查看: 984|回复: 1
[综合讨论] 关于CYL4命令流的含义
发表于 2015-9-21 08:47 | 显示全部楼层 |阅读模式
  1. CYL4,-2,-2,1,,,,21
命令流中这句话代码是什么含义?
发表于 2015-9-21 10:32 | 显示全部楼层
Cyl4这是定义圆柱命令
Cyl4,xcenter,ycenter,rad1,theta1,rad2,theta2,depth
建立一个圆柱体。
XCENTER,YCENTER:以工作平面中的x、y坐标为圆柱体的中心点
rad1,rad2:为圆柱的内外半径
theat1,theta2:为圆柱的起始、终结角度。
菜单路径
Main Menu>Preprocessor>Modeling>Create>Areas>Circle>Annulus
Main Menu>Preprocessor>Modeling>Create>Areas>Circle>Partial Annulus
Main Menu>Preprocessor>Modeling>Create>Areas>Circle>Solid Circle
Main Menu>Preprocessor>Modeling>Create>Primitives>Solid Cylindr
Main Menu>Preprocessor>Modeling>Create>Volumes>Cylinder>Hollow Cylinder
Main Menu>Preprocessor>Modeling>Create>Volumes>Cylinder>Partial Cylinder
Main Menu>Preprocessor>Modeling>Create>Volumes>Cylinder>Solid Cylinder
Main Menu>Preprocessor>Trefftz Domain>TZ Geometry>Create>Volume>Cylinder>Solid Cylinder
GMT+8, 2025-1-29 12:53 , Processed in 0.120144 second(s), 17 queries , Gzip On.
