查看: 3901|回复: 5
[共享资源] 分享matlab冲击响应谱程序
发表于 2013-10-15 16:04 | 显示全部楼层 |阅读模式
Ref : http://www.mathworks.com/matlabc ... ctrum/content/srs.m
  1. disp(' ')
  2. disp(' srs.m ver 2.0 July 3, 2006')
  3. disp(' by Tom Irvine Email: tomirvine@aol.com')
  4. disp(' ')
  5. disp(' This program calculates the shock response spectrum')
  6. disp(' of an acceleration time history, which is pre-loaded into Matlab.')
  7. disp(' The time history must have two columns: time(sec) & acceleration')
  8. disp(' ')
  9. %
  10. clear t;
  11. clear y;
  12. clear yy;
  13. clear n;
  14. clear fn;
  15. clear a1;
  16. clear a2
  17. clear b1;
  18. clear b2;
  19. clear jnum;
  20. clear THM;
  21. clear resp;
  22. clear x_pos;
  23. clear x_neg;
  24. %
  25. iunit=input(' Enter acceleration unit: 1= G 2= m/sec^2 ');
  26. %
  27. disp(' ')
  28. disp(' Select file input method ');
  29. disp(' 1=external ASCII file ');
  30. disp(' 2=file preloaded into Matlab ');
  31. file_choice = input('');
  32. %
  33. if(file_choice==1)
  34. [filename, pathname] = uigetfile('*.*');
  35. filename = fullfile(pathname, filename);
  36. %
  37. fid = fopen(filename,'r');
  38. THM = fscanf(fid,'%g %g',[2 inf]);
  39. THM=THM';
  40. else
  41. THM = input(' Enter the matrix name: ');
  42. end
  43. %
  44. t=double(THM(:,1));
  45. y=double(THM(:,2));
  46. %
  47. tmx=max(t);
  48. tmi=min(t);
  49. n = length(y);
  50. %
  51. out1 = sprintf('\n %d samples \n',n);
  52. disp(out1)
  53. %
  54. dt=(tmx-tmi)/(n-1);
  55. sr=1./dt;
  56. %
  57. out1 = sprintf(' SR = %g samples/sec dt = %g sec \n',sr,dt);
  58. disp(out1)
  59. %
  60. fn(1)=input(' Enter the starting frequency (Hz) ');
  61. if fn(1)>sr/30.
  62. fn(1)=sr/30.;
  63. end
  64. %
  65. idamp=input(' Enter damping format: 1= damping ratio 2= Q ');
  66. %
  67. disp(' ')
  68. if(idamp==1)
  69. damp=input(' Enter damping ratio (typically 0.05) ');
  70. else
  71. Q=input(' Enter the amplification factor (typically Q=10) ');
  72. damp=1./(2.*Q);
  73. end
  74. %
  75. disp(' ')
  76. disp(' Select algorithm: ')
  77. disp(' 1=Kelly-Richman 2=Smallwood ');
  78. ialgorithm=input(' ');
  79. %
  80. tmax=(tmx-tmi) + 1./fn(1);
  81. limit = round( tmax/dt );
  82. n=limit;
  83. yy=zeros(1,limit);
  84. for i=1:length(y)
  85. yy(i)=y(i);
  86. end
  87. %
  88. disp(' ')
  89. disp(' Calculating response..... ')
  90. %
  91. % SRS engine
  92. %
  93. for j=1:1000
  94. %
  95. omega=2.*pi*fn(j);
  96. omegad=omega*sqrt(1.-(damp^2));
  97. cosd=cos(omegad*dt);
  98. sind=sin(omegad*dt);
  99. domegadt=damp*omega*dt;
  100. %
  101. if(ialgorithm==1)
  102. a1(j)=2.*exp(-domegadt)*cosd;
  103. a2(j)=-exp(-2.*domegadt);
  104. b1(j)=2.*domegadt;
  105. b2(j)=omega*dt*exp(-domegadt);
  106. b2(j)=b2(j)*( (omega/omegad)*(1.-2.*(damp^2))*sind -2.*damp*cosd );
  107. b3(j)=0;
  108. %
  109. else
  110. E=exp(-damp*omega*dt);
  111. K=omegad*dt;
  112. C=E*cos(K);
  113. S=E*sin(K);
  114. Sp=S/K;
  115. %
  116. a1(j)=2*C;
  117. a2(j)=-E^2;
  118. b1(j)=1.-Sp;
  119. b2(j)=2.*(Sp-C);
  120. b3(j)=E^2-Sp;
  121. end
  122. forward=[ b1(j), b2(j), b3(j) ];
  123. back =[ 1, -a1(j), -a2(j) ];
  124. %
  125. resp=filter(forward,back,yy);
  126. %
  127. x_pos(j)= max(resp);
  128. x_neg(j)= min(resp);
  129. %
  130. jnum=j;
  131. if fn(j) > sr/8.
