查看: 2238|回复: 3
[Virtual.Lab] 计算结构的谐响应分析,出现这样的错误是怎么回事
发表于 2013-11-5 14:04 | 显示全部楼层 |阅读模式
FREQUENCY RESPONSE MODULE
FOR    3 FREQUENCIES FROM       10.000 TO       30.000 HZ
ANALYSIS #     1  FREQUENCY =         10.000 HZ  TYPE = NORMAL
ANALYSIS #     2  FREQUENCY =         20.000 HZ  TYPE = NORMAL
ANALYSIS #     3  FREQUENCY =         30.000 HZ  TYPE = NORMAL
SOLVE PARAMETERS
MODEL:   1 - Exported VLModel
    PHYSICAL Coordinates
    Saving DISPLACEMENTS every     1 steps
    Energy Calculation Enabled
    Surface post-processing on positive side
LAUNCHING UNCOUPLED STRUCTURAL FEM (Physical Coords - Freq) ANALYSIS
CPU Stats --- Delta:  0:00:02 (      1.73)  Total:  0:00:02 (      1.73)
  Running Bacon and Dynam ...
CPU Stats --- Delta:  0:00:01 (      0.92)  Total:  0:00:03 (      2.65)
ERROR : GRAPH FILE Administrator-368911-Structure_samcef.u60  DOES NOT EXIST !
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
  !!! Please check the *_samcef.log or *_samcef_dy.res file for errors !!!
  Aborting Structural Direct Response  procedure due to error...
>> ERROR :  Aborting Structural Direct Response  procedure due to error...
A FATAL ERROR OCCURRED.  PROGRAM STOPPED
发表于 2013-11-5 15:10 | 显示全部楼层
一般情况就是网格、材料、边界条件这些原因导致的。这个错误看不出具体是什么原因。
 楼主| 发表于 2013-11-5 21:14 | 显示全部楼层
我的这个模型,我已经算了其结构模态,声腔模态,和声压响应分析,都没问题,可是算结构谐响应分析就出现这个错误,这时什么原因啊
发表于 2013-11-5 22:48 | 显示全部楼层
飞哥 发表于 2013-11-5 21:14
我的这个模型,我已经算了其结构模态,声腔模态,和声压响应分析,都没问题,可是算结构谐响应分析就出现 ...
载荷的问题吧。
GMT+8, 2025-1-27 20:20 , Processed in 0.075819 second(s), 17 queries , Gzip On.
