查看: 2014|回复: 6
[编程技巧] ode45在规定区间内提前停止运算!!!
发表于 2014-9-3 15:29 | 显示全部楼层 |阅读模式
function roll_numerical_prediction
y0=[0.1;0.1;0.1;0.1;0];
V0=0.3;
k1=1;k2=1;k3=0.6;
u1=0.09;u2=0.2;u3=0.09;
P1=0.3;P2=0.5;P3=0.5;P4=1;
a1=0.15;a2=0.09;a3=0.07;
options=odeset;options.RelTol=1e-5;options.AbsTol=1e-6;
w=1.2;
T=2*pi/w;
h=T/100;
t0=0;tf=h;
for j=1:2072
   j
    t0=t0+(j-1)*h;
    tf=tf+(j-1)*h;
    if (y0(4)-V0)<0||((-k3*y0(1)-2*u3*y0(2)-k2*y0(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*y0(4)-3*V0*a3*P4*y0(4)^2-a3*P4*y0(4)^3+P3-a2*V0*P4+a3*P4*V0^3+a1*P4)<0&&(-k3*y0(1)-2*u3*y0(2)-k2*y0(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*y0(4)-3*V0*a3*P4*y0(4)^2-a3*P4*y0(4)^3+P3-a2*V0*P4+a3*P4*V0^3-a1*P4)<0&&(y0(4)-V0)==0)
        [t,dx]=ode45(@sb1,[t0:h/2:tf],y0,options);
       T(j)=t(end);
       X1(j)=dx(end,1);
       X2(j)=dx(end,2);
       X3(j)=dx(end,3);
       X4(j)=dx(end,4);
       X5(j)=dx(end,5);
       y0=[X1(j);X2(j);X3(j);X4(j);X5(j)];
           if (X4(j)-V0)==0
           if (X4(j)-V0)>0&&(X4(j-1)-V0)<0
              a=(V0-X4(j-1))/(X4(j)-V0);
              X1(j)=(X1(j-1)+a*X1(j))/(1+a);
              X2(j)=(X2(j-1)+a*X2(j))/(1+a);
              X3(j)=(X3(j-1)+a*X3(j))/(1+a);
              X4(j)=(X4(j-1)+a*X4(j))/(1+a);
           continue;
    if (y0(4)-V0)>0||((-k3*y0(1)-2*u3*y0(2)-k2*y0(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*y0(4)-3*V0*a3*P4*y0(4)^2-a3*P4*y0(4)^3+P3-a2*V0*P4+a3*P4*V0^3+a1*P4)>0&&(-k3*y0(1)-2*u3*y0(2)-k2*y0(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*y0(4)-3*V0*a3*P4*y0(4)^2-a3*P4*y0(4)^3+P3-a2*V0*P4+a3*P4*V0^3-a1*P4)>0&&(y0(4)-V0)==0)
       [t,dx]=ode45(@sb2,[t0:h/2:tf],y0,options);
       T(j)=t(end);
       X1(j)=dx(end,1);
       X2(j)=dx(end,2);
       X3(j)=dx(end,3);
       X4(j)=dx(end,4);
       X5(j)=dx(end,5);
       if (X4(j)-V0)==0
       if (X4(j)-V0)<0&&(X4(j-1)-V0)>0
      continue;
    if (y0(4)-V0)==0&&((-k3*y0(1)-2*u3*y0(2)-k2*y0(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*y0(4)-3*V0*a3*P4*y0(4)^2-a3*P4*y0(4)^3+P3-a2*V0*P4+a3*P4*V0^3+a1*P4)>=0&&(-k3*y0(1)-2*u3*y0(2)-k2*y0(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*y0(4)-3*V0*a3*P4*y0(4)^2-a3*P4*y0(4)^3+P3-a2*V0*P4+a3*P4*V0^3-a1*P4)<=0)
       [t,dx]=ode45(@sb,[t0:h/2:tf],y0,options);
       T(j)=t(end);
       X1(j)=dx(end,1);
       X2(j)=dx(end,2);
       X3(j)=dx(end,3);
       X4(j)=dx(end,4);
       X5(j)=dx(end,5);
       continue;
figure(2)
plot(X3(1:end),X4(1:end),'k-')
X1(end-5:end)
X2(end-5:end)
X3(end-5:end)
X4(end-5:end)
X5(end-5:end)
function dx=sb1(t,x)
k1=1;k2=1;k3=0.6;
V0=0.3;w=1.2;
