查看: 1626|回复: 1
[综合讨论] 关于流固耦合在ANSYS建模中的实现!
发表于 2013-8-8 18:26 | 显示全部楼层 |阅读模式
例子   Example Fluid-Structural Analysis Using Physics Environments   The example in this section illustrates a steady-state fluid-structure         interaction problem. This problem demonstrates the use of nonlinear         large-deflection structural coupling for a fluid domain as well as the         use of the "null" element type in a physics environment setting. It         also demonstrates mesh morphing.
    问题描述:A channel containing a rubber gasket is subjected to water flowing           with an inlet velocity of 0.35 m/sec. (See Figure           5.8 below) The object of the problem is to determine the           pressure drop and gasket deflection under steady-state conditions.           The problem is completely described by the input listing provided at           the end of this section.
     在操作过程中,感觉网格划分处出了问题,但是找不出问题,附图。
这图是我在进行Solve with FLOTRAN.Command(s):             SOLVE
      GUI:       Main Menu> Solution> Run  FLOTRAN
   这步操作后出现的,前面划分网格是好像也跳出了一个警告。这个例子里面,我搞不懂"null"element type的用法,希望有高人给我一一指教,小弟感激不尽。谢谢!
模型
模型
 楼主| 发表于 2013-8-9 09:54 | 显示全部楼层
怎么没人参与呀!我在划分gasket的网格时碰到第一个问题,出现了一个警告。如图
警告
警告
GMT+8, 2025-1-9 00:45 , Processed in 0.059376 second(s), 24 queries , Gzip On.
