elements faces
CPU Stats --- Delta:  0:00:00 (      0.49)  Total:  0:00:04 (      3.94)
Computing ADMITTANCE matrices on elements faces
*****Interpolation between non-matching surfaces with transfer admittance relations:*****
=== Transfer admittance relation #           1
*There were         1596  acoustic faces of surface 1 coupled with         1596
  acoustic faces of surface 2.           0  acoustic faces were
excluded from surface 1 for being beyond the tolerance.
There were            0  orphaned  nodes (not coupled) out of the          840
  nodes of the acoustic surface 2.
There were      0 Gauss points interpolated with a nodal distance-based algorithm and   6384 Gauss points interpolated with an element-based algorithm.
*****End of interpolation information:*****
CPU Stats --- Delta:  0:00:00 (      0.40)  Total:  0:00:04 (      4.34)
CPU Stats --- Delta:  0:00:00 (      0.00)  Total:  0:00:04 (      4.34)
Solver is MUMPS solver
Number of equations               12715
COMPUTATION PROGRESS :       0 /     37                     (   0.00 % )
ANALYSIS NUMBER      4 /     37                FREQUENCY =    175.000 Hz
CPU Stats --- Delta:  0:00:00 (      0.46)  Total:  0:00:05 (      4.80)
Building Matrix of Coefficients
CPU Stats --- Delta:  0:00:00 (      0.10)  Total:  0:00:05 (      4.90)
CPU Stats --- Delta:  0:00:00 (      0.01)  Total:  0:00:05 (      4.91)
Occupied space:             13 Mb  (  1.93 %)
Solving system of equations by direct   solver
Analysis Phase ...
A FATAL ERROR OCCURRED.  PROGRAM STOPPED
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
发表于 2017-5-26 13:36 | 显示全部楼层
平行计算的?
 楼主| 发表于 2017-5-26 14:17 | 显示全部楼层
就是单核计算的,不知道怎么回事
GMT+8, 2025-1-8 22:30 , Processed in 0.050154 second(s), 17 queries , Gzip On.
