查看: 6193|回复: 18
[其他] 求救cot 阶比重采样 问题
发表于 2014-3-18 11:14 | 显示全部楼层 |阅读模式
%-----数据导入(手动修改)--------------------------------------------
N=2200000;
Fs=40000;
order_max=48;
t=(0:N-1)*1/Fs;
array_time_amp=Data1; %时域振动信号导入
pluse=Data2; %脉冲信号导入
计算脉冲发生时刻---------------------------------------------
Num_pluse1=1;
threshold=200; %设定脉冲阈值
for temp2=1:length(pluse)-1;
if (pluse(temp2)<200&&pluse(temp2+1)>=200)
       Num_pluse1=[Num_pluse1,temp2+1];
if length(Num_pluse1)<2, return,end;
t_pluse=(Num_pluse1-1)/Fs;
数字跟踪滤波-----------------------------------
i=2;
while i<=length(t_pluse);
ft=2/(t_pluse(i)-t_pluse(i-1));
[b,a]=ellip(6,3,80,ft*order_max/(Fs/2));
array_time_amp(Num_pluse1(i-1):(Num_pluse1(i)-1))=filter(b,a,array_time_amp(Num_pluse1(i-1):(Num_pluse1(i)-1)));
i=i+1;
%---------重采样
%------等角度时间计算
delt_thet=pi/24; %设定重采样角度
t_angle=[];
for temp3=3:length(t_pluse);
b=inv([1,t_pluse(temp3-2),t_pluse(temp3-2)^2;1,t_pluse(temp3-1),t_pluse(temp3-1)^2;1,t_pl
use(temp3),t_pluse(temp3)^2])*[0,2*pi,4*pi]';
if temp3==3;
k=0;
while k<1.5*2*pi/delt_thet;
tt=(sqrt(4*b(3)*(k*delt_thet-b(1))+b(2)^2)-b(2))/(2*(b(3)+eps));
t_angle=[t_angle,tt];
k=k+1;
else
k=pi/delt_thet;
while k>=pi/delt_thet && k<1.5*2*pi/delt_thet;
k=k+1;
array_angle=[1:length(t_angle)].*delt_thet;
等角度时刻的幅值拟合(三种拟合方式)-----
%------线性插值拟合
% array_angle_amp=[];
% for temp5=1:length(t_angle);
% for temp4=1:length(t);
% if t_angle(temp5)>=t(temp4)&&t_angle(temp5)<t(temp4+1);
% %linear interpolation
% y=[array_time_amp(temp4),array_time_amp(temp4+1)];
% x=[t(temp4),t(temp4+1)];
% angle_amp=interp1(x,y,t_angle(temp5),'linear');
% array_angle_amp=[array_angle_amp,angle_amp];
% % -------- 三次多项式插值拟合
% % if temp4==1;
% % y=[array_time_amp(temp4),array_time_amp(temp4+1)];
% % x=[t(temp4),t(temp4+1)];
% % angle_amp=interp1(x,y,t_angle(temp5),'linear');
% % array_angle_amp=[array_angle_amp,angle_amp];
% % else
y=[array_time_amp(temp4-1),array_time_amp(temp4),array_time_amp(temp4+1),array_time_amp(temp4+2)];
% %由前两点与后两点得用三次多项式插值求得此角度对应的幅值
% % x=[t(temp4-1),t(temp4),t(temp4+1),t(temp4+2)];
% % angle_amp=interp1(x,y,t_angle(temp5),'cubic');
% % end
% break;
% end
% end
% end
三次样条插值拟合-------------------------------
array_angle_amp=interp1(t,array_time_amp,t_angle,'cubic');
%------------------加窗
w=hanning(length(array_angle_amp))';
