查看: 5907|回复: 0
[前后处理] 为什么我用ansys命令流建立beam3模型,定义了实常数,去得面积为
发表于 2013-7-7 21:44 | 显示全部楼层 |阅读模式
  1. finish
  2. /clear
  3. /prep7
  4. RO = 7850
  5. PEX = 2.06E11
  6. MP,EX,1,PEX   !ex: 弹性模量
  7. MP,DENS,1,RO  !密度
  8. MP,PRXY,1,0.3
  9. ET,1,beam3,,,
  10. ET,32,mass21        !mass ux uy uz
  11. keyopt,32,3,4
  12. R,32,0.0248,0.0248,0.0248
  13. ET,33,mass21
  14. keyopt,33,3,4
  15. R,33,0.0577,0.0577,0.0577
  16. ET,34,mass21
  17. keyopt,34,3,4
  18. R,34,0.0577,0.0577,0.0577,
  19. ET,38,mass21
  20. keyopt,38,3,4
  21. R,38,0.134,0.134,0.134
  22. ET,313,mass21
  23. keyopt,313,3,4
  24. R,313,0.0577,0.0577,0.0577
  25. ET,314,mass21
  26. keyopt,314,3,4
  27. R,314,0.0577,0.0577,0.0577
  28. ET,315,mass21
  29. keyopt,315,3,4
  30. R,315,0.02051,0.02051,0.02051
  31. ET,316,mass21
  32. keyopt,316,3,4
  33. R,316,0.06647,0.06647,0.06647
  34. ET,22,COMBIN14
  35. keyopt,22,2,0
  36. R,22,164e6
  37. ET,23,COMBIN14
  38. keyopt,23,2,0
  39. R,23,164e6
  40. *DIM,DIAM,ARRAY,16  !定义直径数组
  41. DIAM(1) = 15E-3
  42. DIAM(2) = 16E-3
  43. DIAM(3) = 17E-3
  44. DIAM(4) = 17E-3
  45. DIAM(5) = 20.5E-3
  46. DIAM(6) = 29E-3
  47. DIAM(7) = 21.7E-3
  48. DIAM(8) = 21E-3
  49. DIAM(9) = 20E-3
  50. DIAM(10) = 17E-3
  51. DIAM(11) = 17E-3
  52. DIAM(12) = 20.5E-3
  53. DIAM(13) = 17E-3
  54. DIAM(14) = 17E-3
  55. DIAM(15) = 16E-3
  56. DIAM(16) = 12.5E-3
  57. *DIM,AERA,ARRAY,16  !定义横截面面积数组
  58. AERA(1)  =   0.000126449104
  59. AERA(2)  =  0.000150796447
  60. AERA(3)  =  0.000176714587
  61. AERA(4)  = 0.000176714587
  62. AERA(5)  =  0.0002797980
  63. AERA(6)  =  0.000610254372
  64. AERA(7)  =  0.0003195707
  65. AERA (8) =   0.0002960951
  66. AERA(9)  =   0.0002638938
  67. AERA(10)  =   0.00017671459
  68. AERA(11)  =   0.00017671459
  69. AERA(12)  = 0.00027979808
  70. AERA(13) =  0.00017671459
  71. AERA(14) =  0.00017671459
  72. AERA (15) =  0.00015079645
  73. AERA(16)  = 0.00007252981
  74. *DIM,IZZ,ARRAY,16  !定义截面惯性矩数组
  75. IZZ(1) = 0.022839869465450E-7
  76. IZZ(2) =   0.030159289474462E-7
  77. IZZ(3) =  0.038987655704901E-7
  78. IZZ(4) =  0.038987655704901E-7
  79. IZZ(5) =   0.084682642404833E-7
  80. IZZ(6) =   0.084682642404833E-7
  81. IZZ(7) = 0.106834468521627E-7
  82. IZZ(8) =   0.093455018336514E-7
  83. IZZ(9) =  0.076529197041447E-7
  84. IZZ(10) =  0.038987655704901E-7
  85. IZZ(11) =   0.038987655704901E-7
  86. IZZ(12) =   0.084682642404833E-7
  87. IZZ(13) =  0.038987655704901E-7
  88. IZZ(14) =0.038987655704901E-7
  89. IZZ(15) = 0.030159289474462E-7
  90. IZZ(16) =   0.009973605607059E-7
  91. *DO,I,1,16
  92. R,I,AERA(I),IZZ(I),DIAM(I)
  93. *ENDDO
  94. N,1,0
  95. N,2,0.0164
  96. N,3,0.029
  97. N,4,0.039
  98. N,5,0.049
  99. N,6,0.0555
  100. N,7,0.0585
  101. N,8,0.065
  102. N,26,0.09
  103. N,9,0.1122
  104. N,10,0.1172
  105. N,11,0.1222
  106. N,12,0.1272
  107. N,13,0.1377
  108. N,14,0.1477
  109. N,15,0.1577
  110. N,16,0.164
  111. N,17,0.187
  112. TYPE,1
  113. *DO,I,1,16
  114.   E,I,I+1
  115. R,I
  116.   *ENDDO
  117. TYPE,32
  118. real,32
  119. e,2
  120. TYPE,33
  121. real,33
  122. e,3
  123. TYPE,34
  124. real,34
  125. e,4
  126. TYPE,38
  127. real,38
  128. e,26
  129. TYPE,313
  130. real,313
  131. e,13
  132. TYPE,314
  133. real,314
  134. e,14
  135. TYPE,315
  136. real,315
  137. e,15
  138. TYPE,316
  139. real,316
  140. e,16
  141. BRG =-0.010
  142. N,18,0.039,BRG
  143. N,20,0.049,BRG
  144. N,22,0.1477,BRG
  145. N,24,0.1577,BRG
  146. TYPE,22                                                    ! CREATE BEARING
  147. REAL,22
  148. E,18,4
  149. E,20,5
  150. TYPE,23                                                    ! CREATE BEARING
  151. REAL,23
  152. E,22,14
  153. E,24,15
  154. finish
  155. /SOLU
  156. D,18,ALL
  157. D,20,ALL
  158. D,22,ALL
  159. D,24,ALL
  160. /SOLU
  161. ANTYPE,MODAL
  162. MODOPT,lanb,20,,,ON
  163. MXPAND,20
  164. SOLVE
  165. finish
TYPE,1
*DO,I,1,16
  E,I,I+1
R,I
  *ENDDO
是不是红色部分字体有问题啊,不能这么定义吗?老是弹出警告
*** WARNING ***                         CP =     324.547   TIME= 21:12:49
Zero thickness element 1 may result in wrong thermal or bending stress.
  Check real constant table 1.
*** ERROR ***                           CP =     324.547   TIME= 21:12:49
Element 1 has a zero area.  Check real constant table 1.
*** WARNING ***                         CP =     324.703   TIME= 21:12:53
Zero moment of inertia for element 1.  Check real constant table 1.
GMT+8, 2025-1-9 00:32 , Processed in 0.061196 second(s), 17 queries , Gzip On.
