查看: 1556|回复: 2
[HHT] 在 Mac 电脑上的Matlab安装emd工具包的时候遇到的问题。求解!!
发表于 2015-1-2 20:45 | 显示全部楼层 |阅读模式
>> index_emd
  index_emd.M list of functions in the EMD package
  type help function_name for more information on a specific function
  Empirical Mode Decomposition
    emd          - computes EMD and bivariate/complex EMD with various options
    emd_local    - computes local EMD variation
    emd_online   - computes on-line EMD variation. Note that it does not truly
                   apply on-line: the function is only a demonstration.
    emdc         - fast implementation for EMD with Cauchy-like stopping criterion
                   (requires compilation, see make_emdc function)
    emdc_fix     - fast implementation for EMD with predefined number of iterations
    cemdc        - fast implementation for bivariate/complex EMD (first algorithm)
                   with Cauchy-like stopping criterion (requires compilation,
    cemdc_fix    - fast implementation for bivariate/complex EMD (first algorithm)
                   with predefined number of iterations (requires compilation,
    cemdc2       - fast implementation for bivariate/complex EMD (second algorithm)
    cemdc2_fix   - fast implementation for bivariate/complex EMD (second algorithm)
  Utilities
    install_emd   - setup Matlab's path and compile the C codes.
    uninstall_emd - revert the modifications made by install_emd and remove the
                    files (optional).
    make_emdc     - compile all C codes
    emd_visu      - visualization of EMD
    cemd_visu     - visualization of bivariate/complex EMD (automatically called
                    by emd_visu when the input is complex)
    cenvelope     - compute envelope curves for bivariate/complex EMD
    cemd_disp     - visualization of envelope curves and tube envelope
    plot3c        - plot a complex vector in 3 dimensions
    plotc         - plot the projection of a complex vector on a variable direction
    dirstretch    - directional stretching of a complex vector
    hhspectrum    - compute Hilbert-Huang spectrum (need the Time-Frequency Toolbox
                    http://tftb.nongnu.org)
    toimage       - transform a spectrum made of 1D functions (e.g., output of
                    "hhspectrum") in an 2D image
    disp_hhs      - display the image output of "toimage" as a Hilbert-Huang spectrum
    addtag        - add a tag to a graphic object (uses the Tag property as a list
                    of keywords or "tags")
    rmtag         - remove a tag from a graphic object (uses the Tag property as
                    a list of keywords or "tags")
    hastag        - test whether a graphic object has a specific tag (uses the Tag
                    property as a list of keywords or "tags")
    findtag       - find objects having a specific tag (uses the Tag property as
  Examples from G. Rilling, P. Flandrin and P. Gon32alves,
    "On Empirical Mode Decomposition and its algorithms"
    IEEE-EURASIP Workshop on Nonlinear Signal and Image Processing
    NSIP-03, Grado (I), June 2003
    emd_fmsin         - Fig. 1: a 3-component example (need the Time-Frequency
                        Toolbox http://tftb.nongnu.org)
    emd_triang        - Fig. 2: another 3-component example
    emd_sampling      - Fig. 3: effect of sampling on 1 tone
    emd_separation    - Fig. 4: separation of 2 tones
    ex_online         - Sect 3.4: the way emd_online.m works
    triangular_signal - subroutine called by emd_triang (formerly triang.m)
  Examples from G. Rilling, P. Flandrin, P. Gon32alves and J. M. Lilly,
    "Bivariate Empirical Mode Decomposition",
    Signal Processing Letters (submitted)
    bivariate_EMD_principle        - Fig. 1: principle of the bivariate/complex EMD
    bivariate_EMD_mean_definitions - Fig. 2: definition of the mean for each algorithm.
                                     Also allows to test other signals and parameter sets.
    bivariate_EMD_illustration     - Fig. 3: illustration of the bivariate EMD
                                     on an oceanographic float position record
 楼主| 发表于 2015-1-2 20:47 | 显示全部楼层
install_emd
/Applications/MATLAB_R2012a.app/bin/mex: line 305: gcc-4.2: command not found
/Applications/MATLAB_R2012a.app/bin/mex: line 1326: gcc-4.2: command not found
    mex: compile of ' "src/emdc.c"' failed.
    mex: compile of ' "src/emdc_fix.c"' failed.
    mex: compile of ' "src/cemdc.c"' failed.
    mex: compile of ' "src/cemdc_fix.c"' failed.
    mex: compile of ' "src/cemdc2.c"' failed.
    mex: compile of ' "src/cemdc2_fix.c"' failed.
Warning: The compilation of the following files failed:
> In make_emdc at 48
  In install_emd at 26
emdc.c
emdc_fix.c
cemdc.c
cemdc_fix.c
cemdc2.c
cemdc2_fix.c
Some errors occurred during compilation. See details above.
Installation complete. Run index_emd for a list of functions.
IMPORTANT: After running INSTALL_EMD you must run the "savepath" command to save the installation
but be careful that if you previously removed parts of the path (using e.g. the "rmpath" command)
these will be permanently removed after you run "savepath"
不好意思,第一个不对,问题是第二个。
GMT+8, 2025-1-1 15:57 , Processed in 0.055366 second(s), 17 queries , Gzip On.