dx=[x(2);-(k1+k3)*x(1)-2*(u1+u3)*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*x(4)-3*V0*a3*P4*x(4)^2-a3*P4*x(4)^3+P2*cos(x(5))+P1+P3-a2*V0*P4+a3*P4*V0^3+a1*P4;x(4);-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*x(4)-3*V0*a3*P4*x(4)^2-a3*P4*x(4)^3+P3-a2*V0*P4+a3*P4*V0^3+a1*P4;w];
function dx=sb2(t,x)
k1=1;k2=1;k3=0.6;
V0=0.3;w=1.2;
dx=[x(2);-(k1+k3)*x(1)-2*(u1+u3)*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*x(4)-3*V0*a3*P4*x(4)^2-a3*P4*x(4)^3+P2*cos(x(5))+P1+P3-a2*V0*P4+a3*P4*V0^3-a1*P4;x(4);-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*x(4)-3*V0*a3*P4*x(4)^2-a3*P4*x(4)^3+P3-a2*V0*P4+a3*P4*V0^3-a1*P4;w];
function dx=sb(t,x)
k1=1;k2=1;k3=0.6;
V0=0.3;w=1.2;
dx=[1/2*((-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P3-a2*V0*P4+a3*P4*V0^3+a1*P4)*x(2)-(-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P3-a2*V0*P4+a3*P4*V0^3-a1*P4)*x(2))/a1/P4;
    1/2*((-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P3-a2*V0*P4+a3*P4*V0^3+a1*P4)*((-k1-k3)*x(1)-(2*u1+2*u3)*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P2*cos(x(5))+P1+P3-a2*V0*P4+a3*P4*V0^3-a1*P4)-(-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P3-a2*V0*P4+a3*P4*V0^3-a1*P4)*((-k1-k3)*x(1)-(2*u1+2*u3)*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P2*cos(x(5))+P1+P3-a2*V0*P4+a3*P4*V0^3+a1*P4))/a1/P4;
    1/2*((-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P3-a2*V0*P4+a3*P4*V0^3+a1*P4)*V0-(-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P3-a2*V0*P4+a3*P4*V0^3-a1*P4)*V0)/a1/P4;
    0;
    1/2*((-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P3-a2*V0*P4+a3*P4*V0^3+a1*P4)*w-(-k3*x(1)-2*u3*x(2)-k2*x(3)-(2*u2+3*V0^2*a3*P4-a2*P4)*V0-3*V0*a3*P4*V0^2-a3*P4*V0^3+P3-a2*V0*P4+a3*P4*V0^3-a1*P4)*w)/a1/P4];
for语句运行一次代表在步长h上积分一次,j取100为运行一个周期,每次积分用的方程用if 语句进行选择,共三个方程。奇怪的是j的取值从2069开始往后,X1到X4的值将一直保持不变,似乎方程不再参数运算,X1X2X3X4最后6个取值为:
X1=-0.0454   -0.0547   -0.0555   -0.0555   -0.0555  -0.0555
X2=-0.1923   -0.1632   -0.1601   -0.1601   -0.1601  -0.1601
X3=0.1781    0.1932    0.1949    0.1949    0.1949  0.1949
X4=0.2770    0.2979     0.3         0.3          0.3        0.3
plot图上也是画到标注为红色的点后就停止了,希望各位帮帮忙
发表于 2014-10-14 10:09 | 显示全部楼层
我看红色数据之后的数据变化很小,你们可以再循环中设置一个收敛残差,残差可以使用没两步解之间的差。
 楼主| 发表于 2014-10-14 19:14 | 显示全部楼层
不是数据变化小,而是根本就不变了,因此在figure图上的效果就是画到某个点之后就停止了,因为后面的点都一样,是同一个点
发表于 2014-10-14 21:38 | 显示全部楼层
那还是可以用判定语句强制跳出计算的!
 楼主| 发表于 2014-10-17 08:39 | 显示全部楼层
谢谢!嗯,基于这种情况确实可以跳出运算,但是我的目的是想让它继续运算下去,而不是跳出。
实际情况应该是状态变量的值能够持续更新,一直到规定的时间结束,这里取j=1:2072是我为了看出从哪里开始停止运算而取的,其实我最初取的是j=1:5000,我就是不知道为啥j取从2069往后,状态变量的值保持不变
发表于 2014-10-17 09:54 | 显示全部楼层
那这个应该不是你编程的问题吧,可能是不是算法的的原因!
 楼主| 发表于 2014-10-27 15:59 | 显示全部楼层
不知道呢,不过还是谢谢了!
GMT+8, 2025-1-16 23:15 , Processed in 0.066164 second(s), 17 queries , Gzip On.
