查看: 2062|回复: 1
[编程技巧] 求助各位大虾冲击响应谱的matlab程序
发表于 2015-3-5 17:08 | 显示全部楼层 |阅读模式
冲击信号是一个时域信号,是做试验用示波器得到的数据,怎么样使用MATLAB计算出其冲击响应谱,画出冲击响应谱的波形。小弟谢过大虾们了!邮箱:764112884@qq.com
发表于 2015-3-5 21:11 | 显示全部楼层
  1. disp(' ')
  2. disp(' srs.m   ver 2.0   July 3, 2006')
  3. disp(' by Tom Irvine   Email: tomirvine@aol.com')
  4. disp(' ')
  5. disp(' This program calculates the shock response spectrum')
  6. disp(' of an acceleration time history, which is pre-loaded into Matlab.')
  7. disp(' The time history must have two columns: time(sec) & acceleration')
  8. disp(' ')
  9. %
  10. clear t;
  11. clear y;
  12. clear yy;
  13. clear n;
  14. clear fn;
  15. clear a1;
  16. clear a2
  17. clear b1;
  18. clear b2;
  19. clear jnum;
  20. clear THM;
  21. clear resp;
  22. clear x_pos;
  23. clear x_neg;
  24. %
  25. iunit=input(' Enter acceleration unit:   1= G   2= m/sec^2  ');
  26. %
  27. disp(' ')
  28. disp(' Select file input method ');
  29. disp('   1=external ASCII file ');
  30. disp('   2=file preloaded into Matlab ');
  31. file_choice = input('');
  32. %
  33. if(file_choice==1)
  34.     [filename, pathname] = uigetfile('*.*');
  35.     filename = fullfile(pathname, filename);
  36. %
  37.     fid = fopen(filename,'r');
  38.     THM = fscanf(fid,'%g %g',[2 inf]);
  39.     THM=THM';
  40. else
  41.     THM = input(' Enter the matrix name:  ');
  42. end
  43. %
  44. t=double(THM(:,1));
  45. y=double(THM(:,2));
  46. %
  47. tmx=max(t);
  48. tmi=min(t);
  49. n = length(y);
  50. %
  51. out1 = sprintf('\n  %d samples \n',n);
  52. disp(out1)
  53. %
  54. dt=(tmx-tmi)/(n-1);
  55. sr=1./dt;
  56. %
  57. out1 = sprintf(' SR  = %g samples/sec    dt = %g sec \n',sr,dt);
  58. disp(out1)
  59. %
  60. fn(1)=input(' Enter the starting frequency (Hz)  ');
  61. if fn(1)>sr/30.
  62.     fn(1)=sr/30.;
  63. end
  64. %
  65. idamp=input(' Enter damping format:  1= damping ratio   2= Q  ');
  66. %
  67. disp(' ')
  68. if(idamp==1)
  69.     damp=input(' Enter damping ratio (typically 0.05) ');
  70. else
  71.     Q=input(' Enter the amplification factor (typically Q=10) ');
  72.     damp=1./(2.*Q);
  73. end
  74. %
  75. disp(' ')
  76. disp(' Select algorithm: ')
  77. disp(' 1=Kelly-Richman  2=Smallwood ');
  78. ialgorithm=input(' ');
  79. %
  80. tmax=(tmx-tmi) + 1./fn(1);
  81. limit = round( tmax/dt );
  82. n=limit;
  83. yy=zeros(1,limit);
  84. for i=1:length(y)
  85.         yy(i)=y(i);
  86. end
  87. %
  88. disp(' ')
  89. disp(' Calculating response..... ')
  90. %
  91. %  SRS engine
  92. %
  93. for j=1:1000
  94. %
  95.     omega=2.*pi*fn(j);
  96.     omegad=omega*sqrt(1.-(damp^2));
  97.     cosd=cos(omegad*dt);
  98.     sind=sin(omegad*dt);
  99.     domegadt=damp*omega*dt;
  100. %
  101.     if(ialgorithm==1)
  102.         a1(j)=2.*exp(-domegadt)*cosd;
  103.         a2(j)=-exp(-2.*domegadt);
  104.         b1(j)=2.*domegadt;
  105.         b2(j)=omega*dt*exp(-domegadt);
  106.         b2(j)=b2(j)*( (omega/omegad)*(1.-2.*(damp^2))*sind -2.*damp*cosd );
  107.         b3(j)=0;
  108. %
  109.     else
  110.             E=exp(-damp*omega*dt);
  111.                 K=omegad*dt;
  112.                 C=E*cos(K);
  113.                 S=E*sin(K);
  114.                 Sp=S/K;
  115. %
  116.             a1(j)=2*C;
  117.                 a2(j)=-E^2;
  118.                 b1(j)=1.-Sp;
  119.                 b2(j)=2.*(Sp-C);
  120.                 b3(j)=E^2-Sp;
  121.     end
  122.     forward=[ b1(j),  b2(j),  b3(j) ];
  123.     back   =[     1, -a1(j), -a2(j) ];
  124. %
  125.     resp=filter(forward,back,yy);
  126. %
  127.     x_pos(j)= max(resp);
  128.     x_neg(j)= min(resp);
  129. %
  130.     jnum=j;
  131.     if  fn(j) > sr/8.
