查看: 2665|回复: 6
[Virtual.Lab] 将icem网格导入virtual. lab后网格检测总有一些网格老出错误
发表于 2015-4-25 10:33 | 显示全部楼层 |阅读模式
将icem网格导入virtual. lab后计算模态,老出错误。在计算前先用lms structural solver监测网格,发现一些网格质量很差,在severity中显示error.我在icem中网格质量已经调的很高了(非结构化网格quality达到了0.3),应该在icem中的质量达到怎样的质量到virtual lab中才不出错?求指导,难道要在virtual lab中用自己的网格工具划分网格?
发表于 2015-4-25 16:22 | 显示全部楼层
你是算结构模态还是什么?把计算日志放上来看看。
 楼主| 发表于 2015-4-26 14:32 | 显示全部楼层
主任我先计算的结构模态,然后计算强迫振动的。计算日志如下:
=====> START "C:\temp\lms_linear_modal_structural_solution_set_3 LISTING;SHOWCPU;KEEPDIALOG"
@@@CSH:SMGINI: BACON
@@@CSH:SMGSTG: 1 / 9
@@@CSH:SMGVANBEG: 1 / 9 : Reading Data File
@@@CSH:SMGVFRBEG: 1 / 9 : Lecture des Donnees
Running BACON with lms_linear_modal_structural_solution_set_3
User requested workspace            87500000 words  (   700 MBytes)
Memory allocation / DB              43750000 /    43750000 words
Release : 15.1-02  - Date : 15-May-2013 (SHORT INTEGERS)
Graphic driver used: Windows
Input 1>!
Input 1>!                    =====================================
Input 1>!                    Programme   <BACON> : Version 15.1-02
Input 1>!
Input 1>!
Input 1>MODE M 1
Spy file :  9 - "C:\temp\lms_linear_modal_structural_solution_set_3.spy"
Input 1>INPUT INIT
Input 1>EXIT
Diagnostics file : 87 - "C:\temp\lms_linear_modal_structural_solution_set_3.dia"
  Current accuracy =  1.28683496E-01
Samcef File (Binary) :  3 - "C:\temp\lms_linear_modal_structural_solution_set_3.sam"
      SAMCEF FILE CREATION
    NR  DATA TYPE            OBJECT NAME   RECORDS
     1  TITLE
     2  NODES-.NOE            (.NOE)     244406
     3  ELEMENT-.MAI          (.MAI)    1253406
     4  HYPOTHESIS            (.HYP)    1253406
     5  FIXATIONS             (.CLM)        614
      DB FILE CREATION
Saving the auxiliary memory in the DB ...
Saving the rotation matrix in the DB ...
Saving the ABREviations in the DB ...
Saving the release flag in the DB ...
Writing the DB on a binary file ...
