楼主: 原来是小飞
[分形与混沌] 求个互信息法求时延的matlab代码
发表于 2016-1-7 09:45 | 显示全部楼层
-1.23665862675654
-1.44669300698828
-1.53773393520168
-1.56020815199158
-1.60298441922196
-1.64442061847516
-1.67042512279866
-1.65231778576676
-1.64297631434209
-1.66524443296456
-1.67772190108367
-1.67482665774040
-1.67560213441244
-1.65587284836421
-1.63612360474710
-1.68920950068480
-1.67360030052829
-1.70936589112327
-1.71739710991460
-1.69004588161458
-1.71299134068360
-1.71615406373194
-1.70704821641171
-1.71059272477066
-1.70447948137920
-1.60906994173273
-1.60999590677745
-1.61170175222012
-1.64225452229904
-1.63680198930224
-1.64586837704414
-1.60393342643961
-1.59928853576375
-1.61715692976512
-1.61824398839816
-1.64494034342541
-1.62686502633155
-1.62018359112753
-1.60606683151523
-1.59748959841578
-1.60091449320393
-1.60888157525832
-1.62279273861657
-1.55937706338064
-1.58860886055375
-1.59761594135015
-1.58258043346525
-1.56862585360707
-1.56690666494615
-1.59234151005111
-1.58161319525448
-1.59068695216018
-1.55672796217194
-1.55258181182545
-1.54089178023806
-1.55610723747075
-1.59704977820160
-1.59797838138263
-1.60964289219264
-1.57790380345291
-1.59403818278247
-1.59781103289969
-1.59826016511027
-1.57103003591134
-1.58945471052889
-1.56015416942269
-1.58952200263448
-1.58639944623221
-1.61294985807431
-1.59023244782547
-1.61131233887343
-1.60662315226988
-1.60467199526430
-1.58826562079993
-1.59844326635167
-1.61243188985618
-1.63725177015276
-1.60126090852055
-1.59140155728926
-1.58385506952818
-1.58778356272109
-1.61938073051215
-1.56605702861731
-1.55098845821608
-1.57526652630228
-1.57104222713997
-1.60051218325000
-1.61662045618877
-1.60102807304090
-1.60891006940651
-1.62129974707229
-1.54670385554897
-1.54966582803093
-1.52069364731949
-1.50612718536383
-1.47343224203738
-1.48029864974216
-1.49450501208577
-1.49164379970318
-1.46941298265183
这是啥啊  详情 回复 发表于 2016-7-11 08:54
发表于 2016-1-18 09:37 | 显示全部楼层
下载一个试一试
发表于 2016-3-3 11:49 | 显示全部楼层
gghhjj 发表于 2014-3-5 09:03
我这儿有两个互信息法求时延的程序
一个是武汉大学Adu的,另一个是陆振波的
希望对大家有所帮助,遗憾的 ...
本人小白,这个里面的dll文件怎么使用啊?
参考http://forum.vibunion.com/thread-141050-1-1.html  详情 回复 发表于 2016-3-3 15:27
发表于 2016-3-3 15:27 | 显示全部楼层
发表于 2016-3-3 16:34 | 显示全部楼层
谢谢,但是我发现我的电脑没有编译器。
mex -setup
Please choose your compiler for building external interface (MEX) files:
Would you like mex to locate installed compilers [y]/n? y
Select a compiler:
[0] None
Compiler:
调用之用看第5步就行,前面的是编译  详情 回复 发表于 2016-3-3 22:05
发表于 2016-3-3 21:49 | 显示全部楼层
我也求。。。3021335252@qq.com
发表于 2016-3-3 21:51 | 显示全部楼层
原来是小飞 发表于 2014-2-26 09:00
手上有一个,你试试,我有些参数设置不好。
请问这个程序tau_max设置成多少,计算结果就是多少?貌似不对。
tau_max的问题可以看看http://forum.vibunion.com/thread-132034-1-1.html  详情 回复 发表于 2016-3-3 22:06
发表于 2016-3-3 22:05 | 显示全部楼层
雪梨 发表于 2016-3-3 16:34
谢谢,但是我发现我的电脑没有编译器。
mex -setup
Please choose your compiler for building externa ...
调用之用看第5步就行,前面的是编译
发表于 2016-3-3 22:06 | 显示全部楼层
发表于 2016-5-3 09:27 | 显示全部楼层
求问,MATLAB运行程序时候,报错:Index exceeds matrix dimensions.怎么办?我设置了N=3000,tau_max=100,n=1:N,MATLAB说指数超过矩阵维度了,怎么改?
是那句代码出现这个问题呢?  详情 回复 发表于 2016-5-24 10:12
发表于 2016-5-22 21:14 | 显示全部楼层
lzmhncs 发表于 2016-1-7 09:44
我用你上面的程序试一下,算出来的互信息量怎么都是负数
好有耐心啊,  详情 回复 发表于 2016-5-24 10:11
发表于 2016-5-24 10:11 | 显示全部楼层
xyzsunshine 发表于 2016-5-22 21:14
里面有句写错了,应该是这样的
好有耐心啊,
时延是嘛意思
发表于 2016-5-24 10:12 | 显示全部楼层
rebornfight 发表于 2016-5-3 09:27
求问,MATLAB运行程序时候,报错:Index exceeds matrix dimensions.怎么办?我设置了N=3000,tau_max=10 ...
是那句代码出现这个问题呢?
发表于 2016-7-8 16:38 | 显示全部楼层
求一份    互信息法求tau.zip  邮箱 dweiyj@163.com  谢谢大家!!!
GMT+8, 2024-12-28 14:02 , Processed in 0.096252 second(s), 21 queries , Gzip On.
