查看: 1463|回复: 2
[综合讨论] 工况传递路分析模型输入输出选取
发表于 2014-3-10 21:18 | 显示全部楼层 |阅读模式
系统的位置有激励点(source)、路径点(transition)、接收点(receiver),但是看到下面就不明白了。
1:Choosing response data measured on different sources as input signal allows to separate a measured output responses, at for example the driver’s ear, in the different source contents.
2:Choosing several responses on one excitation source as input variables allows the identification of how the source’s excitation propagate into its neighboring component(s).
3:Using transition locations as OTPA inputs allow one to determine which locations transmit vibration the most. They do not indicate the origin of the source.
4:Using additional responses within the structure allows to identify how the vibration is propagated into the vehicle through succeeding components.
以上4条均没有说明输出(output)是谁。
 楼主| 发表于 2014-3-10 21:29 | 显示全部楼层
有谁看明白的给解释一下,欢迎讨论
 楼主| 发表于 2014-3-13 09:35 | 显示全部楼层
我先说说我的理解:
1 选择不同激励处的响应为输入(默认为接收处的响应为输出),研究输出中有哪些是由各激励传递来的,即separate a measured output responses in the different source contents。
2 选择同一个激励的多个响应为输入,可以识别激励是如何向邻近的部件传播,这一条我理解不了,因为还找不到合适的输出信号可以能够合理解释
3 选择路径上的响应作为输入(默认选择接收处的响应为输出),可以识别哪一条路径传播的振动最大,路径的响应并不代表激励源。
4 选择结构上额外的响应(作为输入,默认选择接收处的响应为输出),可以识别振动是如何通过这些部件传递到接收处。
关于第二条,不知还有没有更好的理解,抛砖引玉了。。
GMT+8, 2025-1-11 05:53 , Processed in 0.058949 second(s), 17 queries , Gzip On.