array_angle_amp=array_angle_amp.*w;
s%---------------------------------------------------------------
%-------------- FFT ------------------------------------------
angle_dom_ffty=abs(fft(array_angle_amp))*2/length(array_angle_amp);
delt_order=2*pi/(length(angle_dom_ffty)*delt_thet);
angle_dom_fx=(0:length(angle_dom_ffty)-1)*delt_order;
FFTy=abs(fft(array_time_amp))*2/length(array_time_amp);
fx=(0:length(array_time_amp)-1)/t_sample;
%---------------2 维图形显示
figure(1);
subplot(2,1,1),plot(t,array_time_amp),title('timedomianat'),xlabel('time'),ylabel('amplitude');
grid on;
subplot(2,1,2),plot(t,pluse),title('keyphasor'),xlabel('time'),ylabel('amplitude');
grid on;
figure(2);
subplot(2,1,1),plot(fx(1:length(fx)/2),FFTy(1:length(fx)/2)),title('Frequencydomain');
xlabel('f'), ylabel('amplitude');
subplot(2,1,2),plot(array_angle,array_angle_amp), title('angle dominant'),xlabel('angle /rad'),
grid on;
figure(3);
subplot(2,1,1),plot(angle_dom_fx(1:length(angle_dom_fx)/2),angle_dom_ffty(1:length(angle_dom_fx)/2));
file:///C:/Users/Administrator.L1PAC6T64O1PUEG/Documents/Tencent%20Files/895628164/Image/85Y3B%7B5~EK96Z%609LXLYB@%60M.jpg
但是程序运行出现了这样的结果[img]file:///C:/Users/Administrator.L1PAC6T64O1PUEG/Documents/Tencent%20Files/895628164/Image/Z2A~GC76E%60ZD0@MEKBRW4[G.jpg[/img]
我不知道是不是程序有问题
threshold=200; %设定脉冲阈值,这个是怎么设定的
order_max=48;这个是计算出来的吗  还是固定数值
整个程序还有哪些需要设定参数的地方
谢谢各位大神了 我是菜鸟
发表于 2014-3-18 17:24 | 显示全部楼层
这个程序有点问题,你matlab图上显示的数据是哪来的?
 楼主| 发表于 2014-3-21 10:05 | 显示全部楼层
自己实验室测的  能帮我改一下吗 谢谢
发表于 2014-10-10 12:06 | 显示全部楼层
最近也在做这个
发表于 2014-10-10 16:10 | 显示全部楼层
现在成高手了吧!
 楼主| 发表于 2014-10-30 15:12 | 显示全部楼层
lbtv 发表于 2014-10-10 16:10
现在成高手了吧!
还行哈哈哈哈哈哈哈哈哈哈哈
发表于 2014-11-25 09:37 | 显示全部楼层
impluse 这个程序哪块出问题了? 怎么老显示 ??? Error using ==> times Matrix dimensions must agree.  调试了好久也没调出 矩阵维数是哪错了? 谢谢啦
发表于 2014-12-2 16:14 | 显示全部楼层
t_pluse 为什么是0?
 楼主| 发表于 2014-12-2 16:17 | 显示全部楼层
369 发表于 2014-12-2 16:14
t_pluse 为什么是0?
这个程序错好多
发表于 2014-12-3 15:17 | 显示全部楼层
卡索 发表于 2014-12-2 16:17
这个程序错好多
能加下qq交流下么? 我的是2899355008
发表于 2016-8-10 16:42 | 显示全部楼层
楼主问题解决了么,可否交流下
发表于 2016-8-10 16:43 | 显示全部楼层
楼主问题解决了么,可否交流下
发表于 2016-8-11 08:27 | 显示全部楼层
楼主问题解决了吗
发表于 2018-3-30 08:38 | 显示全部楼层
各位,麻烦请教仿真信号怎么产生的
发表于 2018-4-3 19:14 | 显示全部楼层
主任,怎么仿真阶比的脉冲信号啊,谢谢
GMT+8, 2025-1-30 06:01 , Processed in 0.091419 second(s), 23 queries , Gzip On.
