查看: 3126|回复: 6
[Patran专区] 怎么求解循环对称结构的模态啊?要求考虑转速载荷。
发表于 2006-5-24 22:16 | 显示全部楼层 |阅读模式
  如题,我找了许久,就是找不到,哪位大侠给我讲讲,最好发个算例。 我的email:lfchnuaa@163.com。先谢了。
 楼主| 发表于 2006-5-25 18:33 | 显示全部楼层
  怎么没人回答啊??/很难吗??自己先顶一下!!!
发表于 2006-5-29 13:51 | 显示全部楼层
回复:(aaaa123abc)怎么求解循环对称结构的模态啊?...
  (循环对称结构模态计算及结果察看)
  Product Line: MSC.Patran Product Name: MSC.PATRAN Customization/Other (0501)
  Product Version: 9 Product Feature: Utilities/Shareware Menu
  Article Type: FAQ Publish: Y
  Extended Description Problem Summary:
  A few hints for using rotational cyclic symmetry in a normal mode analysis with patran-nastran (SOL 115):
  - Define the cyclic symmetry in patran via:
  - Create a cylindrical system where the z-axis is the axis of symmetry.
  Let's call it Coord 1.
  - Define the cyclic symmetry:
  Finite elements - Create - Mpc - Cyclic Symmetry
  Connect the independent nodes on one side of the segment to dependent nodes which are revolved around the z-axis over an angle of 360/N, where N is the number of segments.
  The dependent nodes need not be part of the segment. They do not even need to be attached to elements. They are just used to define the number of segments in the model .
  In most situations the dependent nodes are also part of the segment when the segment exactly represents a "piece of cake".
  Note that here the Mpc has nothing to do with a rigid element, but is only used to define the cyclic symmetry in the nastran input deck.
  The Mpc results in a CYSYM,N,ROT entry and two CYJOIN entries in the nastran input deck, one for side 1; the independent nodes and one for side two; the dependent nodes.
  If a node lies exactly on the z-axis, choose it both as dependent and as independent.
  This results in one CYAX entry.
  Make sure that the independent nodes have lower theta angle than the dependent nodes,t.i. nastran will create the new segments using the right hand rule by rotating around the z-axis in positive direction.
  - In order to use the patran cyclic symmetry utility (see below), make sure all the nodes are defined in this cylindrical system, otherwise the in-plane eigenvectors are wrong!
  Finite Elements - Modify - Node - Edit: Analysis Coord system = Coord 1 -
  Reference Coord System = Coord 1
  - Analysis - solution type - normal modes - solution parameters - enable: cyclic symmetry
  - write out a nastran input deck
  - in the nastran input deck add above the subcase:
  HARMONICS = ALL
  NOUTPUT = ALL
  and change:
  VECTOR(SORT1,REAL) = ALL
  in
  VECTOR(SORT1,REAL,PUNCH) = ALL
  - For post-processing in patran:
  Utilities - Results - MSC/N Cyclic Symmetry Tool
  Select your punch file - select a group - and select the coordinate system used to define the mpc's - apply
  Your modes will be extended to your whole model subdivided in harmonics.
  The number of harmonics will be N/2 where N is the number of segments. If N is an odd number N/2 will be rounded off to the lower integer.
  (If you had defined independent and dependent in the wrong way, the results can look discontinous as the utility creates the model by rotating in positive direction around the z-axis while nastran used the negative direction in that case).
  If you still notice discontinuous results over the segments, it is probably caused by the fact that some nodes are still defined in the global system. The utility simple reads the eigenvectors from the punch file. Eigenvectors are defined in the coordinate system of the grid point.
  Furthermore, the punch file represents the vectors with respect to segment 1. So they are not rotated over an angle (360 /N) * (i-1) for segment i. That means the magnitude of the vector is correct but not its direction. So a fringe plot in patran of the displacement is correct but a deformation plot is very likely not correct for the in plane components.
  The z-component is correct. A solution is to define all your nodes in Coord 1, then the eigenvectors are expressed in Coord 1 which is a cylindrical system. Now the nastran representation of the modes on segment 1 is the same for all segments as the coordinates are cylindrical.
 楼主| 发表于 2006-5-30 18:52 | 显示全部楼层
  先谢了, 但是这样求解好像没有考虑 离心力载荷啊?比如说有转速的循环对称结构。有转速又该怎么求解呢???
发表于 2006-6-2 09:58 | 显示全部楼层
  在拉格朗日坐标系下不能考虑旋转。
  如果非想做的话可以在旋转部件内插入一个刚体
  想要算例吗?
 楼主| 发表于 2006-6-2 22:42 | 显示全部楼层
回复:(zhangmeng)在拉格朗日坐标系下不能考虑旋转。...
能给我个算例啊,那多谢了。我的email:lfchnuaa@163.com
发表于 2006-9-23 23:01 | 显示全部楼层
原帖由 aaaa123abc 于 2006-5-24 22:16 发表
如题,我找了许久,就是找不到,哪位大侠给我讲讲,最好发个算例。 我的email:lfchnuaa@163.com。先谢了。<BR>
建议找一些转子系统动力学之类的书看看。转子系统的模态分析要考虑转子转动时的陀螺效应。
GMT+8, 2025-1-8 01:25 , Processed in 0.057958 second(s), 17 queries , Gzip On.