DB File     : "C:\temp\lms_linear_modal_structural_solution_set_3.sdb"
File size statistics
File name                                                            Size
D... \LMS\LMS Virtual.Lab 12\VirtualLab\Samcef\bin\pilote.dat      161501 Bytes
C:\temp\lms_linear_modal_structural_solution_set_3_ba.w02           34403 Bytes
C:\temp\lms_linear_modal_structural_solution_set_3.sam          220155680 Bytes
C:\temp\lms_linear_modal_structural_solution_set_3.spy                268 Bytes
C:\temp\lms_linear_modal_structural_solution_set_3.dat           87876659 Bytes
C:\temp\lms_linear_modal_structural_solution_set_3.sdb          346502504 Bytes
C:\temp\lms_linear_modal_structural_solution_set_3.dia                 30 Bytes
D:\Program Files\LMS\LMS Virtual.Lab 12\VirtualLab\Samcef/...      397973 Bytes
D:\Program Files\LMS\LMS Virtual.Lab 12\VirtualLab\Samcef/...       82619 Bytes
@@@CSH:SMGINT: PID =     6304 : Current Process ID
@@@CSH:SMGFIN: I_RUNSUCCESS
End of BACON
...TEArun_bacon Done
Running dynam with lms_linear_modal_structural_solution_set_3
@@@CSH:SMGINI: DYNAM
@@@CSH:SMGINT: PID =     7748 : Current Process ID
@@@CSH:SMGSTG:  1 /  6 : Data Analysis
@@@CSH:SMGSTG:  2 /  6 : Element Generation
@@@CSH:SMGSTG:  3 /  6 : Frontal Elimination
@@@CSH:SMGSTG:  4 /  6 : Vibration Frequency Computation
@@@CSH:SMGSTG:  5 /  6 : Vibration Modes Computation
@@@CSH:SMGSTG:  6 /  6 : Residual Vectors Computation
@@@CSH:SMGSTG:  7 /  6 : Modal Mass Computation
@@@CSH:SMGSTG:  8 /  6 : Modal Stresses Computation
@@@CSH:SMGSTG:  9 /  6 : Super-Element Generation
@@@CSH:SMGBEG:  1 /  6 : Data Analysis
@@@CSH:SMGEVO:     1 /     4 : Front Width Optimization
@@@CSH:SMGEVO:     2 /     4 : Dof Numbering
@@@CSH:SMGEVO:     3 /     4 : Substructuring
@@@CSH:SMGEVO:     4 /     4 : Resource Estimation
@@@CSH:SMGINT: NBRDDL =   731376 : Number of dof's
@@@CSH:SMGINF: Disk space report for device "C:\"
@@@CSH:SMGREA: DISKFREE =    29477.496 : Free disk space (Mb).
@@@CSH:SMGREA: DISKREQUIRED =    17553.000 : Required disk space (Mb).
@@@CSH:SMGEND: -1 /  6 : Data Analysis
@@@CSH:SMGBEG:  2 /  6 : Element Generation
@@@CSH:SMGEVO:        1 /  1253406 : Elements generated
@@@CSH:SMGEVO:    13241 /  1253406 : Elements generated
@@@CSH:SMGEVO:  1250555 /  1253406 : Elements generated
@@@CSH:SMGEVO:  1253406 /  1253406 : Elements generated
@@@CSH:SMGREA: TOTVOLUME%VOLUME = 6.877298256588E5 : Total volume.
@@@CSH:SMGREA: TOTMASS%MASS = 5.4261883244448E-3 : Total mass.
@@@CSH:SMGEND: -2 /  6 : Element Generation
@@@CSH:SMGBEG:  5 /  6 : Lanczos for sparse matrix.
@@@CSH:SMGEVO:     0 /   100 : Factorization %
@@@CSH:SMGEVO:   100 /   100 : Factorization %
@@@CSH:SMGEND: -5 /  6 : Lanczos for sparse matrix.
