查看: 7415|回复: 4
[Nastran专区] F06文件中存在着 Fatal 3046 该如何解决?
发表于 2014-6-28 10:42 | 显示全部楼层 |阅读模式
3046  是什么类型的错误? 错误是不是模型建立的不对 ?? 多谢各位大神帮忙了
0        N A S T R A N    F I L E    A N D    S Y S T E M    P A R A M E T E R    E C H O
0
0
0                                        C A S E    C O N T R O L    E C H O
                 COMMAND
                 COUNT
                  1      $ DIRECT TEXT INPUT FOR GLOBAL CASE CONTROL DATA
                  2      $ NODES FOR GROUP : NODES
                  3      SET 1 = 48
                  4      TITLE = MSC.NASTRAN JOB CREATED ON 28-JUN-14 AT 08:55:02
                  5      ECHO = NONE
                  6      RESVEC = YES
                  7      SDAMPING = 1
                  8      SUBCASE 1
                  9         METHOD = 1
                 10         FREQUENCY = 1
                 11         ACCELERATION(SORT1,REAL)=1
                 12      $ DIRECT TEXT INPUT FOR THIS SUBCASE
                 13      BEGIN BULK
1    MSC.NASTRAN JOB CREATED ON 28-JUN-14 AT 08:55:02                          JUNE  28, 2014  MSC.NASTRAN  7/ 6/12   PAGE     4
0
                                        M O D E L   S U M M A R Y          BULK = 0
                                   ENTRY NAME        NUMBER OF ENTRIES
                                         CBAR                      916
                                        CONM2                       81
                                        EIGRL                        1
                                        FREQ1                        1
                                         GRID                      861
                                         MAT1                        3
                                        PARAM                        2
                                         PBAR                      534
                                         RBE2                       14
                                       RJOINT                        8
                                      TABDMP1                        1
^^^ >>> IFP OPERATIONS COMPLETE <<<
1    MSC.NASTRAN JOB CREATED ON 28-JUN-14 AT 08:55:02                          JUNE  28, 2014  MSC.NASTRAN  7/ 6/12   PAGE     5
0
*** USER INFORMATION MESSAGE 7310 (VECPRN)
     ORIGIN OF SUPERELEMENT BASIC COORDINATE SYSTEM WILL BE USED AS REFERENCE LOCATION.
     RESULTANTS ABOUT ORIGIN OF SUPERELEMENT BASIC COORDINATE SYSTEM IN SUPERELEMENT BASIC SYSTEM COORDINATES.
0                                                  OLOAD    RESULTANT
  SUBCASE/    LOAD
  DAREA ID    TYPE       T1            T2            T3            R1            R2            R3
0        1     FX    0.000000E+00     ----          ----          ----       0.000000E+00  0.000000E+00
               FY       ----       0.000000E+00     ----       0.000000E+00     ----       0.000000E+00
               FZ       ----          ----       0.000000E+00  0.000000E+00  0.000000E+00     ----
               MX       ----          ----          ----       0.000000E+00     ----          ----
               MY       ----          ----          ----          ----       0.000000E+00     ----
               MZ       ----          ----          ----          ----          ----       0.000000E+00
             TOTALS  0.000000E+00  0.000000E+00  0.000000E+00  0.000000E+00  0.000000E+00  0.000000E+00
1    MSC.NASTRAN JOB CREATED ON 28-JUN-14 AT 08:55:02                          JUNE  28, 2014  MSC.NASTRAN  7/ 6/12   PAGE     6
0        SUBCASE 1
0                                         G R I D   P O I N T   S I N G U L A R I T Y   T A B L E
0                             POINT    TYPE   FAILED      STIFFNESS       OLD USET           NEW USET
                               ID            DIRECTION      RATIO     EXCLUSIVE  UNION   EXCLUSIVE  UNION
                             6657        G      1         0.00E+00          B        F         SB       S    *
                             6657        G      2         0.00E+00          B        F         SB       S    *
                             6657        G      3         0.00E+00          B        F         SB       S    *
                             6657        G      4         0.00E+00          B        F         SB       S    *
                             6657        G      5         0.00E+00          B        F         SB       S    *
                             6657        G      6         0.00E+00          B        F         SB       S    *
*** USER INFORMATION MESSAGE 5010 (LNCILD)
     STURM SEQUENCE DATA FOR EIGENVALUE EXTRACTION.
