查看: 2169|回复: 0
[ABAQUS应用] 一个inp文件中调用多个mat的方法
发表于 2016-4-5 10:21 | 显示全部楼层 |阅读模式
  在ABAUQS帮助文档UMAT或VUMAT中提到可以同时调用不同材料模型:
  1.   IF (CMNAME(1:4) .EQ. 'MAT1') THEN
  2.   CALL UMAT_MAT1(argument_list) .or. CALL VUMAT_MAT1(argument_list)
  3.   ELSE IF(CMNAME(1:4) .EQ. 'MAT2') THEN
  4.   CALL UMAT_MAT2(argument_list) .or. CALL VUMAT_MAT2(argument_list)
  5.   END IF
  这里以VUMAT为例,
  subroutine vumat(
  C Read only -
  1.   1 nblock, ndir, nshr, nstatev, nfieldv, nprops, lanneal,
  2.   2 stepTime, totalTime, dt, cmname, coordMp, charLength,
  3.   3 props, density, strainInc, relSpinInc,
  4.   4 tempOld, stretchOld, defgradOld, fieldOld,
  5.   3 stressOld, stateOld, enerInternOld, enerInelasOld,
  6.   6 tempNew, stretchNew, defgradNew, fieldNew,
  7.   C Write only -
  8.   5 stressNew, stateNew, enerInternNew, enerInelasNew )
  9.   C
  10.   include 'vaba_param.inc'
  11.   dimension props(nprops), density(nblock),
  12.   1 coordMp(nblock,*),
  13.   2 charLength(*), strainInc(nblock,ndir+nshr),
  14.   3 relSpinInc(*), tempOld(*),
  15.   4 stretchOld(*), defgradOld(*),
  16.   5 fieldOld(*), stressOld(nblock,ndir+nshr),
  17.   6 stateOld(nblock,nstatev), enerInternOld(nblock),
  18.   7 enerInelasOld(nblock), tempNew(*),
  19.   8 stretchNew(*), defgradNew(*), fieldNew(*),
  20.   9 stressNew(nblock,ndir+nshr), stateNew(nblock,nstatev),
  21.   1 enerInternNew(nblock), enerInelasNew(nblock),
  22.   2 ustran(2),ustress(2),udstran(2),uddsdde(2,2)
  23.   C
  24.   character*80 cmname
  25.   if (cmname(1:4) .eq. 'MAT1') then
  26.   call VUMAT_mat1(
  27.   C Read only -
  28.   1 nblock, ndir, nshr, nstatev, nfieldv, nprops, lanneal,
  29.   2 stepTime, totalTime, dt, cmname, coordMp, charLength,
  30.   3 props, density, strainInc, relSpinInc,
  31.   4 tempOld, stretchOld, defgradOld, fieldOld,
  32.   3 stressOld, stateOld, enerInternOld, enerInelasOld,
  33.   6 tempNew, stretchNew, defgradNew, fieldNew,
  34.   C Write only -
  35.   5 stressNew, stateNew, enerInternNew, enerInelasNew )
  36.   else if (cmname(1:4) .eq. 'MAT2') then
  37.   call VUMAT_mat2(
  38.   C Read only -
  39.   1 nblock, ndir, nshr, nstatev, nfieldv, nprops, lanneal,
  40.   2 stepTime, totalTime, dt, cmname, coordMp, charLength,
  41.   3 props, density, strainInc, relSpinInc,
  42.   4 tempOld, stretchOld, defgradOld, fieldOld,
  43.   3 stressOld, stateOld, enerInternOld, enerInelasOld,
  44.   6 tempNew, stretchNew, defgradNew, fieldNew,
  45.   C Write only -
  46.   5 stressNew, stateNew, enerInternNew, enerInelasNew )
  47.   end if
  48.   !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  49.   RETURN
  50.   END
  其他就是将MAT1和MAT2复制在这后面就可以了。
  注意: “if (cmname(1:4) .eq. 'MAT1') then”中MAT1必须是大写的,如果是小写,将在子程序运行中出现:
  ERROR:BAD MATERIAL DEFINITION。
转自:http://blog.sina.com.cn/s/blog_642b4b710100ibdd.html
GMT+8, 2024-12-28 12:31 , Processed in 0.075030 second(s), 17 queries , Gzip On.
