查看: 1836|回复: 1
[GUI界面] 为什么手工圆滑曲线部分不成功
发表于 2013-6-29 22:43 | 显示全部楼层 |阅读模式
function se
global handles
global a;
global b;
global c;
global d;
global ha1;
global ha2;
global hMainFig
%clc
%close all
hMainFig=figure('name','手工圆滑','number','off','menubar','none',...
    'units','normalized','tag','hMainFig');
set(hMainFig,'units','normalized','position',[.2,.2,.6,.6]);
set(hMainFig,'defaultuicontrolfontname','隶书');
set(hMainFig,'defaultuicontrolfontsize',13);
set(hMainFig,'defaultuicontrolunits','normalized');
hAxes=axes('position',[.15,.2,.8,.7]);
b=[1.45829E+02
    1.38841E+02
    1.26428E+02
    1.26685E+02
    1.29584E+02
    1.38322E+02
    1.42670E+02
    6.97490E+01
    1.00166E+02
    1.44230E+02
    1.14989E+02
    1.19405E+02
    1.32245E+02
    1.35919E+02
  1.33458E+02
  1.32025E+02
  1.31339E+02
  1.35567E+02
  1.36867E+02
  1.37972E+02
  1.41170E+02
  1.48319E+02
  1.51382E+02
  1.56039E+02
  1.64074E+02
  1.70963E+02
  1.74719E+02
  1.77379E+02
  1.84034E+02
  1.87624E+02
  1.92784E+02
  1.78992E+02
  1.87221E+02
  1.84854E+02
  1.86131E+02
  1.81557E+02
  1.81499E+02
  1.77094E+02
  1.76973E+02
  1.67492E+02
  1.57153E+02
  1.58719E+02
  1.47376E+02
  1.26563E+02
  1.19241E+02
  1.15421E+02
  1.02704E+02
  1.00490E+02
  9.68207E+01
  8.50081E+01
  7.32428E+01
  6.71406E+01
  5.68262E+01
  6.29521E+01
  3.88121E+01
  3.99925E+01
  1.09562E+01
  1.93862E+01
  1.68555E+01
  6.17044E+00];
a=[1.04000E+04
   8.80000E+03
   7.20000E+03
   6.00000E+03
   5.20000E+03
   4.40000E+03
   3.60000E+03
  3.00000E+03
  2.60000E+03
  2.20000E+03
  1.80000E+03
  1.50000E+03
  1.30000E+03
  1.10000E+03
  9.00000E+02
  7.80000E+02
  6.40000E+02
  5.30000E+02
  4.60000E+02
  3.90000E+02
  3.20000E+02
  2.65000E+02
  2.29000E+02
  1.94000E+02
  1.59000E+02
  1.32000E+02
  1.15000E+02
  9.70000E+01
  7.90000E+01
  6.60000E+01
  5.70000E+01
  4.90000E+01
  4.00000E+01
  3.30000E+01
  2.75000E+01
  2.25000E+01
  1.88000E+01
  1.62000E+01
  1.37000E+01
  1.12000E+01
  9.40000E+00
  8.10000E+00
  6.90000E+00
  5.60000E+00
  4.70000E+00
  4.10000E+00
  3.40000E+00
  2.81000E+00
  2.34000E+00
  2.03000E+00
  1.72000E+00
  1.41000E+00
  1.17000E+00
  1.02000E+00
  8.60000E-01
  7.00000E-01
  5.90000E-01
  5.10000E-01
  4.30000E-01
  3.50000E-01];
assignin('base','aa',a);
ha1=loglog(a,b,'g:+');
set(hMainFig,'pointer','cross');
set(hMainFig,'WindowButtonMotionFcn',@ShowPointData);
hText11=uicontrol(hMainFig,'style','text','position',[.05,.05,.1,.1],'string','x:');
hText12=uicontrol(hMainFig,'style','text','position',[.15,.05,.25,.1],'tag','hText12');
hText21=uicontrol(hMainFig,'style','text','position',[.45,.05,.1,.1],'string','y:');
hText22=uicontrol(hMainFig,'style','text','position',[.55,.05,.25,.1],'tag','hText22');
handles=guihandles(hMainFig);%handles的生成
guidata(hMainFig,handles);
set(hMainFig,'windowButtonDownFcn',@WritePointData);
function WritePointData(hObject, eventdata, handles)
%hObject -- the handle to the figure or Callback object
%handles -- structure with handles and user data
global handles;
global a;
global b;
global c;
global d;
global ha1;
global ha2;
global hMainFig
hp=findobj(ha1);
w=gco;
while 1
[xx,yy,s]=ginput(1);
set(handles.hText12,'string',num2str(xx));
set(handles.hText22,'string',num2str(yy));
assignin('base','xxx',xx);
if s==1
  if w==hp(1)
      if 900<=xx<100000
          for j=1:length(a)
    if(abs(xx-a(j))<=100)
        b(j)=yy;
      elseif 500<=xx<900
          for j=1:length(a)
       if(abs(xx-a(j))<=50)
        b(j)=yy;
       elseif 260<=xx<500
           for j=1:length(a)
       if(abs(xx-a(j))<=27)
        b(j)=yy;
       elseif 130<=xx<260
           for j=1:length(a)
       if(abs(xx-a(j))<=13)
        b(j)=yy;
       elseif 60<=xx<130
           for j=1:length(a)
       if(abs(xx-a(j))<=6)
        b(j)=yy;
       elseif 20<=xx<60
           for j=1:length(a)
       if(abs(xx-a(j))<=2.5)
        b(j)=yy;
       elseif 5<=xx<20
           for j=1:length(a)
       if(abs(xx-a(j))<=0.6)
        b(j)=yy;
       elseif 2.5<=xx<5
           for j=1:length(a)
       if(abs(xx-a(j))<=0.28)
        b(j)=yy;
       elseif 1.1<=xx<2.5
           for j=1:length(a)
       if(abs(xx-a(j))<=0.12)
        b(j)=yy;
       elseif 0.3<=xx<1.1
           for j=1:length(a)
       if(abs(xx-a(j))<=0.04)
        b(j)=yy;
else
     error('没选到线 ');
else s~=1
    break;
function ShowPointData(hObject, eventdata, handles)
p=get(gca,'currentpoint');
if(isempty(findobj('tag','htext')))
   ht=text('tag','htext','string',sprintf('(%g, %g)', p(1), p(3)),'position',[p(1),p(3)]);
else
   ht = findobj('tag','htext');
   set(ht,'string',sprintf('(%g, %g)', p(1), p(3)),'position',[p(1)+.1,p(3)+.1]);
以上是手工圆滑曲线的程序,但是在x轴小的点上不能拖动,但在x轴大的点上能成功拖动?
麻烦各位高手解答。
发表于 2013-7-1 00:17 | 显示全部楼层
个人水平/时间有限, 仅感觉好复杂看著有些吃力, 真无法细究
不过凭LZ的描述及相应代码, 猜测问题出在类似这些逻辑判断语句
请注意下900<=xx<100000的意思不是这范围内, 而是等同 (900<=xx)<100000
试试xx=800; if 900<=xx<100000, disp('You got it!?'); end
GMT+8, 2025-1-4 11:48 , Processed in 0.063609 second(s), 17 queries , Gzip On.
