查看: 2305|回复: 2
[结构分析] workbench中integration point results中的选择
发表于 2016-9-17 23:07 | 显示全部楼层 |阅读模式
10体能
       在workbench中进行静力分析时,在查看结果时,有一个integration point results选项 integration.png ,一般选择哪个结果
发表于 2016-9-22 16:08 | 显示全部楼层
一般选 averaged 默认的。
Unaveraged: Displays unaveraged results.
Averaged: Displays averaged results.
Nodal Difference: Computes the maximum difference between the unaveraged computed result (for example, total heat flux, equivalent stress) for all elements that share a particular node.
Nodal Fraction: Computes the ratio of the nodal difference and the nodal average.
Elemental Difference: Computes the maximum difference between the unaveraged computed result (for example, total heat flux, equivalent stress) for all nodes in an element, including midside nodes.
Elemental Fraction: Computes the ratio of the elemental difference and the elemental average.
Elemental Mean: Computes the elemental average from the averaged component results.
这都是什么啊  详情 回复 发表于 2016-9-23 09:04
发表于 2016-9-23 09:04 | 显示全部楼层
Fancredit 发表于 2016-9-22 16:08
一般选 averaged 默认的。
这都是什么啊
GMT+8, 2024-12-29 06:37 , Processed in 0.062111 second(s), 22 queries , Gzip On.
