查看: 1974|回复: 1
EMD信号处理的程序
发表于 2016-10-28 11:01 | 显示全部楼层 |阅读模式
新手报到
职业: 学习的人
性别:
年龄: 29
所在地: 广东
毕业院校:
工作单位:
行业: 教工
如何知道本站: 朋友介绍
本站给您带来什么帮助?:
对论坛的建议: -
附件不能发压缩包,好奇怪的,,只好复制粘贴过来了, 是以前我用过的EMD信号处理程序 ,看对大家能不能有用 。
% EMD.M
% computes EMD (Empirical Mode Decomposition) according to:
% N. E. Huang et al., "The empirical mode decomposition and the
% Hilbert spectrum for non-linear and non stationary time series analysis",
% Proc. Royal Soc. London A, Vol. 454, pp. 903-995, 1998
% with variations reported in:
% G. Rilling, P. Flandrin and P. Gon峚lv弒
% "On Empirical Mode Decomposition and its algorithms",
% IEEE-EURASIP Workshop on Nonlinear Signal and Image Processing
% NSIP-03, Grado (I), June 2003
% default stopping criterion for sifting :
%   at each point : mean amplitude < threshold2*envelope amplitude
%   mean of boolean array ((mean amplitude)/(envelope amplitude) > threshold) < tolerance
%   |#zeros-#extrema|<=1
% inputs:
%                - x: analysed signal (line vector)
%                - opts (optional): struct object with (optional) fields:
%                        - t: sampling times (line vector) (default: 1:length(x))
%                        - stop: threshold, threshold2 and tolerance (optional)
%                                for sifting stopping criterion
%                                default: [0.05,0.5,0.05]
%                        - display: if equals to 1 shows sifting steps with pause
%                                if equals to 2 shows sifting steps without pause (movie style)
%                        - maxiterations: maximum number of sifting steps for the computation of each mode
%                        - fix (int): disable the stopping criterion and do exactly
%                                the value of the field number of sifting steps for each mode
%                        - maxmodes: maximum number of imfs extracted
%                        - interp: interpolation scheme: 'linear', 'cubic' or 'spline' (default)
%                        - fix_h (int): do <fix_h> sifting iterations with |#zeros-#extrema|<=1 to stop
%                                according to N. E. Huang et al., "A confidence limit for the Empirical Mode
%                                Decomposition and Hilbert spectral analysis",
%                                Proc. Royal Soc. London A, Vol. 459, pp. 2317-2345, 2003
%                        - mask: masking signal used to improve the decomposition
%                                according to R. Deering and J. F. Kaiser, "The use of a masking signal to
%                                improve empirical mode decomposition",
%                                ICASSP 2005
% outputs:
%                - imf: intrinsic mode functions (last line = residual)
%                - ort: index of orthogonality
%                - nbits: number of iterations for each mode
% calls:
%                - io: computes the index of orthogonality
%examples:
%>>x = rand(1,512);
%>>imf = emd(x);
%>>imf = emd(x,struct('stop',[0.1,0.5,0.05],'maxiterations',100));
%Remark: the following syntax is equivalent
%>>imf = emd(x,'stop',[0.1,0.5,0.05],'maxiterations',100);
%>>options.dislpay = 1;
%>>options.fix = 10;
%>>options.maxmodes = 3;
%>>[imf,ort,nbits] = emd(x,options);
function [imf,ort,nbits] = emd(varargin);
[x,t,sd,sd2,tol,display_sifting,sdt,sd2t,ner,nzr,lx,r,imf,k,nbit,NbIt,MAXITERATIONS,FIXE,FIXE_H,MAXMODES,INTERP,mask] = init(varargin{:});
if display_sifting
  figure
% maximum number of iterations
% MAXITERATIONS=2000;
%main loop : requires at least 3 extrema to proceed
while ~stop_EMD(r) & (k < MAXMODES+1 | MAXMODES == 0) & ~any(mask)
        % current mode
        m = r;
        % mode at previous iteration
        mp = m;
        if FIXE
                [stop_sift,moyenne] = stop_sifting_fixe(t,m,INTERP);
        elseif FIXE_H
                stop_count = 0;
                [stop_sift,moyenne,stop_count] = stop_sifting_fixe_h(t,m,INTERP,stop_count,FIXE_H);
                stop_count = 0;
        else
                [stop_sift,moyenne] = stop_sifting(m,t,sd,sd2,tol,INTERP);
          if (max(m) - min(m)) < (1e-10)*(max(x) - min(x))
            if ~stop_sift
                           warning('forced stop of EMD : too small amplitude')
            else
                      disp('forced stop of EMD : too small amplitude')
            break
          % sifting loop
          while ~stop_sift & nbit<MAXITERATIONS
            if(nbit>MAXITERATIONS/5 & mod(nbit,floor(MAXITERATIONS/10))==0 & ~FIXE & nbit > 100)
                      disp(['mode ',int2str(k),', iteration ',int2str(nbit)])
                        if exist('s')
                              disp(['stop parameter mean value : ',num2str(s)])
            [im,iM] = extr(m);
            disp([int2str(sum(m(im) > 0)),' minima > 0; ',int2str(sum(m(iM) < 0)),' maxima < 0.'])
