查看: 1948|回复: 0
[滤波] 关于升余弦滤波器应用的一个小例子
发表于 2016-5-10 09:00 | 显示全部楼层 |阅读模式
  1. clc
  2. clear all
  3. close all hidden
  4. M = 4;                   % The order for modulate of DPSK
  5. nPacket = 5000;           % The signal length
  6. x = randint(nPacket,1,M); % Signal for modulate
  7. h = modem.dpskmod('M',M);      % Creat an object of DPSK modulation
  8. y = modulate(h,x);        % modulate x get y
  9. scatterplot(y);
  10. %% Process raised cosine filter pulse shaping
  11. Nsamp = 4;               % Oversampling rate
  12. num = rcosine(1,4);
  13. ypulse = rcosflt(y,1,4);
  14. ynoisy = awgn(ypulse,15,'measured');
  15. ynoisy = ynoisy(3/1*4+1:end-3/1*4);
  16. ydownsamp = downsample(ynoisy,Nsamp);
  17. scatterplot(ydownsamp);
  18. reset(h);
  19. h = modem.dpskdemod('M',M);
  20. z = demodulate(h,ydownsamp);
  21. [num,rt]= symerr(x,z)
这里需要注意的是rcosin的参数设置问题,第一个参数是码速率fd,第二个参数采样频率fs,默认的滚降系数是0.5,那么滤波器的时延可以delay=3/fd×fs,这样在降采样之前需要对数据进行处理,去除时延ynoisy = ynoisy(3/1*4+1:end-3/1*4);然进行降采样处理。
希望能对需要的朋友有点参考价值!
滤波器的时延可以用
转自:http://blog.sina.com.cn/s/blog_5def5a660100mhru.html
GMT+8, 2024-12-29 02:55 , Processed in 0.070406 second(s), 19 queries , Gzip On.
