查看: 4217|回复: 1
[Virtual.Lab] 求助,计算时出现错误
发表于 2014-10-11 20:39 | 显示全部楼层 |阅读模式
计算acoustic response solution set.1模块时出现如下错误,判断是License 哪边有问题,但没能查出,求助论坛哪位高手能指点下?
virtual.Lab 13版本,64位win7系统,论坛里面的试用license.
“(12) RLM: Cannot connect
server 5053@ZS-PC reported for feature LMS_VL_ACM_41(lms_vltoken:39): Communications error with license server. (RLM error -17) ERROR : NO LICENSE GRANTED FOR MODULE LMS_VL_ACM_41.
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
SYSNOISE Rev 5.6  Windows_x86_64  MAR2003 DATE: 11-OCT-2014 20:33:13
CPU Stats --- Delta:  0:00:05 (      4.97)  Total:  0:00:05 (      4.97)
ERROR: Sysnoise terminated with an error!
**** ERROR has occurred during computation ***”
 楼主| 发表于 2014-10-11 20:44 | 显示全部楼层
附图附图附图
报错提示窗口
报错提示窗口
GMT+8, 2025-1-11 00:12 , Processed in 0.063347 second(s), 21 queries , Gzip On.
