查看: 1832|回复: 0
[结构分析] 仿真中提示错误:mesh has more than 1 element in at least
发表于 2014-6-23 02:30 | 显示全部楼层 |阅读模式
在做机械仿真的时候,提示错误:An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports.  Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present.  Please see the Troubleshooting section of the Help System for more information.
请问有朋友知道是怎么回事吗,该如何解决。另外我的模型是个轴承动态分析。
GMT+8, 2025-1-30 19:40 , Processed in 0.079553 second(s), 17 queries , Gzip On.
