查看: 1509|回复: 0
[综合讨论] matlab启动时出现pathdef.m not found错误
发表于 2015-10-28 07:10 | 显示全部楼层 |阅读模式
Warning: D:\Program Files\MATLAB\R2012a\toolbox\local\pathdef.m not found.
Toolbox Path Cache is not being used. Type 'help toolbox_path_cache' for more
info
Undefined function or variable 'ispc'.
Warning: MATLAB did not appear to successfully set the search path. To recover
for this session of MATLAB, type "restoredefaultpath;matlabrc". To find out how
to avoid this warning the next time you start MATLAB, type "docsearch problem
path" after recovering for this session.
Warning: Duplicate directory name: D:\MATLAB2010b\toolbox\local.
Warning: Initializing Handle Graphics failed in matlabrc.
This indicates a potentially serious problem in your MATLAB setup,
which should be resolved as soon as possible.  Error detected was:
MATLAB:UndefinedFunction
Undefined function or method 'colordef' for input arguments of type 'double'.
> In matlabrc at 100
Warning: Initializing Java preferences failed in matlabrc.
Undefined function or method 'usejava' for input arguments of type 'char'.
> In matlabrc at 123
Warning: Failed to add default profiler filters.
> In matlabrc at 179
GMT+8, 2024-12-28 14:37 , Processed in 0.080438 second(s), 17 queries , Gzip On.