                   %sifting
            m = m - moyenne;
                %computation of mean and stopping criterion
                if FIXE
                elseif FIXE_H
                else
                        [stop_sift,moyenne,s] = stop_sifting(m,t,sd,sd2,tol,INTERP);
            % display
            if display_sifting
                        [envminp,envmaxp,envmoyp] = envelope(t,mp,INTERP);
                        if FIXE |FIXE_H
                                display_emd_fixe(t,m,mp,r,envminp,envmaxp,envmoyp,nbit,k,display_sifting)
                        else
                                   sxp=2*(abs(envmoyp))./(abs(envmaxp-envminp));
                                   sp = mean(sxp);
                                display_emd(t,m,mp,r,envminp,envmaxp,envmoyp,s,sp,sxp,sdt,sd2t,nbit,k,display_sifting,stop_sift)
            mp = m;
            nbit=nbit+1;
            NbIt=NbIt+1;
            if(nbit==(MAXITERATIONS-1) & ~FIXE & nbit > 100)
            if exist('s')
                warning(['forced stop of sifting : too many iterations... mode ',int2str(k),'. stop parameter mean value : ',num2str(s)])
            else
                warning(['forced stop of sifting : too many iterations... mode ',int2str(k),'.'])
          end % sifting loop
          imf(k,:) = m;
          if display_sifting
                  disp(['mode ',int2str(k),' stored'])
          nbits(k) = nbit;
          k = k+1;
          r = r - m;
          nbit=0;
end %main loop
if sum(r.^2) & ~any(mask)
        imf(k,:) = r;
ort = io(x,imf);
if display_sifting
  close
function stop = stop_EMD(r)
        [indmin,indmax,indzer] = extr(r);
        ner = length(indmin) + length(indmax);
        stop = ner <3;
function [stop,envmoy,s]= stop_sifting(m,t,sd,sd2,tol,INTERP)
        try
                   [envmin,envmax,envmoy,indmin,indmax,indzer] = envelope(t,m,INTERP);
                   nem = length(indmin) + length(indmax);
                   nzm = length(indzer);
                   % evaluation of mean zero
                   sx=2*(abs(envmoy))./(abs(envmax-envmin));
                   s = mean(sx);
                stop = ~((mean(sx > sd) > tol | any(sx > sd2) | (abs(nzm-nem)>1)) & (nem > 2));
        catch
                stop = 1;
                envmoy = zeros(1,length(m));
                s = NaN;
function [stop,moyenne]= stop_sifting_fixe(t,m,INTERP)
        try
                [envmin,envmax,moyenne] = envelope(t,m,INTERP);
                stop = 0;
        catch
                moyenne = zeros(1,length(m));
                stop = 1;
function [stop,moyenne,stop_count]= stop_sifting_fixe_h(t,m,INTERP,stop_count,FIXE_H)
        try
                [envmin,envmax,moyenne,indmin,indmax,indzer] = envelope(t,m,INTERP);
                if (abs(nzm-nem)>1)
                        stop = 0;
                        stop_count = 0;
                else
                        stop_count = stop_count+1;
                        stop = (stop_count == FIXE_H);
        catch
                stop = 1;
function display_emd(t,m,mp,r,envmin,envmax,envmoy,s,sb,sx,sdt,sd2t,nbit,k,display_sifting,stop_sift)
        subplot(4,1,1)
    plot(t,mp);hold on;
    plot(t,envmax,'--k');plot(t,envmin,'--k');plot(t,envmoy,'r');
    title(['IMF ',int2str(k),';   iteration ',int2str(nbit),' before sifting']);
