查看: 945|回复: 1
[求助]关于MEX编译器配置的问题
发表于 2006-5-15 18:31 | 显示全部楼层 |阅读模式
<BR>在配置MEX编译的过程中,最后的提示该怎么处理???????<BR>&gt;&gt; mex -setup<BR>Please choose your compiler for building external interface (MEX) files: <BR><BR>Would you like mex to locate installed compilers [y]/n? y<BR><BR>Select a compiler: <BR>[1] Lcc C version 2.4 in F:\MATLAB\sys\lcc <BR>[2] Microsoft Visual C/C++ version 6.0 in F: <BR><BR>[0] None <BR><BR>Compiler: 2<BR><BR>Please verify your choices: <BR><BR>Compiler: Microsoft Visual C/C++ 6.0 <BR>Location: F: <BR><BR>Are these correct?([y]/n): y<BR><BR>Try to update options file: C:\Documents and Settings\yw\Application Data\MathWorks\MATLAB\R14\mexopts.bat <BR>From template:              F:\MATLAB\BIN\WIN32\mexopts\msvc60opts.bat <BR><BR>Done . . . <BR><BR>
发表于 2006-5-16 09:04 | 显示全部楼层
回复:(yanwei678)[求助]关于MEX编译器配置的问题
参考帖子<a href="http://202.118.250.107/vibbbs/dispbbs.asp?boardID=35&amp;ID=8386" target="_blank" >http://202.118.250.107/vibbbs/dispbbs.asp?boardID=35&amp;ID=8386</A>
GMT+8, 2025-1-18 16:48 , Processed in 0.064520 second(s), 17 queries , Gzip On.
