查看: 2600|回复: 0
[经典算法] [求助]delphi编程 高斯积分算法
发表于 2006-5-23 19:13 | 显示全部楼层 |阅读模式
有一积分编不出来,想请教大家,第一页 倒数第五行,I(n,b,+)的计算。<BR>其中u, yD, e, s, hD, zwD,角度Φ看作是常数,K0是Bessel 函数。<BR><V:SHAPETYPE><V:STROKE joinstyle="miter"></V:STROKE><V:FORMULAS><V:F eqn="if lineDrawn pixelLineWidth 0"></V:F><V:F eqn="sum @0 1 0"></V:F><V:F eqn="sum 0 0 @1"></V:F><V:F eqn="prod @2 1 2"></V:F><V:F eqn="prod @3 21600 pixelWidth"></V:F><V:F eqn="prod @3 21600 pixelHeight"></V:F><V:F eqn="sum @0 0 1"></V:F><V:F eqn="prod @6 1 2"></V:F><V:F eqn="prod @7 21600 pixelWidth"></V:F><V:F eqn="sum @8 21600 0"></V:F><V:F eqn="prod @7 21600 pixelHeight"></V:F><V:F eqn="sum @10 21600 0"></V:F></V:FORMULAS><V:PATH gradientshapeok="t" extrusionok="f" connecttype="rect"></V:PATH><LOCK aspectratio="t" v:ext="edit"></LOCK></V:SHAPETYPE><V:SHAPETYPE><V:STROKE joinstyle="miter"></V:STROKE><V:FORMULAS><V:F eqn="if lineDrawn pixelLineWidth 0"></V:F><V:F eqn="sum @0 1 0"></V:F><V:F eqn="sum 0 0 @1"></V:F><V:F eqn="prod @2 1 2"></V:F><V:F eqn="prod @3 21600 pixelWidth"></V:F><V:F eqn="prod @3 21600 pixelHeight"></V:F><V:F eqn="sum @0 0 1"></V:F><V:F eqn="prod @6 1 2"></V:F><V:F eqn="prod @7 21600 pixelWidth"></V:F><V:F eqn="sum @8 21600 0"></V:F><V:F eqn="prod @7 21600 pixelHeight"></V:F><V:F eqn="sum @10 21600 0"></V:F></V:FORMULAS><V:PATH gradientshapeok="t" extrusionok="f" connecttype="rect"></V:PATH><LOCK aspectratio="t" v:ext="edit"></LOCK></V:SHAPETYPE>
GMT+8, 2025-1-8 01:45 , Processed in 0.068854 second(s), 20 queries , Gzip On.