     TRIAL EIGENVALUE = 2.467401D+08, CYCLES = 2.500000D+03 THE STURM COUNT = 603
     TRIAL EIGENVALUE = -1.049872D+03, CYCLES = 5.156896D+00 THE STURM COUNT = 0
     TRIAL EIGENVALUE = 6.329957D+06, CYCLES = 4.004244D+02 THE STURM COUNT = 169
     TRIAL EIGENVALUE = 2.256359D+07, CYCLES = 7.560042D+02 THE STURM COUNT = 250
     TRIAL EIGENVALUE = 6.769077D+07, CYCLES = 1.309438D+03 THE STURM COUNT = 362
     TRIAL EIGENVALUE = 4.371865D+07, CYCLES = 1.052334D+03 THE STURM COUNT = 311
     TRIAL EIGENVALUE = 2.030723D+08, CYCLES = 2.268013D+03 THE STURM COUNT = 555
     TRIAL EIGENVALUE = 1.204174D+08, CYCLES = 1.746484D+03 THE STURM COUNT = 443
     TRIAL EIGENVALUE = 9.004578D+07, CYCLES = 1.510260D+03 THE STURM COUNT = 400
     TRIAL EIGENVALUE = 1.634908D+08, CYCLES = 2.035011D+03 THE STURM COUNT = 503
TABLE OF SHIFTS:  (LNNRIGL)
SHIFT #        SHIFT VALUE         FREQUENCY, CYCLES     # EIGENVALUES BELOW    # NEW EIGENVALUES FOUND
     1.        2.4674010E+08          2.4999998E+03               603                        0
     2.       -1.0498722E+03         -5.1568952E+00                 0                       89
     3.        6.3299570E+06          4.0042438E+02               169                      118
     4.        2.2563588E+07          7.5600421E+02               250                       65
     5.        6.7690768E+07          1.3094377E+03               362                       37
     6.        4.3718652E+07          1.0523337E+03               311                       72
     7.        2.0307230E+08          2.2680127E+03               555                       46
     8.        1.2041737E+08          1.7464843E+03               443                       60
     9.        9.0045784E+07          1.5102604E+03               400                       35
    10.        1.6349077E+08          2.0350109E+03               503                       54
    11.        2.4674010E+08          2.4999998E+03               603                       27
1    MSC.NASTRAN JOB CREATED ON 28-JUN-14 AT 08:55:02                          JUNE  28, 2014  MSC.NASTRAN  7/ 6/12   PAGE     7
0        SUBCASE 1
*** USER FATAL MESSAGE 3046 (SQFREQ)
     THIS FREQUENCY RESPONSE ANALYSIS HAS NO EXCITATION SPECIFIED FOR IT.
     APPLIED LOADS AND ENFORCED MOTION ARE BOTH NULL.
     THE RESULT WILL THEREFORE BE A ZERO SOLUTION.
0FATAL ERROR
1                                        * * * END OF JOB * * *
发表于 2014-6-28 13:49 | 显示全部楼层
没遇到过  建议上传整个F06文件
 楼主| 发表于 2014-6-28 20:00 | 显示全部楼层
yhappy0519 发表于 2014-6-28 13:49
没遇到过  建议上传整个F06文件
f06文件
发表于 2014-6-28 22:00 | 显示全部楼层
你的应该是频响分析,应该是时间场没有建立,或者你的约束和载荷没有施加在时间场里面也或者你在分析域里面没有选择你建立的时间场,而选择了默认的
发表于 2014-7-10 21:20 | 显示全部楼层
加载不是按照频响要求的卡片来的,即使是恒定载荷也要按照卡片定义的方式施加,建议看看频响那部分的帮助文档,不要随意施加载荷。
GMT+8, 2024-12-28 12:43 , Processed in 0.094321 second(s), 19 queries , Gzip On.