  132. break
  133. end
  134. fn(j+1)=fn(1)*(2. ^ (j*(1./12.)));
  135. end
  136. %
  137. % Output options
  138. %
  139. disp(' ')
  140. disp(' Select output option ');
  141. choice=input(' 1=plot only 2=plot & output text file ' );
  142. disp(' ')
  143. %
  144. if choice == 2
  145. %%
  146. [writefname, writepname] = uiputfile('*','Save SRS data as');
  147. writepfname = fullfile(writepname, writefname);
  148. writedata = [fn' x_pos' (abs(x_neg))' ];
  149. fid = fopen(writepfname,'w');
  150. fprintf(fid,' %g %g %g\n',writedata');
  151. fclose(fid);
  152. %%
  153. % disp(' Enter output filename ');
  154. % SRS_filename = input(' ','s');
  155. %
  156. % fid = fopen(SRS_filename,'w');
  157. % for j=1:jnum
  158. % fprintf(fid,'%7.2f %10.3f %10.3f \n',fn(j),x_pos(j),abs(x_neg(j)));
  159. % end
  160. % fclose(fid);
  161. end
  162. %
  163. % Plot SRS
  164. %
  165. disp(' ')
  166. disp(' Plotting output..... ')
  167. %
  168. % Find limits for plot
  169. %
  170. srs_max = max(x_pos);
  171. if max( abs(x_neg) ) > srs_max
  172. srs_max = max( abs(x_neg ));
  173. end
  174. srs_min = min(x_pos);
  175. if min( abs(x_neg) ) < srs_min
  176. srs_min = min( abs(x_neg ));
  177. end
  178. %
  179. figure(1);
  180. plot(fn,x_pos,fn,abs(x_neg),'-.');
  181. %
  182. if iunit==1
  183. ylabel('Peak Accel (G)');
  184. else
  185. ylabel('Peak Accel (m/sec^2)');
  186. end
  187. xlabel('Natural Frequency (Hz)');
  188. Q=1./(2.*damp);
  189. out5 = sprintf(' Acceleration Shock Response Spectrum Q=%g ',Q);
  190. title(out5);
  191. grid;
  192. set(gca,'MinorGridLineStyle','none','GridLineStyle',':','XScale','log','YScale','log');
  193. legend ('positive','negative',2);
  194. %
  195. ymax= 10^(round(log10(srs_max)+0.8));
  196. ymin= 10^(round(log10(srs_min)-0.6));
  197. %
  198. fmax=max(fn);
  199. fmin=fmax/10.;
  200. %
  201. fmax= 10^(round(log10(fmax)+0.5));
  202. %
  203. if fn(1) >= 0.1
  204. fmin=0.1;
  205. end
  206. if fn(1) >= 1
  207. fmin=1;
  208. end
  209. if fn(1) >= 10
  210. fmin=10;
  211. end
  212. if fn(1) >= 100
  213. fmin=100;
  214. end
  215. axis([fmin,fmax,ymin,ymax]);
  216. %
  217. disp(' ')
  218. disp(' Plot pseudo velocity? ');
  219. vchoice=input(' 1=yes 2=no ' );
  220. if(vchoice==1)
  221. figure(2);
  222. %
  223. % Convert to pseudo velocity
  224. %
  225. for j=1:jnum
  226. if iunit==1
  227. x_pos(j)=386.*x_pos(j)/(2.*pi*fn(j));
  228. x_neg(j)=386.*x_neg(j)/(2.*pi*fn(j));
  229. else
  230. x_pos(j)=x_pos(j)/(2.*pi*fn(j));
  231. x_neg(j)=x_neg(j)/(2.*pi*fn(j));
  232. end
  233. end
  234. %
  235. srs_max = max(x_pos);
  236. if max( abs(x_neg) ) > srs_max
  237. srs_max = max( abs(x_neg ));
  238. end
  239. srs_min = min(x_pos);
  240. if min( abs(x_neg) ) < srs_min
  241. srs_min = min( abs(x_neg ));
  242. end
  243. %
  244. plot(fn,x_pos,fn,abs(x_neg),'-.');
  245. %
  246. if iunit==1
  247. ylabel('Velocity (in/sec)');
  248. else
  249. ylabel('Velocity (m/sec)');
  250. end
  251. xlabel('Natural Frequency (Hz)');
  252. Q=1./(2.*damp);
  253. out5 = sprintf(' Pseudo Velocity Shock Response Spectrum Q=%g ',Q);
  254. title(out5);
  255. grid;
  256. set(gca,'MinorGridLineStyle','none','GridLineStyle',':','XScale','log','YScale','log');
  257. legend ('positive','negative',2);
  258. %
  259. ymax= 10^(round(log10(srs_max)+0.8));
  260. ymin= 10^(round(log10(srs_min)-0.6));
  261. %
  262. axis([fmin,fmax,ymin,ymax]);
  263. end
赞成: 5.0
赞成: 5
  发表于 2016-1-26 10:48
发表于 2013-11-5 09:32 | 显示全部楼层
先收藏了!!!
发表于 2016-1-23 14:13 | 显示全部楼层
谢谢楼主!
发表于 2016-2-3 20:51 | 显示全部楼层
楼主,想问下这个代码原理,是用的Laplace小波来做点乘寻找冲击吗?
 楼主| 发表于 2016-2-10 09:40 | 显示全部楼层
水平有限,不清楚Laplace小波,但个人以为没那麼复杂
GMT+8, 2024-12-28 15:37 , Processed in 0.103544 second(s), 20 queries , Gzip On.
