查看: 2796|回复: 3
[前后处理] 在网格划分中,系统提示的警告如何处理
发表于 2006-5-15 11:01 | 显示全部楼层 |阅读模式
在网格划分中,系统提示warning: 1. Shape testing revealed that 4500 of the 4500 new or modified elements
violate shape warning limits. To review test results, please see the
output file or issue the CHECK command.
2.1200 angles less than 2.5 degrees found in triangle facets of volume
3, with smallest angle = 0.97 degrees. Poor element quality or mesh
failure may result. A smaller element size specification may give
better results.
3. Shape testing revealed that 1705 of the 2250 new or modified elements
请指点下,原因是什么啊?谢谢了!
发表于 2006-5-15 11:37 | 显示全部楼层
网格划分的太差了,雅克比值检查不行,重新划分网格!
 楼主| 发表于 2006-5-15 16:01 | 显示全部楼层
回复:(zzhies)有问题了,帮忙啊
模拟焊缝的残余应力,中间部分是焊缝,采用映射网格划分,两边是母材,采用自由网格划分。错在什么地方了啊?新手上路,给指教下吧!
发表于 2008-8-29 13:37 | 显示全部楼层
纵横向的比例不对。在你的问题中,需要适当增加纵向密度。
GMT+8, 2025-1-29 10:59 , Processed in 0.087250 second(s), 21 queries , Gzip On.
