查看: 17213|回复: 74
[心得体会] Mobius institute振动分析资料分享(中英文对照)
发表于 2016-5-13 09:10 | 显示全部楼层 |阅读模式
1 Analysis Definitions: Unbalance 不平衡
1.1 Unbalance: Static imbalance 静不平衡
1.2 Unbalance: Couple imbalance 力偶不平衡
1.3 Unbalance: Dynamic unbalance 动不平衡
1.4 Unbalance: Vertical machines 立式设备
1.5 Unbalance: Overhung machines 悬臂设备
2 Analysis Definitions: Misalignment 不对中
2.1 Misalignment: Parallel (Offset)平行不对中
2.2 Misalignment: Angular (Gap)角不对中
3 Analysis Definitions: Rolling element bearings 滚道轴承
3.1 Rolling element bearings: Stage one fault 滚道轴承:第一阶段故障
3.2 Rolling element bearings: Stage two fault 滚动轴承:第二阶段故障
3.3 Rolling element bearings: Stage three fault: outer race 滚动轴承:第三阶段:外滚道
3.4 Rolling element bearings: Stage three fault: inner race 滚道轴承:第三阶段:内滚道
3.5 Rolling element bearings: Stage three fault: ball damage 滚动轴承:第三阶段:滚子损伤
3.6 Rolling element bearings: Stage four fault 滚动轴承:第四阶段故障
3.7 Rolling element bearings: Cocked bearing: on shaft 滚动轴承:翘曲轴承:转轴上
3.8 Rolling element bearings: Cocked bearing: in housing 滚动轴承:翘曲轴承:轴承箱内
3.9 Rolling element bearings: Fluting EDM 滚动轴承:电蚀
3.10 Rolling element bearings: Rolling elements skidding 滚动轴承:滚子打滑
3.11 Rolling element bearings: Inner race sliding on shaft 滚动轴承:跑内圈
3.12 Rolling element bearings: Outer race loose in housing 滚动轴承:跑外圈
4 Analysis Definitions: Looseness 松动
4.1 Looseness: Rotating looseness 松动:旋转部件
4.2 Looseness: Structural looseness 松动:结构松动
4.3 Looseness: Loose pedestal bearings 松动:轴承座松动
5 Analysis Definitions: Resonance 共振
5.1 Resonance: Excited by fluting/EDM 共振:轴电流激起
5.2 Resonance: Excited by bearing skidding 共振:打滑激起
6 Bent shaft: Bent Shaft 轴弯
7 Cavitation: Pump cavitation 气蚀:泵气蚀
8 Journal bearings 滑动轴承
8.1 Journal bearings: Wear/Clearance 滑动轴承:磨损/间隙
8.2 Journal bearings: Oil whirl 滑动轴承:油膜涡动
9 Analysis Definitions: Rotor rub 转子摩擦
10 Eccentricity: Eccentricity general comments 偏心常规说明
10.1 Eccentricity: Eccentric motor rotor 偏心:电机转子偏心
10.2 Eccentricity: Eccentric motor stator 偏心:电机定子偏心
10.3 Eccentricity: Eccentric pulley or sheave 偏心:皮带轮或槽轮偏心
10.4 Eccentricity: Eccentric gear 偏心:齿轮偏心
11 Hydraulic and aerodynamic 流体
11.1 Hydraulic and aerodynamic: Blade faults 流体:叶片故障
11.2 Hydraulic and aerodynamic: Flow turbulence 流体:湍流
11.3 Hydraulic and aerodynamic: Pump cavitation 流体:泵气蚀
12 Analysis Definitions: Reciprocating machines 往复设备
13 Induction motors 异步电机
13.1 Induction motors: Type I rotor faults 异步电机:I 型转子故障
13.2 Induction motors: Type II rotor faults 异步电机:II 型转子故障
13.3 Induction motors: Stator eccentricity or soft foot 异步电机:定子偏心或软角
