查看: 4934|回复: 18
[Virtual.Lab] Virtual.lab计算时sysnoise启动不了怎么解决?
发表于 2014-6-18 15:40 | 显示全部楼层 |阅读模式
软件:Virtual.lab  12;
系统:xp64
计算时出现如下提示:
XPR VERSION 12
Requested task is SYSNOISE sequential computation.
Working directory on server is D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp
Checking that the SYSNOISE launch script (D:\Program Files\LMS\LMS Virtual.Lab 12\VirtualLab\Sysnoise\5.6\bin\sysnoise_nogui.bat) exists on server...
OK
SYSNOISE log file on server is D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Administrator-11839-sysnoise.log.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxx  JOB EXECUTION START
                System for Computational Vibro-Acoustics
SYSNOISE Rev 5.6  Windows_x86_64  MAR2003 DATE: 18-JUN-2014 15:23:45
PATCH LEVEL  P  (Build Date: 10-FEB-2014)
READING THE SET-UP FILE: D:\Program Files\LMS\LMS Virtual.Lab 12\VirtualLab\Sysnoise\5.6\bin\\..\res\SYSNOISE.STP
THE SYSNOISE PROFILE FILE NAME HAS NOT BEEN DEFINED.
STANDARD GRAPHIC DEVICE SET TO DEFAULT
PLOTTING GRAPHIC DEVICE SET TO SCREENDUMP
MEMORY IN USE   =         800000
AVAILABLE MEMORY=      307100006
FREE MEMORY     =      306300006
CREATING DEFAULT SYSNOISE MODEL FILE default.sdb
SYSNOISE ANALYSIS OPTION :
      BEM INDIRECT VARIATIONAL UNBAFFLED FREQUENCY FLUID
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP USRDIR 'D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\' RETURN
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP TMPDIR 'D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\' RETURN
SYSNOISE>  SCL> Open Model 1 File Administrator-11839-Acoustic.sdb Original Return
OPENING SYSNOISE MODEL FILE Administrator-11839-Acoustic.sdb
LOADING MODEL Exported VLModel
SYSNOISE>  SCL> Extract Summary Return
      BEM DIRECT COLLOCATION ELEMENT EXTERIOR UNCOUPLED UNBAFFLED FREQUENCY FLUID
SYSNOISE SUMMARY INFORMATION
Title...Exported VLModel
Date....18-JUN-2014 15:23:45
Number of dimensions......................      3
Number of nodes...........................   5852
Number of elements........................   5796
Number of material characteristics........      1
Number of load cases......................      1
Number of nodes with jump of pres B.C.'s..     60
Number of elements with d. dipole B.C.'s..   5796
Number of symmetry/antisymmetry planes....      1
SYSNOISE>  SCL> Environment Section SETUP BELL 'on' Return
SYSNOISE>  SCL> Environment Section SETUP GEO_TOLERANCE '1E-006' Return
SYSNOISE>  SCL> Parameter Model 1
PARAMETER>  SCL>   Physical
PARAMETER>
PARAMETER>  SCL>   Save Potentials Step 1
PARAMETER>  SCL>   Save Results none
PARAMETER>  SCL>   Store Results none
STORE RESULTS>  SCL>   Return
PARAMETER>  SCL>   Near 2
PARAMETER>  SCL>   Far 5
PARAMETER>  SCL>   Quadrature 2  2  1
PARAMETER>  SCL>   Return
Updating Model Parameters
SYSNOISE>  SCL> NAEROBC
(12) RLM: Cannot connect
server 5053@AK47 reported for feature LMS_VL_ACM_41(lms_vltoken:39): Communications error with license server. (RLM error -17) ERROR : NO LICENSE GRANTED FOR MODULE LMS_VL_ACM_41.
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
SYSNOISE Rev 5.6  Windows_x86_64  MAR2003 DATE: 18-JUN-2014 15:23:48
CPU Stats --- Delta:  0:00:03 (      3.12)  Total:  0:00:03 (      3.12)
ERROR: Sysnoise terminated with an error!
补充内容 (2014-6-23 09:26):
问题已解决!
补充内容 (2014-6-23 16:18):
另下了一个重新安装的!
LZ最好分享一下解决的经验,为其他人提供必要的参考~  发表于 2014-6-23 12:40
发表于 2014-6-18 16:47 | 显示全部楼层
确认软件安装有问题么?可以试试其他模型看能否计算。
 楼主| 发表于 2014-6-19 11:31 | 显示全部楼层
完全新手啊,不知道怎么测试。在照着做第一个列子。安装应该没啥问题吧,照着百度上面的安装方式安装的。
发表于 2014-6-19 12:36 | 显示全部楼层
感觉是没安装好吧,按照论坛里的那个安装指南检查一下,或是重启一下软件试试新的计算!
2
 楼主| 发表于 2014-6-19 15:33 | 显示全部楼层
嗯,我试试,谢谢咯!!
发表于 2014-6-20 21:36 | 显示全部楼层
License没配置好。
 楼主| 发表于 2014-6-23 09:25 | 显示全部楼层
嗯,谢谢,已经弄好了!
发表于 2014-6-23 11:09 | 显示全部楼层
观望中 期待有人回复
发表于 2016-7-26 20:27 | 显示全部楼层
楼主我遇到跟你一样的问题,请问怎么解决的啊?
发表于 2016-7-27 14:03 | 显示全部楼层
不行就重装
发表于 2016-7-27 15:07 | 显示全部楼层
解决了吗  同样的问题求教
发表于 2017-5-5 10:07 | 显示全部楼层
server 5053@AK47 reported for feature LMS_VL_ACM_41(lms_vltoken:39): Commu ...
冯博士请问这个license在那个选项中配置,困扰好多天了
发表于 2017-5-5 12:52 | 显示全部楼层
你没按照说明安装,配置License,仔细检查下。
发表于 2017-5-5 13:17 | 显示全部楼层
的确按照教程安装的,并且试了多次,我用的13.6是用RLM注册的,5053@dell-pc这种方式
发表于 2017-5-5 13:19 | 显示全部楼层
这一周一直在看论坛,有很多人提这个问题,但是始终没见到明确的解决办法,有些人解决了也没有分享自己的经验,感觉很伤心
GMT+8, 2025-1-9 14:12 , Processed in 0.103549 second(s), 27 queries , Gzip On.
