查看: 2021|回复: 3
[Virtual.Lab] 关于ansys模型导入vl问题
发表于 2014-12-11 16:51 | 显示全部楼层 |阅读模式
请论坛的大神帮我看一下,问什么导入vl后什么都不显示,我用的plane42单元,之前看过一些帖子,我也折腾了半天也没有解决。
一个很简单的模型,我做练习用的。
 楼主| 发表于 2014-12-11 16:54 | 显示全部楼层
这是CDB文件,在ansys中用命令CDWRITE,DB,ban3,cdb,,,输出的
ban3.rar
1.65 KB, 下载次数: 3
 楼主| 发表于 2014-12-11 16:56 | 显示全部楼层
/COM,ANSYS RELEASE 13.0    UP20101012       16:01:15    12/11/2014
/PREP7
/NOPR
/TITLE,
*IF,_CDRDOFF,EQ,1,THEN     !if solid model was read in
_CDRDOFF=             !reset flag, numoffs already performed
*ELSE              !offset database for the following FE model
NUMOFF,NODE,      42
NUMOFF,ELEM,      31
NUMOFF,TYPE,       1
*ENDIF
*SET,_BUTTON ,  0.000000000000
*SET,_RETURN ,  0.000000000000
*SET,_STATUS ,  0.000000000000
*SET,_UIQR   ,  1.000000000000
DOF,DELETE
ET,       1, 42
NBLOCK,6,SOLID,        42,        42
(3i8,6e20.13)
       1       0       0 0.0000000000000E+00
       2       0       0 1.0000000000000E+01-1.0000000000000E+00
       3       0       0 1.2500000000000E+00-1.2500000000000E-01
       4       0       0 2.5000000000000E+00-2.5000000000000E-01
       5       0       0 3.7500000000000E+00-3.7500000000000E-01
       6       0       0 5.0000000000000E+00-5.0000000000000E-01
       7       0       0 6.2500000000000E+00-6.2500000000000E-01
       8       0       0 7.5000000000000E+00-7.5000000000000E-01
       9       0       0 8.7500000000000E+00-8.7500000000000E-01
      10       0       0 8.0000000000000E+00 6.0000000000000E+00
      11       0       0 9.0000000000000E+00 2.5000000000000E+00
      12       0       0 1.0000000000000E+00 3.0000000000000E+00
      13       0       0 5.6666666666667E+00 5.0000000000000E+00
      14       0       0 3.3333333333333E+00 4.0000000000000E+00
      15       0       0 8.5714285714286E-01 2.5714285714286E+00
      16       0       0 7.1428571428571E-01 2.1428571428571E+00
      17       0       0 5.7142857142857E-01 1.7142857142857E+00
      18       0       0 4.2857142857143E-01 1.2857142857143E+00
      19       0       0 2.8571428571429E-01 8.5714285714286E-01
      20       0       0 1.4285714285714E-01 4.2857142857143E-01
      21       0       0 3.4112328934936E+00 6.5975417678985E-01
      22       0       0 3.5670515455913E+00 2.4562942028297E-01
      23       0       0 1.5486305178124E+00 8.2933860484535E-01
      24       0       0 2.6697384513337E+00 7.5963809047577E-01
      25       0       0 1.3780070005877E+00 3.5607452795114E-01
      26       0       0 2.5347075569197E+00 2.8169418074513E-01
      27       0       0 6.4991989100018E+00 3.0430484035578E+00
      28       0       0 5.4576280043214E+00 1.9358351060748E+00
      29       0       0 4.6148984893498E+00 1.3127429537620E+00
      30       0       0 3.9045711009349E+00 9.0335124732963E-01
      31       0       0 4.5233644471238E+00 3.0886156404204E-01
      32       0       0 5.5001506697373E+00 4.8948302137597E-01
      33       0       0 6.5546447772057E+00 8.1698238355528E-01
      34       0       0 7.7389638473742E+00 1.4419379782217E+00
      35       0       0 2.9923156068902E+00 1.2149338044829E+00
      36       0       0 3.4805973014578E+00 1.7389563124380E+00
      37       0       0 4.0896050749093E+00 2.4323484360565E+00
      38       0       0 4.8441862083717E+00 3.4706684961468E+00
      39       0       0 1.7885437545283E+00 1.3073605783061E+00
      40       0       0 2.0979658309334E+00 1.8224590263916E+00
      41       0       0 2.4689021233039E+00 2.4173198295074E+00
      42       0       0 2.8937434660638E+00 3.1385511986386E+00
N,R5.3,LOC,       -1,
EBLOCK,19,SOLID,        31,        31
(19i8)
       1       1       1       1       0       0       0       0       4       0       1       1       3      25      20
       1       1       1       1       0       0       0       0       4       0       2       3       4      26      25
       1       1       1       1       0       0       0       0       4       0       3       4       5      22      26
       1       1       1       1       0       0       0       0       4       0       4      20      25      23      19