    set(gca,'XTick',[])
    hold  off
    subplot(4,1,2)
    plot(t,sx)
    hold on
    plot(t,sdt,'--r')
    plot(t,sd2t,':k')
    title('stop parameter')
    set(gca,'XTick',[])
    hold off
    subplot(4,1,3)
    plot(t,m)
    title(['IMF ',int2str(k),';   iteration ',int2str(nbit),' after sifting']);
    set(gca,'XTick',[])
    subplot(4,1,4);
    plot(t,r-m)
    title('residue');
    disp(['stop parameter mean value : ',num2str(sb),' before sifting and ',num2str(s),' after'])
        if stop_sift
                disp('last iteration for this mode')
    if display_sifting == 2
      pause(0.01)
    else
      pause
function display_emd_fixe(t,m,mp,r,envmin,envmax,envmoy,nbit,k,display_sifting)
        subplot(3,1,1)
    plot(t,mp);hold on;
    set(gca,'XTick',[])
    hold  off
    subplot(3,1,2)
    plot(t,m)
    set(gca,'XTick',[])
    subplot(3,1,3);
    plot(t,r-m)
    title('residue');
      pause(0.01)
    else
      pause
function [envmin, envmax,envmoy,indmin,indmax,indzer] = envelope(t,x,INTERP)
%computes envelopes and mean with various interpolations
NBSYM = 2;
DEF_INTERP = 'spline';
if nargin < 2
        x = t;
        t = 1:length(x);
        INTERP = DEF_INTERP;
if nargin == 2
        if ischar(x)
                INTERP = x;
                x = t;
                t = 1:length(x);
if ~ischar(INTERP)
        error('interp parameter must be ''linear'''', ''cubic'' or ''spline''')
if ~any(strcmpi(INTERP,{'linear','cubic','spline'}))
if min([size(x),size(t)]) > 1
        error('x and t must be vectors')
s = size(x);
if s(1) > 1
        x = x';
s = size(t);
if s(1) > 1
        t = t';
if length(t) ~= length(x)
        error('x and t must have the same length')
lx = length(x);
[indmin,indmax,indzer] = extr(x,t);
%boundary conditions for interpolation
[tmin,tmax,xmin,xmax] = boundary_conditions(indmin,indmax,t,x,NBSYM);
% definition of envelopes from interpolation
envmax = interp1(tmax,xmax,t,INTERP);
envmin = interp1(tmin,xmin,t,INTERP);
if nargout > 2
    envmoy = (envmax + envmin)/2;
function [tmin,tmax,xmin,xmax] = boundary_conditions(indmin,indmax,t,x,nbsym)
% computes the boundary conditions for interpolation (mainly mirror symmetry)
        lx = length(x);
        if (length(indmin) + length(indmax) < 3)
                error('not enough extrema')
        if indmax(1) < indmin(1)
            if x(1) > x(indmin(1))
                        lmax = fliplr(indmax(2:min(end,nbsym+1)));
                        lmin = fliplr(indmin(1:min(end,nbsym)));
                        lsym = indmax(1);
                else
                        lmax = fliplr(indmax(1:min(end,nbsym)));
                        lmin = [fliplr(indmin(1:min(end,nbsym-1))),1];
                        lsym = 1;
        else
                if x(1) < x(indmax(1))
                        lmin = fliplr(indmin(2:min(end,nbsym+1)));
                        lsym = indmin(1);
                else
                        lmax = [fliplr(indmax(1:min(end,nbsym-1))),1];
                        lsym = 1;
        if indmax(end) < indmin(end)
                if x(end) < x(indmax(end))
                        rmax = fliplr(indmax(max(end-nbsym+1,1):end));
                        rmin = fliplr(indmin(max(end-nbsym,1):end-1));
                        rsym = indmin(end);
                else
