查看: 2244|回复: 1
[编程技巧] 多项式拟合.m文件
发表于 2005-7-26 21:31 | 显示全部楼层 |阅读模式
<PRE>% General Polynomial Fitting Method
function Ans=polyfit2(x,y,order)
% Polynomial Fitting Method
% x,y are two set of data, and order is the
% max degree of fitting polynomial
% FangQ
% 2000/11/30
n=4
if nargin==3
   n=order;
if size(x)~=size(y)
   warning('Bad input data');
n=n+1;
a=zeros(1,n);
A=zeros(n);
Y=zeros(n,1);
for i=1:n
   for j=1:n
      A(i,j)=sum(x.^(i+j-2));
for i=1:n
   Y(i,1)=sum(y.*x.^(i-1));
Ans=inv(A)*Y;
XI=min(x):min(diff(x))/3:max(x);
Poly=num2str(Ans(1));
for i=2:n
   Poly=strcat(Poly,'+(',num2str(Ans(i)),'*x^',num2str(i-1),')');
disp(sprintf('Polynomial: \n\t %s',Poly));
FitError=sum((y-polyval(fliplr(Ans'),x)).^2);
disp(sprintf('\nTotal error is %f',FitError));
hold on;
plot(XI,polyval(fliplr(Ans'),XI),'r-',x,y,'o');
</PRE>
发表于 2005-8-1 11:10 | 显示全部楼层
挺好用的,就是要注意换行,
要不粘贴时不太好整。
哈哈。
[ 本帖最后由 xinyuxf 于 2007-7-3 09:04 编辑 ]
GMT+8, 2025-1-19 17:20 , Processed in 0.094759 second(s), 17 queries , Gzip On.
