查看: 2292|回复: 0
利用Python输出Abaqus的结果数据
发表于 2016-5-27 14:50 | 显示全部楼层 |阅读模式
  from odbAccess import *
  #打开Ddb文件
  odb = openOdb(path='viewer_tutorial.odb')
  #创建变量lastFrame,得到载荷步Step-1的最后一帧
  lastFrame = odb.steps['Step-1'].frames[-1]
  # Create a variable that refers to the displacement 'U'
  # in the last frame of the first step.
  #创建变量displacement ,得到最后一帧的位移场数据
  displacement = lastFrame.fieldOutputs['U']
  #创建变量center,得到节点集PUNCH
  center = odb.rootAssembly.instances['PART-1-1'].\
  nodeSets['PUNCH']
  #创建变量centerDisplacement,得到region center的位移场数据
  centerDisplacement = displacement.getSubset(region=center)
  #输出各种信息,该节点集只有一个节点
  1.   for v in centerDisplacement.values:
  2.   print 'Position = ', v.position,'Type = ',v.type
  3.   print 'Node label = ', v.nodeLabel
  4.   print 'X displacement = ', v.data[0]
  5.   print 'Y displacement = ', v.data[1]
  6.   print 'Displacement magnitude =', v.magnitude
  7.   odb.close()
  输出结果为:
  1.   The resulting output is
  2.   Position = NODAL Type = VECTOR
  3.   Node label = 1000
  4.   X displacement = -8.29017850095e-34
  5.   Y displacement = -76.4554519653
  6.   Displacement magnitude = 76.4554519653
转自:http://blog.sina.com.cn/s/blog_6465f2ed0102x4ei.html
GMT+8, 2025-1-14 20:41 , Processed in 0.064445 second(s), 17 queries , Gzip On.