                        rmax = [lx,fliplr(indmax(max(end-nbsym+2,1):end))];
                        rmin = fliplr(indmin(max(end-nbsym+1,1):end));
                        rsym = lx;
        else
                if x(end) > x(indmin(end))
                        rmax = fliplr(indmax(max(end-nbsym,1):end-1));
                        rsym = indmax(end);
                else
                        rmin = [lx,fliplr(indmin(max(end-nbsym+2,1):end))];
                        rsym = lx;
        tlmin = 2*t(lsym)-t(lmin);
        tlmax = 2*t(lsym)-t(lmax);
        trmin = 2*t(rsym)-t(rmin);
        trmax = 2*t(rsym)-t(rmax);
        % in case symmetrized parts do not extend enough
        if tlmin(1) > t(1) | tlmax(1) > t(1)
                if lsym == indmax(1)
                else
                if lsym == 1
                        error('bug')
                lsym = 1;
        if trmin(end) < t(lx) | trmax(end) < t(lx)
                if rsym == indmax(end)
                else
        if rsym == lx
                error('bug')
                rsym = lx;
        xlmax =x(lmax);
        xlmin =x(lmin);
        xrmax =x(rmax);
        xrmin =x(rmin);
        tmin = [tlmin t(indmin) trmin];
        tmax = [tlmax t(indmax) trmax];
        xmin = [xlmin x(indmin) xrmin];
        xmax = [xlmax x(indmax) xrmax];
function [indmin, indmax, indzer] = extr(x,t);
%extracts the indices corresponding to extrema
if(nargin==1)
  t=1:length(x);
m = length(x);
if nargout > 2
        x1=x(1:m-1);
        x2=x(2:m);
        indzer = find(x1.*x2<0);
        if any(x == 0)
          iz = find( x==0 );
          indz = [];
          if any(diff(iz)==1)
            zer = x == 0;
            dz = diff([0 zer 0]);
            debz = find(dz == 1);
            finz = find(dz == -1)-1;
            indz = round((debz+finz)/2);
          else
            indz = iz;
          indzer = sort([indzer indz]);
d = diff(x);
n = length(d);
d1 = d(1:n-1);
d2 = d(2:n);
indmin = find(d1.*d2<0 & d1<0)+1;
indmax = find(d1.*d2<0 & d1>0)+1;
% when two or more consecutive points have the same value we consider only one extremum in the middle of the constant area
if any(d==0)
  imax = [];
  imin = [];
  bad = (d==0);
  dd = diff([0 bad 0]);
  debs = find(dd == 1);
  fins = find(dd == -1);
  if debs(1) == 1
    if length(debs) > 1
      debs = debs(2:end);
      fins = fins(2:end);
    else
      debs = [];
      fins = [];
  if length(debs) > 0
    if fins(end) == m
      if length(debs) > 1
        debs = debs(1:(end-1));
        fins = fins(1:(end-1));
      else
        debs = [];
        fins = [];
  lc = length(debs);
  if lc > 0
    for k = 1:lc
      if d(debs(k)-1) > 0
        if d(fins(k)) < 0
          imax = [imax round((fins(k)+debs(k))/2)];
      else
        if d(fins(k)) > 0
          imin = [imin round((fins(k)+debs(k))/2)];
  if length(imax) > 0
    indmax = sort([indmax imax]);
  if length(imin) > 0
    indmin = sort([indmin imin]);
function [x,t,sd,sd2,tol,display_sifting,sdt,sd2t,ner,nzr,lx,r,imf,k,nbit,NbIt,MAXITERATIONS,FIXE,FIXE_H,MAXMODES,INTERP,mask] = init(varargin)
x = varargin{1};
if nargin == 2
        if strcmp(class(varargin{2}),'struct')
                inopts = varargin{2};
        else
                error('when using 2 arguments the first one is the analysed signal x and the second one is a struct object describing the options')