13.4 Induction motors: Rotor bow 异步电机:转子弓形
13.5 Induction motors: Cracked or broken rotor bars 异步电机:转子条断条
13.6 Induction motors: Loose rotor bars 异步电机:转子条松动
13.7 Induction motors: Loose rotor 异步电机:转子松动
13.8 Induction motors: Loose stator windings 异步电机:定子绕组松动
13.9 Induction motors: Shorted laminations 异步电机:铁芯短路
13.10 Induction motors: Loose connections 异步电机:接头松动
14 Synchronous motors: Loose stator coils 同步电机:定子线圈松动
15 DC motors: General fault comment 直流电机:常见故障说明
15.1 DC motors: Grounding fault 直流电机:接地故障
15.2 DC motors: SCR Tuning faults 直流电机:SCR 调频故障
15.3 DC motors: Phase loss 直流电机:缺相
15.4 DC motors: Loose connectors, shorted control card and more 直流电机:接头松动,控制卡短
15.5 DC motors: DC motor hunting 直流电机速度偏差
16 Gearbox: Gear mesh 齿轮:啮合频率
16.1 Gearbox: Tooth wear 齿轮:齿轮磨损
16.2 Gearbox: Tooth load 齿轮:齿轮过载
16.3 Gearbox: Eccentric gears 齿轮:偏心齿
16.4 Gearbox: Misaligned gears 齿轮:齿轮不对中
16.5 Gearbox: Gear backlash 齿轮:齿轮游隙
16.6 Gearbox: Cracked or broken tooth 齿轮:断齿
16.7 Gearbox: Hunting tooth frequency 齿轮:追逐齿频率
17 Couplings 联轴器
17.1 Couplings: Coupling unbalance 联轴器:联轴器不平衡
17.2 Couplings: Non-parallel coupling faces 联轴器:非平行面
17.3 Couplings: Coupling wear 联轴器:联轴器磨损
17.4 Couplings: Misaligned 3-jaw coupling 联轴器:3 爪联轴器不对中
17.5 Couplings: Locked gearflex coupling 联轴器:齿式联轴器卡住
18 Belt drives 带传动
18.1 Belt drives: Worn belts 带传动:皮带磨损
18.2 Belt drives: Sheave misalignment 带传动:槽轮不对中
18.3 Belt drives: Belt resonance 带传动:皮带共振
19 Things you should know
19.1 Things you should know: Warning 警告
19.2 Things you should know: Data Analysis 数据分析
19.3 Things you should know: Useful facts 有用信息
19.4 Things you should know: Spectral Ski-slope 滑雪坡
19.5 Things you should know: Raised noise floor 底部噪声抬起
19.6 Things you should know: External noise 外部噪声
中文来源:33cm.net
英文原文:http://www.mobiusinstitute.com/site2/item.asp?LinkID=2001
译者:王红星
校核:宗棠
vibration analysis.pdf
3.67 MB, 下载次数: 900
发表于 2016-6-5 11:58 来自手机 | 显示全部楼层
:感谢
发表于 2016-7-16 09:11 | 显示全部楼层
感謝分享
发表于 2016-7-18 22:18 来自手机 | 显示全部楼层
谢谢红星的辛苦翻译!下载的人挺多,回复的很少,嗨,伸手党太多,感恩心态太少了
发表于 2016-7-19 08:47 | 显示全部楼层
辛苦辛苦呀
发表于 2016-7-19 09:20 | 显示全部楼层
感谢红星!
发表于 2016-7-20 20:49 | 显示全部楼层
发表于 2016-7-21 10:13 | 显示全部楼层
谢谢
发表于 2016-7-21 13:44 | 显示全部楼层
感恩一下  谢谢  谢谢
发表于 2016-7-21 16:32 | 显示全部楼层
感谢,学习中。。。。
发表于 2016-7-22 09:37 | 显示全部楼层
谢谢
发表于 2016-7-25 09:28 | 显示全部楼层
感谢整理
发表于 2016-7-26 10:26 | 显示全部楼层
lz辛苦啦
发表于 2016-8-2 09:11 | 显示全部楼层
感谢分享,谢谢红星兄!
发表于 2016-8-3 13:21 | 显示全部楼层
感谢前辈分享
GMT+8, 2024-12-27 21:14 , Processed in 0.124286 second(s), 26 queries , Gzip On.
