查看: 2919|回复: 4
[Virtual.Lab] 求解声振耦合时出错
发表于 2014-4-4 22:55 | 显示全部楼层 |阅读模式
各位大虾,我按照詹福良老师那本教材第2.8节的例子,进行汽车内声场声振耦合计算,当求结构模态计算时,显示失败,提示信息如下,请各位大师不吝赐教,感激不尽!
PR VERSION 11-SL2
Requested task is SYSNOISE sequential computation.
Working directory on server is C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp
Checking that the SYSNOISE launch script (E:\Program Files\LMS\LMS Virtual.Lab 11-SL2\VirtualLab\Sysnoise\5.6\bin\sysnoise_nogui.bat) exists on server...
OK
SYSNOISE log file on server is C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Administrator-79151-sysnoise.log.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxx  JOB EXECUTION START
                System for Computational Vibro-Acoustics
SYSNOISE Rev 5.6      WinNT       MAR2003 DATE: 04-APR-2014 22:48:18
PATCH LEVEL  O  (Build Date: 18-FEB-2013)
READING THE SET-UP FILE: E:\Program Files\LMS\LMS Virtual.Lab 11-SL2\VirtualLab\Sysnoise\5.6\bin\\..\res\SYSNOISE.STP
THE SYSNOISE PROFILE FILE NAME HAS NOT BEEN DEFINED.
STANDARD GRAPHIC DEVICE SET TO DEFAULT
PLOTTING GRAPHIC DEVICE SET TO SCREENDUMP
MEMORY IN USE   =         800000
AVAILABLE MEMORY=      357700012
FREE MEMORY     =      356900012
CREATING DEFAULT SYSNOISE MODEL FILE default.sdb
SYSNOISE ANALYSIS OPTION :
      BEM INDIRECT VARIATIONAL UNBAFFLED FREQUENCY FLUID
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP USRDIR 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\' RETURN
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP TMPDIR 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\' RETURN
SYSNOISE>  SCL> Open Model 1 File Administrator-79151-Structure.sdb Original Return
OPENING SYSNOISE MODEL FILE Administrator-79151-Structure.sdb
LOADING MODEL Exported VLModel
SYSNOISE>  SCL> Environment Section SETUP GEO_TOLERANCE '1E-006' Return
SYSNOISE>  SCL> Return Environment Section SETUP BELL 'on' Return
SYSNOISE>  SCL> Environment Section SETUP STABLEFEM TRUE Return
SYSNOISE>  SCL> Modes
EIGENMODES>  SCL> From 0 To 100 Tolerance 1.000000e-006 Iteration 100
EIGENMODES>  SCL> BLanczos
EIGENMODES>  SCL> Return
No shift has been defined.
A shift value of -0.50000E-01 will be used.
EIGEN MODES COMPUTATION
COMPUTING EIGENVALUES BETWEEN  0.0000     Hz and   100.00     Hz BY BLANCZOS METHOD
Shift value.......................-5.00000E-02 Hz
Maximum number of iterations......     100
Number of iter. vect. (subspace)..       4
Tolerance for eigenvalues......... 1.00000E-06
STURM         control (subspace method)
CPU Stats --- Delta:  0:00:02 (      1.54)  Total:  0:00:02 (      1.54)
  Running Bacon and Dynam ...
CPU Stats --- Delta:  0:00:01 (      0.99)  Total:  0:00:03 (      2.53)
ERROR : GRAPH FILE Administrator-79151-Structure_samcef.u60  DOES NOT EXIST !
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
  !!! Please check the *_samcef.log or *_samcef_dy.res file for errors !!!
  ***ERROR*** CANNOT PERFORM THIS ANALYSIS PROCEDURE
SYSNOISE>  SCL> Close Return
SAVING MODEL Exported VLModel
FILE NAME    C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Administrator-79151-Structure.sdb
SYSNOISE>  SCL> New Model 1 File Administrator-79151-SignalFile.sdb Return
SYSNOISE>  SCL> Save Return
SAVING MODEL Administrator-79151-SignalFile
FILE NAME    C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\_Administrator-79151-SignalFile.sdb
SYSNOISE>  SCL> Exit
SYSNOISE Rev 5.6      WinNT       MAR2003 DATE: 04-APR-2014 22:48:21
CPU Stats --- Delta:  0:00:00 (      0.03)  Total:  0:00:03 (      2.56)
发表于 2014-4-5 00:57 | 显示全部楼层
检查一下材料什么的都设置对了没。
从这个日志上看不出什么来。。。
 楼主| 发表于 2014-4-9 21:45 | 显示全部楼层
lengxuef 发表于 2014-4-5 00:57
检查一下材料什么的都设置对了没。
从这个日志上看不出什么来。。。
我换了部64位的电脑,在上面成功运行了,谢谢
检查一下材料什么的都设置对了没。
从这个日志上看不出什么来。。。
发表于 2017-9-2 11:48 | 显示全部楼层
你有没有算过2.7的例子,那个我也出错!
GMT+8, 2025-1-8 22:02 , Processed in 0.054075 second(s), 20 queries , Gzip On.
