查看: 2039|回复: 4
[Virtual.Lab] 求助:关于时域声学有限元定义压力边界条件的问题
发表于 2015-9-17 09:11 | 显示全部楼层 |阅读模式
阿伟版主的教材中,列举了两个时域有限元的算例,两个算例全是加速度边界条件,而有些工况下需要定义的是压力边界条件。类似加速度边界条件的定义方式,我定义了压力边界条件,但计算出错,错误信息如下:SYSNOISE ANALYSIS OPTION :
      FEM VARIATIONAL TIME FLUID
SYSNOISE SUMMARY INFORMATION
Title...Exported VLModel
Date....16-SEP-2015 16:11:25
Number of dimensions......................      3
Number of nodes...........................  41142
Number of elements........................  20267
Number of material characteristics........      1
Number of load cases......................      1
Number of nodes with pressure B.C.'s......      1
Number of nodes with an initial condition.  41142
SYSNOISE>  SCL> Option FEM Time Fluid Return
SYSNOISE>  SCL> Environment Section SETUP BELL 'on' Return
SYSNOISE>  SCL> Environment Section SETUP SOLVITER 0 Return
SYSNOISE>  SCL> Environment Section SETUP STABLEFEM TRUE Return
SYSNOISE>  SCL> Environment Section SETUP GEO_TOLERANCE '1E-006' Return
SYSNOISE>  SCL> Parameter Model 1  Physical
PARAMETER>  SCL>   Save Potentials Step 1
PARAMETER>  SCL>   Save Results none
PARAMETER>
PARAMETER>  SCL>   Newmark 0.25 0.5
PARAMETER>  SCL> Return
Updating Model Parameters
SYSNOISE>  SCL> Case 1 Return
CURRENT LOAD CASE         1
Load Case #         1 Name: Case 1
SAVING LOAD CASE         1
SYSNOISE>  SCL> Solve
SOLVE>  SCL> Time 0 To 1 LinStep 0.1
SOLVE>  SCL> Return
TIME RESPONSE MODULE
FOR   11 TIME STEPS FROM     0.000000 TO     1.000000
SOLVE PARAMETERS
MODEL:   1 - Exported VLModel
    PHYSICAL Coordinates
    Saving POTENTIALS every        1 steps
    No saving of RESULTS
    Energy Calculation Enabled
    Surface post-processing on positive side
    NEWMARK Time Integration Parameters:
           ALPHA =    0.250
           DELTA =    0.500
LAUNCHING UNCOUPLED ACOUSTIC FEM (Physical Coords - Time) ANALYSIS
Computing MASS and STIFFNESS elements matrices
using HIGH PRECISION STABILIZED scheme for linear elements
CPU Stats --- Delta:  0:00:01 (      1.32)  Total:  0:00:01 (      1.32)
Computing VELOCITY matrices on elements faces
CPU Stats --- Delta:  0:00:00 (      0.47)  Total:  0:00:02 (      1.79)
NEWMARK TIME INTEGRATION PARAMETERS:
           ALPHA =    0.250
           DELTA =    0.500
NEWMARK PARAMETERS OK
Reverse Cuthill McKee Ordering :
    Old maximum bandwidth:        40737
    New maximum bandwidth:          447
Applying nodal fixed pressure values
Occupied space:             28 Mb  (  0.09 %)
Building the matrix of coefficients
Building the damping matrix
ANALYSIS NUMBER      1 /     11                      TIME =     0.000000
CPU Stats --- Delta:  0:00:01 (      0.71)  Total:  0:00:03 (      2.50)
Generating load vector
SAVING POTENTIALS    INTO DATABASE
Initializing skyline matrix
NOT ENOUGH CORE FOR THE STORAGE OF ONE BLOCK OF THE SPARSE MATRIX
    Available : -203317434 words (R8 or C*16)
    Required  :   12183866 words
NOT ENOUGH CORE FOR FACTORIZATION : ADD   48735464 MORE WORDS
CPU Stats --- Delta:  0:00:00 (      0.04)  Total:  0:00:03 (      2.54)
  SYSNOISE>  SCL> Close Return
麻烦各位大神不吝赐教,谢谢!
发表于 2015-9-18 08:16 | 显示全部楼层
案例26:LMS Virtual.Lab 在结构上施加压力载荷
http://forum.vibunion.com/forum. ... &fromuid=152190
(出处: 声振论坛)
 楼主| 发表于 2015-9-18 16:06 | 显示全部楼层
http://forum.vibunion.com/forum.php?mod=viewthread&tid ...
冯博士您好,我现在想在时域有限元的声学网格上添加声压条件,跟结构网格的施加好像有些不同,我是按照阿伟版主的书上加速度边界条件定义方法进行的定义,在计算的时候没有错误,但其实没算,在计算的过程信息中才看到下面的错误:
问题还是没找到,不知道是参数设置的问题还是定义的条件不对
发表于 2015-9-26 10:56 | 显示全部楼层
msMySelf 发表于 2015-9-18 16:06
冯博士您好,我现在想在时域有限元的声学网格上添加声压条件,跟结构网格的施加好像有些不同,我是按照阿 ...
not enough core,未必是加边界条件的原因,你试试加其他边界看能不能算
 楼主| 发表于 2015-9-27 21:02 | 显示全部楼层
首先感谢冯博士!这里定义边界条件的时候只有两种,一种是加速度,另一种就是声压,定义加速度的时候是没有任何问题的!只要定义声压的话就会报这个错误!
GMT+8, 2025-1-10 17:01 , Processed in 0.065475 second(s), 21 queries , Gzip On.