@@@CSH:SMGBEG:  7 /  6 : Modal Mass Computation
@@@CSH:SMGREA: FREQUENCY%FREQUENCY =  2.67069057E+00 : Frequency Nbr. 1
@@@CSH:SMGREA: FREQUENCY%FREQUENCY =  2.67189340E+00 : Frequency Nbr. 2
@@@CSH:SMGREA: FREQUENCY%FREQUENCY =  3.11270710E+01 : Frequency Nbr. 3
@@@CSH:SMGREA: FREQUENCY%FREQUENCY =  6.99350932E+02 : Frequency Nbr. 14
@@@CSH:SMGREA: FREQUENCY%FREQUENCY =  6.99801530E+02 : Frequency Nbr. 15
@@@CSH:SMGEND: -7 /  6 : Modal Mass Computation
@@@CSH:SMGBEG:  8 /  6 : Modal Stresses Computation
@@@CSH:SMGINT: NBRWRN =        0 : Number of warning(s)
@@@CSH:SMGINT: NBRERR =        0 : Number of error(s)
...TEArun_module Done
@@@CSH:SMGINI: FAC
@@@CSH:SMGVANBEG: 1 / 9 : Processing Results File
@@@CSH:SMGVFRBEG: 1 / 9 : Generation des Resultats
Running FAC with lms_linear_modal_structural_solution_set_3
Status of the DB            : "lms_linear_modal_structural_solution_set_3"
DB created by BACON for ZLF (APR 26 2015 10:35:02)
modified   by BACON for ZLF (APR 26 2015 10:35:02)
modified   by DYNAM for ZLF (APR 26 2015 10:35:52)
Release                     :   15.1- 2
DB file name                : "C:\Temp\lms_linear_modal_structural_solution_set_3.sdb"
DB size                     :       83546099 (Max=       180443999)
Memory allocated            :       43747504
Size of the garbage         :              3 (  0.00% of the DB size)
Relational level            :              0
Object counter              :        1497844
Pagination flag             :        on
Swap count                  :             16 page I/O on disk
Used pages in memory        :          13227 on           13227
Used records in swap file   :          12077 on           54651
Page alignment garbage      :           2705 (  0.00% of the DB size)
Archive length :            :              0
Archive garbage :           :              0
Archive loading endian swap :              0
    MEMORY ALLOCATION / DB:                      43747495  43747505
!  Processed Data                                               ! Code ! Type !
! "Creation date of the display file  [APR 26 2015 11:30:54]"   !   24 ! CHAR !
! "Module name  [DYNAM]"                                        !   23 ! CHAR !
! "Number of errors  [0]"                                       !   59 ! INTG !
! "Number of warnings  [0]"                                     !   60 ! INTG !
! "CPU Time (Sec.)  [2003]"                                     ! 1006 ! INTG !
! "Elapsed Time (Sec.)  [3258]"                                 ! 1007 ! INTG !
! "Elements  [1253406]"                                         !    2 ! INTG !
! "Nodes  [244406]"                                             !    1 ! INTG !
! "Nodal coordinates (X,Y,Z)"                                   !  153 ! REAL !
! "Nodal displacements (DX,DY,DZ)"                              !  163 ! REAL !
!  "Subset Nr          1"                                       !      !      !
!  "Subset Nr          2"                                       !      !      !
!  "Subset Nr          3"                                       !      !      !
!  "Subset Nr          4"                                       !      !      !
!  "Subset Nr          5"                                       !      !      !
!  "Subset Nr          6"                                       !      !      !
!  "Subset Nr          7"                                       !      !      !
!  "Subset Nr          8"                                       !      !      !
!  "Subset Nr          9"                                       !      !      !
!  "Subset Nr         10"                                       !      !      !
!  "Subset Nr         11"                                       !      !      !
!  "Subset Nr         12"                                       !      !      !
!  "Subset Nr         13"                                       !      !      !
!  "Subset Nr         14"                                       !      !      !
!  "Subset Nr         15"                                       !      !      !
!  "Subset Nr         16"                                       !      !      !
!  "Subset Nr         17"                                       !      !      !
!  "Subset Nr         18"                                       !      !      !
!  "Subset Nr         19"                                       !      !      !
!  "Subset Nr         20"                                       !      !      !
!  "Subset Nr         21"                                       !      !      !
!  "Subset Nr         22"                                       !      !      !
!  "Subset Nr         23"                                       !      !      !
!  "Subset Nr         24"                                       !      !      !
!  "Subset Nr         25"                                       !      !      !
!  "Subset Nr         26"                                       !      !      !
!  "Subset Nr         27"                                       !      !      !
!  "Subset Nr         28"                                       !      !      !
!  "Subset Nr         29"                                       !      !      !
!  "Subset Nr         30"                                       !      !      !
%%%I01- FNL006, working with temporary files
     in order to work in memory increase SAM_ZONE
     number of words to be added :   83000000
FILE=D:\Program Files\LMS\LMS Virtual.Lab 12\VirtualLab\Samcef\bin\bacon_van.mes
%%%ERROR-2304%%%
Not enough space to compute data by ply by element.