elseif nargin > 2
        try
                inopts = struct(varargin{2:end});
        catch
                error('bad argument syntax')
% default for stopping
defstop = [0.05,0.5,0.05];
opt_fields = {'t','stop','display','maxiterations','fix','maxmodes','interp','fix_h','mask'};
defopts.stop = defstop;
defopts.display = 0;
defopts.t = 1:max(size(x));
defopts.maxiterations = 2000;
defopts.fix = 0;
defopts.maxmodes = 0;
defopts.interp = 'spline';
defopts.fix_h = 0;
defopts.mask = 0;
opts = defopts;
if(nargin==1)
        inopts = defopts;
elseif nargin == 0
        error('not enough arguments')
names = fieldnames(inopts);
for nom = names'
        if length(strmatch(char(nom), opt_fields)) == 0
                error(['bad option field name: ',char(nom)])
        eval(['opts.',char(nom),' = inopts.',char(nom),';'])
t = opts.t;
stop = opts.stop;
display_sifting = opts.display;
MAXITERATIONS = opts.maxiterations;
FIXE = opts.fix;
MAXMODES = opts.maxmodes;
INTERP = opts.interp;
FIXE_H = opts.fix_h;
mask = opts.mask;
S = size(x);
if ((S(1) > 1) & (S(2) > 1)) | (length(S) > 2)
  error('x must have only one row or one column')
if S(1) > 1
  x = x';
S = size(t);
  error('option field t must have only one row or one column')
if S(1) > 1
  t = t';
if (length(t)~=length(x))
  error('x and option field t must have the same length')
S = size(stop);
if ((S(1) > 1) & (S(2) > 1)) | (S(1) > 3) | (S(2) > 3) | (length(S) > 2)
  error('option field stop must have only one row or one column of max three elements')
if ~all(isfinite(x))
        error('data elements must be finite')
if S(1) > 1
  stop = stop';
  S = size(stop);
if S(2) < 3
  stop(3)=defstop(3);
if S(2) < 2
  stop(2)=defstop(2);
if ~ischar(INTERP)
        error('interp field must be ''linear'', ''cubic'' or ''spline''')
%special procedure when a masking signal is specified
if any(mask)
        S = size(mask);
        if min(S) > 1
                error('masking signal must have the same dimension as the analyzed signal x')
        if S(1) > 1
                mask = mask';
        if max(S) ~= max(size(x))
        opts.mask = 0;
        imf1 = emd(x+mask,opts);
        imf2 = emd(x-mask,opts);
        if size(imf1,1) ~= size(imf2,1)
                warning(['the two sets of IMFs have different sizes: ',int2str(size(imf1,1)),' and ',int2str(size(imf2,1)),' IMFs.'])
        S1 = size(imf1,1);
        S2 = size(imf2,1);
        if S1 ~= S2
                if S1 < S2
                        tmp = imf1;
                        imf1 = imf2;
                        imf2 = tmp;
                imf2(max(S1,S2),1) = 0;
        imf = (imf1+imf2)/2;
sd = stop(1);
sd2 = stop(2);
tol = stop(3);
lx = length(x);
sdt = sd*ones(1,lx);
sd2t = sd2*ones(1,lx);
if FIXE
        MAXITERATIONS = FIXE;
        if FIXE_H
                error('cannot use both ''fix'' and ''fix_h'' modes')
% number of extrema and zero-crossings in residual
ner = lx;
nzr = lx;
r = x;
if ~any(mask) % if a masking signal is specified "imf" already exists at this stage
        imf = [];
k = 1;
% iterations counter for extraction of 1 mode
nbit=0;
% total iterations counter
NbIt=0;
发表于 2016-10-28 13:31 | 显示全部楼层
感谢您的分享  您是大学教师吧  代码放在这里更规范
GMT+8, 2025-1-13 19:45 , Processed in 0.205212 second(s), 28 queries , Gzip On.