  132.         break
  133.     end
  134.     fn(j+1)=fn(1)*(2. ^ (j*(1./12.)));
  135. end
  136. %
  137. %  Output options
  138. %
  139. disp(' ')
  140. disp(' Select output option ');
  141. choice=input(' 1=plot only   2=plot & output text file  ' );
  142. disp(' ')
  143. %
  144. if choice == 2
  145. %%
  146.       [writefname, writepname] = uiputfile('*','Save SRS data as');
  147.           writepfname = fullfile(writepname, writefname);
  148.           writedata = [fn' x_pos' (abs(x_neg))' ];
  149.           fid = fopen(writepfname,'w');
  150.           fprintf(fid,'  %g  %g  %g\n',writedata');
  151.           fclose(fid);
  152. %%
  153. %   disp(' Enter output filename ');
  154. %   SRS_filename = input(' ','s');
  155. %
  156. %   fid = fopen(SRS_filename,'w');
  157. %   for j=1:jnum
  158. %        fprintf(fid,'%7.2f %10.3f %10.3f \n',fn(j),x_pos(j),abs(x_neg(j)));
  159. %   end
  160. %   fclose(fid);
  161. end
  162. %
  163. %  Plot SRS
  164. %
  165. disp(' ')
  166. disp(' Plotting output..... ')
  167. %
  168. %  Find limits for plot
  169. %
  170. srs_max = max(x_pos);
  171. if max( abs(x_neg) ) > srs_max
  172.     srs_max = max( abs(x_neg ));
  173. end
  174. srs_min = min(x_pos);
  175. if min( abs(x_neg) ) < srs_min
  176.     srs_min = min( abs(x_neg ));
  177. end
  178. %
  179. figure(1);
  180. plot(fn,x_pos,fn,abs(x_neg),'-.');
  181. %
  182. if iunit==1
  183.     ylabel('Peak Accel (G)');
  184. else
  185.     ylabel('Peak Accel (m/sec^2)');
  186. end
  187. xlabel('Natural Frequency (Hz)');
  188. Q=1./(2.*damp);
  189. out5 = sprintf(' Acceleration Shock Response Spectrum Q=%g ',Q);
  190. title(out5);
  191. grid;
  192. set(gca,'MinorGridLineStyle','none','GridLineStyle',':','XScale','log','YScale','log');
  193. legend ('positive','negative',2);
  194. %
  195. ymax= 10^(round(log10(srs_max)+0.8));
  196. ymin= 10^(round(log10(srs_min)-0.6));
  197. %
  198. fmax=max(fn);
  199. fmin=fmax/10.;
  200. %
  201. fmax= 10^(round(log10(fmax)+0.5));
  202. %
  203. if  fn(1) >= 0.1
  204.     fmin=0.1;
  205. end
  206. if  fn(1) >= 1
  207.     fmin=1;
  208. end
  209. if  fn(1) >= 10
  210.     fmin=10;
  211. end
  212. if  fn(1) >= 100
  213.     fmin=100;
  214. end
  215. axis([fmin,fmax,ymin,ymax]);
  216. %
  217. disp(' ')
  218. disp(' Plot pseudo velocity? ');
  219. vchoice=input(' 1=yes   2=no  ' );
  220. if(vchoice==1)
  221. figure(2);
  222. %
  223. %   Convert to pseudo velocity
  224. %
  225. for j=1:jnum
  226.     if iunit==1
  227.        x_pos(j)=386.*x_pos(j)/(2.*pi*fn(j));
  228.        x_neg(j)=386.*x_neg(j)/(2.*pi*fn(j));
  229.     else
  230.        x_pos(j)=x_pos(j)/(2.*pi*fn(j));
  231.        x_neg(j)=x_neg(j)/(2.*pi*fn(j));
  232.     end
  233. end
  234. %
  235. srs_max = max(x_pos);
  236. if max( abs(x_neg) ) > srs_max
  237.     srs_max = max( abs(x_neg ));
  238. end
  239. srs_min = min(x_pos);
  240. if min( abs(x_neg) ) < srs_min
  241.     srs_min = min( abs(x_neg ));
  242. end
  243. %
  244. plot(fn,x_pos,fn,abs(x_neg),'-.');
  245. %
  246. if iunit==1
  247.     ylabel('Velocity (in/sec)');
  248. else
  249.     ylabel('Velocity (m/sec)');
  250. end
  251. xlabel('Natural Frequency (Hz)');
  252. Q=1./(2.*damp);
  253. out5 = sprintf(' Pseudo Velocity Shock Response Spectrum Q=%g ',Q);
  254. title(out5);
  255. grid;
  256. set(gca,'MinorGridLineStyle','none','GridLineStyle',':','XScale','log','YScale','log');
  257. legend ('positive','negative',2);
  258. %
  259. ymax= 10^(round(log10(srs_max)+0.8));
  260. ymin= 10^(round(log10(srs_min)-0.6));
  261. %
  262. axis([fmin,fmax,ymin,ymax]);
  263. end
GMT+8, 2024-12-29 05:23 , Processed in 0.052430 second(s), 20 queries , Gzip On.