%%%ERROR-42%%%
Insufficient workspace for this problem.
Possible actions: increase the workspace and re-run BACON.
You can use the spy file (usually problem_name.spy).
Available space   : 43747495 REAL*8
Asked space       : 69072951 REAL*8
Space to be added : 25325456 REAL*8
! "Status of the FAC program"                                   !   62 !      !
File name                                                            Size
lms_linear_modal_structural_solution_set_3_dy.u18                   9507 Mbytes
lms_linear_modal_structural_solution_set_3_dy.des                   11186 Bytes
lms_linear_modal_structural_solution_set_3_dy.fac               264426880 Bytes
lms_linear_modal_structural_solution_set_3_fa.w07               220148000 Bytes
lms_linear_modal_structural_solution_set_3_fa.w10               580639392 Bytes
D... S\LMS Virtual.Lab 12\VirtualLab\Samcef\bin\bacon_van.mes      334435 Bytes
C:\Temp\lms_linear_modal_structural_solution_set_3.sdb          668218844 Bytes
C:\Temp\lms_linear_modal_structural_solution_set_3_fa.w80       319017600 Bytes
@@@CSH:SMGINI: FAC
@@@CSH:SMGINT: PID =     8120 : Current Process ID
End of FAC
...TEArun_fac Done
@@@CSH:SMGVANERR: No SAMRES run due to previous module failure
@@@CSH:SMGVFRERR: Pas d'execution SAMRES suite a un probleme lors du module precedent
=====> END (Total 13981.1 Secs)
 楼主| 发表于 2015-4-26 14:34 | 显示全部楼层
由于太多,字符数多了,日志中我把这些删了:
@@@CSH:SMGEVO:    34989 /  1253406 : Elements generated
@@@CSH:SMGEVO:    56735 /  1253406 : Elements generated
@@@CSH:SMGEVO:    78604 /  1253406 : Elements generated
@@@CSH:SMGEVO:    84137 /  1253406 : Elements generated
@@@CSH:SMGEVO:    96370 /  1253406 : Elements generated
@@@CSH:SMGEVO:   117809 /  1253406 : Elements generated
@@@CSH:SMGEVO:   139593 /  1253406 : Elements generated
@@@CSH:SMGEVO:   161409 /  1253406 : Elements generated
@@@CSH:SMGEVO:   183159 /  1253406 : Elements generated
@@@CSH:SMGEVO:   205018 /  1253406 : Elements generated
@@@CSH:SMGEVO:   226913 /  1253406 : Elements generated
@@@CSH:SMGEVO:   248330 /  1253406 : Elements generated
@@@CSH:SMGEVO:   270047 /  1253406 : Elements generated
@@@CSH:SMGEVO:   291819 /  1253406 : Elements generated
@@@CSH:SMGEVO:   312858 /  1253406 : Elements generated
@@@CSH:SMGEVO:   334673 /  1253406 : Elements generated
@@@CSH:SMGEVO:   356096 /  1253406 : Elements generated
@@@CSH:SMGEVO:   377699 /  1253406 : Elements generated
@@@CSH:SMGEVO:   399420 /  1253406 : Elements generated
@@@CSH:SMGEVO:   421156 /  1253406 : Elements generated
@@@CSH:SMGEVO:   442823 /  1253406 : Elements generated
@@@CSH:SMGEVO:   458926 /  1253406 : Elements generated
@@@CSH:SMGEVO:   474318 /  1253406 : Elements generated
