查看: 2025|回复: 0
[编程技巧] Matlab 线性拟合 & 非线性拟合
发表于 2016-5-4 10:13 | 显示全部楼层 |阅读模式
fittype
Fit type for curve and surface fitting
Syntax
  1. <font color="#000000">ffun = fittype(libname)
  2. ffun = fittype(expr)
  3. ffun = fittype({expr1,...,exprn})
  4. ffun = fittype(expr, Name, Value,...)
  5. ffun= fittype({expr1,...,exprn}, Name, Value,...)</font>
线性拟合公式:
coeff1 * term1 + coeff2 * term2 + coeff3 * term3 + ...其中,coefficient是系数,term都是x的一次项。
线性拟合Example:
Example1: y=kx+b;
法1:
  1. <font color="#000000">[csharp] view plaincopyprint?
  2. x=[1,1.5,2,2.5,3];y=[0.9,1.7,2.2,2.6,3];
  3. p=polyfit(x,y,1);
  4. x1=linspace(min(x),max(x));
  5. y1=polyval(p,x1);
  6. plot(x,y,'*',x1,y1); </font>
结果:p =    1.0200    0.0400
即y=1.0200 *x+ 0.0400
  1. <font color="#000000">法2:
  2. [csharp] view plaincopyprint?
  3. x=[1;1.5;2;2.5;3];y=[0.9;1.7;2.2;2.6;3];
  4. p=fittype('poly1')
  5. f=fit(x,y,p)
  6. plot(f,x,y);
  7. 运行结果:
  8. [csharp] view plaincopyprint?
  9. x=[1;1.5;2;2.5;3];y=[0.9;1.7;2.2;2.6;3];
  10. p=fittype('poly1')
  11. f=fit(x,y,p)
  12. plot(f,x,y);
  13.
  14. p =
  15.
  16.      Linear model Poly1:
  17.      p(p1,p2,x) = p1*x + p2
  18.
  19. f =
  20.
  21.      Linear model Poly1:
  22.      f(x) = p1*x + p2
  23.      Coefficients (with 95% confidence bounds):
  24.        p1 =        1.02  (0.7192, 1.321)
  25.        p2 =        0.04  (-0.5981, 0.6781)  </font>
  1. <font color="#000000">Example2:y=a*x + b*sin(x) + c
  2. 法1:
  3. [csharp] view plaincopyprint?
  4. x=[1;1.5;2;2.5;3];y=[0.9;1.7;2.2;2.6;3];
  5. EXPR = {'x','sin(x)','1'};
  6. p=fittype(EXPR)
  7. f=fit(x,y,p)
  8. plot(f,x,y);
  9. 运行结果:
  10. [csharp] view plaincopyprint?
  11. x=[1;1.5;2;2.5;3];y=[0.9;1.7;2.2;2.6;3];
  12. EXPR = {'x','sin(x)','1'};
  13. p=fittype(EXPR)
  14. f=fit(x,y,p)
  15. plot(f,x,y);
  16.
  17. p =
  18.
  19.      Linear model:
  20.      p(a,b,c,x) = a*x + b*sin(x) + c
  21.
  22. f =
  23.
  24.      Linear model:
  25.      f(x) = a*x + b*sin(x) + c
  26.      Coefficients (with 95% confidence bounds):
  27.        a =       1.249  (0.9856, 1.512)
  28.        b =      0.6357  (0.03185, 1.24)
  29.        c =     -0.8611  (-1.773, 0.05094)
  30. 法2:
  31. [csharp] view plaincopyprint?
  32. x=[1;1.5;2;2.5;3];y=[0.9;1.7;2.2;2.6;3];
  33. p=fittype('a*x+b*sin(x)+c','independent','x')
  34. f=fit(x,y,p)
  35. plot(f,x,y);
  36. 运行结果:
  37. [csharp] view plaincopyprint?
  38. x=[1;1.5;2;2.5;3];y=[0.9;1.7;2.2;2.6;3];
  39. p=fittype('a*x+b*sin(x)+c','independent','x')
  40. f=fit(x,y,p)
  41. plot(f,x,y);
  42.
  43. p =
  44.
  45.      General model:
  46.      p(a,b,c,x) = a*x+b*sin(x)+c
  47. Warning: Start point not provided, choosing random start
  48. point.
  49. > In fit>iCreateWarningFunction/nThrowWarning at 738
  50.   In fit>iFit at 320
  51.   In fit at 109
  52.
  53. f =
  54.
  55.      General model:
  56.      f(x) = a*x+b*sin(x)+c
  57.      Coefficients (with 95% confidence bounds):
  58.        a =       1.249  (0.9856, 1.512)
  59.        b =      0.6357  (0.03185, 1.24)
  60.        c =     -0.8611  (-1.773, 0.05094)  </font>
  1. <font color="#000000">Example:y=a*x^2+b*x+c
  2. 法1:
  3. [cpp] view plaincopyprint?
  5. p=fittype('a*x.^2+b*x+c','independent','x')
  6. f=fit(x,y,p)
  7. plot(f,x,y);
  8. 运行结果:
  9. [csharp] view plaincopyprint?
  10. p =
  11.
  12.      General model:
  13.      p(a,b,c,x) = a*x.^2+b*x+c
  14. Warning: Start point not provided, choosing random start
  15. point.
  16. > In fit>iCreateWarningFunction/nThrowWarning at 738
  17.   In fit>iFit at 320
  18.   In fit at 109
  19.
  20. f =
  21.
  22.      General model:
  23.      f(x) = a*x.^2+b*x+c
  24.      Coefficients (with 95% confidence bounds):
  25.        a =     -0.2571  (-0.5681, 0.05386)
  26.        b =       2.049  (0.791, 3.306)
  27.        c =       -0.86  (-2.016, 0.2964)  </font>
  4. %use c=0;
  5. c=0;
  6. p1=fittype(@(a,b,x) a*x.^2+b*x+c)
  7. f1=fit(x,y,p1)
  8. %use c=1;
  9. c=1;
  10. p2=fittype(@(a,b,x) a*x.^2+b*x+c)
  11. f2=fit(x,y,p2)
  12. %predict c
  13. p3=fittype(@(a,b,c,x) a*x.^2+b*x+c)
  14. f3=fit(x,y,p3)
  15.
  16. %show results
  17. scatter(x,y);%scatter point
  18. c1=plot(f1,'b:*');%blue
  19. hold on
  20. plot(f2,'g:+');%green
  21. hold on
  22. plot(f3,'m:*');%purple
  23. hold off  </font>
GMT+8, 2024-12-28 14:24 , Processed in 0.095997 second(s), 21 queries , Gzip On.
