查看: 1132|回复: 2
如何在popupmenu下的不同选项中调用不同的图像
发表于 2006-5-18 11:08 | 显示全部楼层 |阅读模式
<P>请教:<br>如何在popupmenu下的不同选项中调用不同的图像??</P>
[此贴子已经被suffer于2006-5-18 11:09:37编辑过]
发表于 2006-5-18 11:14 | 显示全部楼层
回复:(zbf)如何在popupmenu下的不同选项中调用不同...
<P>通过callback设置调用不同的图片文件</P>
 楼主| 发表于 2006-5-18 11:46 | 显示全部楼层
这样写哪错了???
clf reset             %      &lt;1&gt;<br>set(gcf,'unit','normalized','position',[0.1,0.4,0.85,0.35]);%<br>set(gcf,'defaultuicontrolunits','normalized');<br>set(gcf,'defaultuicontrolfontsize',11);<br>set(gcf,'defaultuicontrolfontname','隶书');<br>set(gcf,'defaultuicontrolhorizontal','left');<br>       %<br>str='Data reconciliation';<br>set(gcf,'name',str,'numbertitle','off'); <br>hpop=uicontrol(gcf,'style','popup',...    %  &lt;17&gt;<br>   'position',[0.8,0.73,0.18,0.12],...<br>   'string','图1|图2');% <br>set(hpop,'callback','Mycolormap(hpop)'); %&lt;27&gt;<br>[Mycolormap.m]<br>function Mycolormap(hpop)<br>global hpop<br>popstr={'图1','图2'};  %弹出框色图矩阵<br>vpop=get(findobj(gcf,'Tag','PopupMenu1'),'value'); %获得选项的位置标识<br>h1(eval(popstr{vpop}))       %采用弹出框所选色图<br>function h1(vpop)<br>switch vpop<br>    case '图1',set(hpop,'callback','tu1');<br>    otherwise '图2', set(hpop,'callback','tu2');<br>end<br><br>Function 'eval' is not defined for values of class 'double'.<br>Error while evaluating uicontrol Callback.<br>怎么改呀?
[此贴子已经被作者于2006-5-18 11:58:05编辑过]
GMT+8, 2025-1-30 22:18 , Processed in 0.081774 second(s), 17 queries , Gzip On.
