查看: 2169|回复: 6
[稳定性与分岔] 求助如何画三维相空间图
发表于 2017-2-22 10:39 来自手机 | 显示全部楼层 |阅读模式
利用数值可以得到二维杜芬系统的速度和位移,可以画三维曲线图,如何画三维网格图?
发表于 2017-2-22 11:01 | 显示全部楼层
  1. function dx=Duffing(t,x,flag,f); global f; %Duffing方程
  2. a=0.25;
  3. b=-1;
  4. c=1;
  5. w=1;
  6. dx=[x(2);-a*x(2)-b*x(1)-c*x(1)^3+f*cos(x(3));w];
  7. %fftplot幅值谱
  8. function [f,y]=fftplot(x,step)
  9. [r,c] = size(x);
  10. if r == 1
  11.         x = x.';   % make it a column
  12. end;
  13. [n,cc] = size(x);
  14. m = 2^nextpow2(n);
  15. y = fft(x,m);
  16. y = y(1:n,:);
  17. yy=abs(y)*step;
  18. fid1=fopen('fft1.txt','w');
  19. fid2=fopen('aft1.txt','w');
  20. for kk=1:m/2+1;
  21.    f(kk)=(kk-1)/m/step;
  22.    fprintf(fid1,'%8.4f\n',f(kk));
  23.    fprintf(fid2,'%8.4f\n',y(kk));
  24. end
  25. fclose(fid1);
  26. fclose(fid2);
  27. y=yy(1:m/2+1);
  28. %plot(f,y);
  29. %xlabel('Frequency (Hz)');
  30. %ylabel('Fourier Amplitude');
  31. %title('Fouier Transform of the Data')
  32. %求解、绘图:时域波形、相平面、幅值谱、Poincare图、分岔图
  33. clc
  34. global f;
  35. f=0.1
  36. tspan=[0:0.01*2*pi:2000];
  37. options=odeset('RelTol',1e-5,'AbsTol',1e-6);
  38. [t,x]=ode45('Duffing',tspan,[1;1.5;0],options);
  39. x_data=x(:,1);
  40. x_dot=x(:,2);
  41. %时域波形
  42. axes('FontSize',16,'FontName','Times New Roman','LineWidth',1.5);
  43. hold on;
  44. plot(tspan,x_data,'LineWidth',1.5);
  45. xlim([100 200])
  46. %xlim([200 300])
  47. xlabel('\itt','Fontsize',20,'Fontname','Times new roman');%x轴标注
  48. ylabel('\itx','Fontsize',20,'Fontname','Times new roman','Rotation',0);%y轴标注
  49. grid on
  50. box on
  51. %相平面图
  52. figure(2)
  53. axes('FontSize',16,'FontName','Times New Roman','LineWidth',1.5);
  54. hold on;
  55. plot(x_data(1000:3000),x_dot(1000:3000),'LineWidth',1.5);
  56. %plot(x_data(10:30000),x_dot(10:30000),'LineWidth',1.5);
  57. xlabel('\itx','Fontsize',20,'Fontname','Times new roman');%x轴标注
  58. ylabel('d\itx/d\itt','Fontsize',20,'Fontname','Times new roman');%y轴标注
  59. grid on
  60. box on
  61. %幅值谱
  62. [freq,amp]=fftplot(x_data,0.01*2*pi);
  63. figure(3)
  64. axes('FontSize',16,'FontName','Times New Roman','LineWidth',1.5);
  65. hold on;
  66. xlim([0 1])
  67. ylim([0 200])
  68. plot(freq(1:5000),amp(1:5000),'LineWidth',1.5);
  69. xlabel('/Hz','Fontsize',20,'Fontname','Times new roman');%x轴标注
  70. ylabel('mu','Fontsize',20,'Fontname','Times new roman');%y轴标注
  71. grid on
  72. box on
  73. %poincare图
  74. x(:,2)=mod(x(:,2),2*pi)-pi;
  75. phi0=pi*1;
  76. for k=1:round(max(x(:,3))/2/pi);
  77.     d=x(:,3)-(k-1)*2*pi-phi0;
  78.     [P,K]=sort(abs(d));
  79.     x1l=x(K(1),1);
  80.     x1r=x(K(2),1);
  81.     x2l=x(K(1),2);
  82.     x2r=x(K(2),2);
  83.     x3l=x(K(1),3);
  84.     x3r=x(K(2),3);
  85.     if abs(P(1))+abs(P(2))<3e-16;
  86.         X1(k)=x1l;
  87.         X2(k)=x2l;
  88.     else
  89.         Q=polyfit([x3l,x3r],[x1l,x1r],1);
  90.         X1(k)=polyval(Q,(k-1)*2*pi-phi0);
  91.          Q=polyfit([x3l,x3r],[x2l,x2r],1);
  92.         X2(k)=polyval(Q,(k-1)*2*pi-phi0);
  93.     end
  94. end
  95.     figure(4)
  96.    axes('FontSize',16,'FontName','Times New Roman','LineWidth',1.5);
  97.    plot(X1,X2,'.');
  98.   xlabel('\itx','Fontsize',20,'Fontname','Times new roman');%x轴标注
  99. ylabel('d\itx/d\itt','Fontsize',20,'Fontname','Times new roman');%y轴标注
  100. %分岔图
  101. global f
  102. figure(5)
  103. hold on;
  104. box on;
  105. xlim([0,1]);
  106. ylim([-2,2]);
  107. N=80;
  108. Tn=zeros(1,N);
  109. options=odeset('RelTol',1e-9);
  110. for f=0.05:.05:1;
  111. x0=[0,1.5,0];
  112. for n=1:60;
  113. [t,x]=ode45('Duffing',[0,2*pi],x0,options);
  114. x0=x(end,:);
  115. end
  116. for n=1:N;
  117. [t,x]=ode45('Duffing',[0,pi*2],x0,options);
  118. x0=x(end,:);
  119. xd=x(:,1);
  120. Tn(n)=max(xd);
  121. end
  122. f
  123. plot(f,Tn,'b.','markersize',1);
  124. pause(0.0001);
  125. end
  126. xlabel('\itf','Fontsize',16,'Fontname','Times new roman');%x轴标注
  127. ylabel('\itx','Fontsize',16,'Fontname','Times new roman','Rotation',0);%y轴标注
仅供参考
 楼主| 发表于 2017-2-22 12:29 来自手机 | 显示全部楼层
这个是相平面图 我希望是如图的相空间图
 楼主| 发表于 2017-2-22 22:20 | 显示全部楼层
顶楼的相空间是如何画?自由度1的位移-速度-自由度2的位移
发表于 2017-2-23 08:29 | 显示全部楼层
plot3  meshgrid等命令不都能实现吗
 楼主| 发表于 2017-2-23 16:58 来自手机 | 显示全部楼层
plot3是画空间曲线,meshgrid要求z是矩阵
matlab不就是针对矩阵进行的运算吗  详情 回复 发表于 2017-2-24 08:32
发表于 2017-2-24 08:32 | 显示全部楼层
matlab不就是针对矩阵进行的运算吗
GMT+8, 2024-12-27 21:04 , Processed in 0.114361 second(s), 22 queries , Gzip On.