@@@CSH:SMGEVO:   495593 /  1253406 : Elements generated
@@@CSH:SMGEVO:   517364 /  1253406 : Elements generated
@@@CSH:SMGEVO:   539080 /  1253406 : Elements generated
@@@CSH:SMGEVO:   560274 /  1253406 : Elements generated
@@@CSH:SMGEVO:   582058 /  1253406 : Elements generated
@@@CSH:SMGEVO:   604287 /  1253406 : Elements generated
@@@CSH:SMGEVO:   625935 /  1253406 : Elements generated
@@@CSH:SMGEVO:   636083 /  1253406 : Elements generated
@@@CSH:SMGEVO:   658734 /  1253406 : Elements generated
@@@CSH:SMGEVO:   681210 /  1253406 : Elements generated
@@@CSH:SMGEVO:   703824 /  1253406 : Elements generated
@@@CSH:SMGEVO:   726341 /  1253406 : Elements generated
@@@CSH:SMGEVO:   748936 /  1253406 : Elements generated
@@@CSH:SMGEVO:   764554 /  1253406 : Elements generated
@@@CSH:SMGEVO:   786315 /  1253406 : Elements generated
@@@CSH:SMGEVO:   808229 /  1253406 : Elements generated
@@@CSH:SMGEVO:     8 /   100 : Factorization %
@@@CSH:SMGEVO:    10 /   100 : Factorization %
@@@CSH:SMGEVO:    21 /   100 : Factorization %
@@@CSH:SMGEVO:    23 /   100 : Factorization %
@@@CSH:SMGEVO:    26 /   100 : Factorization %
@@@CSH:SMGEVO:    27 /   100 : Factorization %
@@@CSH:SMGEVO:    31 /   100 : Factorization %
@@@CSH:SMGEVO:    37 /   100 : Factorization %
@@@CSH:SMGEVO:    55 /   100 : Factorization %
@@@CSH:SMGEVO:    56 /   100 : Factorization %
@@@CSH:SMGEVO:    58 /   100 : Factorization %
@@@CSH:SMGEVO:    59 /   100 : Factorization %
@@@CSH:SMGEVO:    61 /   100 : Factorization %
@@@CSH:SMGEVO:    64 /   100 : Factorization %
@@@CSH:SMGEVO:    65 /   100 : Factorization %
@@@CSH:SMGEVO:    74 /   100 : Factorization %
@@@CSH:SMGEVO:    83 /   100 : Factorization %
@@@CSH:SMGEVO:    87 /   100 : Factorization %
@@@CSH:SMGEVO:    88 /   100 : Factorization %
@@@CSH:SMGEVO:    90 /   100 : Factorization %
@@@CSH:SMGEVO:    91 /   100 : Factorization %
@@@CSH:SMGEVO:    94 /   100 : Factorization %
@@@CSH:SMGEVO:    95 /   100 : Factorization %
@@@CSH:SMGEVO:    97 /   100 : Factorization %
@@@CSH:SMGEVO:    98 /   100 : Factorization %
@@@CSH:SMGEVO:    99 /   100 : Factorization %
@@@CSH:SMGEVO:     1 /   100 : Factorization %
 楼主| 发表于 2015-4-26 15:20 | 显示全部楼层
主任那个模型一共244406个节点,1387896个体,在计算前用lms check solver 检查有两个错误(criterion distorsion detected 2105 resp. 0.17% bad elements).但是我用abaqus检测是好的。不知道是不是网格原因造成的。我尝试重新画过网格,发现只要是四面体网格基本都会出现这一项网格不好。而且,我算的另一个模型中也出现了网格检测错误,但依然能算出结构来。求主任指导,困扰了我好多天。。
发表于 2015-4-29 00:18 | 显示全部楼层
zlfnmg 发表于 2015-4-26 15:20
主任那个模型一共244406个节点,1387896个体,在计算前用lms check solver 检查有两个错误(criterion di ...
 楼主| 发表于 2015-4-30 07:58 | 显示全部楼层
谢谢主任,恩,就是这个问题,我调大了内存后就好了,
GMT+8, 2025-1-10 21:25 , Processed in 0.131302 second(s), 28 queries , Gzip On.