       1       1       1       1       0       0       0       0       4       0       5      25      26      24      23
       1       1       1       1       0       0       0       0       4       0       6      26      22      21      24
       1       1       1       1       0       0       0       0       4       0       7      22       5       6      31
       1       1       1       1       0       0       0       0       4       0       8      21      22      31      30
       1       1       1       1       0       0       0       0       4       0       9      24      21      30      35
       1       1       1       1       0       0       0       0       4       0      10      23      24      35      39
       1       1       1       1       0       0       0       0       4       0      11      19      23      39      18
       1       1       1       1       0       0       0       0       4       0      12      31       6       7      32
       1       1       1       1       0       0       0       0       4       0      13      30      31      32      29
       1       1       1       1       0       0       0       0       4       0      14      35      30      29      36
       1       1       1       1       0       0       0       0       4       0      15      39      35      36      40
       1       1       1       1       0       0       0       0       4       0      16      18      39      40      17
       1       1       1       1       0       0       0       0       4       0      17      32       7       8      33
       1       1       1       1       0       0       0       0       4       0      18      29      32      33      28
       1       1       1       1       0       0       0       0       4       0      19      36      29      28      37
       1       1       1       1       0       0       0       0       4       0      20      40      36      37      41
       1       1       1       1       0       0       0       0       4       0      21      17      40      41      16
       1       1       1       1       0       0       0       0       4       0      22      33       8       9      34
       1       1       1       1       0       0       0       0       4       0      23      28      33      34      27
       1       1       1       1       0       0       0       0       4       0      24      37      28      27      38
       1       1       1       1       0       0       0       0       4       0      25      41      37      38      42
       1       1       1       1       0       0       0       0       4       0      26      16      41      42      15
       1       1       1       1       0       0       0       0       4       0      27      34       9       2      11
       1       1       1       1       0       0       0       0       4       0      28      27      34      11      10
       1       1       1       1       0       0       0       0       4       0      29      38      27      10      13
       1       1       1       1       0       0       0       0       4       0      30      42      38      13      14
       1       1       1       1       0       0       0       0       4       0      31      15      42      14      12
      -1
EXTOPT,ATTR,      0,      0,      0
EXTOPT,ESIZE,  0,  0.0000
EXTOPT,ACLEAR,      0
BFUNIF,TEMP,_TINY
KUSE,     0
TIME,  0.00000000
TREF,  0.00000000
ALPHAD,  0.00000000
BETAD,  0.00000000
DMPRAT,  0.00000000
CRPLIM, 0.100000000    ,   0
CRPLIM,  0.00000000    ,   1
NCNV,     1,  0.00000000    ,     0,  0.00000000    ,  0.00000000
NEQIT,     0
ERESX,DEFA
ACEL,  0.00000000    ,  0.00000000    ,  0.00000000
OMEGA,  0.00000000    ,  0.00000000    ,  0.00000000
DOMEGA,  0.00000000    ,  0.00000000    ,  0.00000000
CGLOC,  0.00000000    ,  0.00000000    ,  0.00000000
CGOMEGA,  0.00000000    ,  0.00000000    ,  0.00000000
DCGOMG,  0.00000000    ,  0.00000000    ,  0.00000000
IRLF,  0
/GO
FINISH
ban3.rar
1.65 KB, 下载次数: 0
 楼主| 发表于 2014-12-11 16:57 | 显示全部楼层
/PREP7
/NOPR
各位大神不用附件下载,直接在网页上看吧
GMT+8, 2025-1-11 00:35 , Processed in 0.068403 second(s), 21 queries , Gzip On.
