查看: 1558|回复: 2
[Workbench] mesh问题,棘手!
发表于 2013-6-23 16:25 | 显示全部楼层 |阅读模式
我在对装配体进行静力分析时,施加完约束和载荷后进行求解,最后总是出现一错误,如下:An internal solution magnitude limit was exceeded.please check your environment for inappropriate load values or insnfficient supports.Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present.我施加的载荷不算大呀,100牛左右,结构是铝合金钣金大概4个厚,怎么总是出现这个问题呀,还有后面关于mesh的错误,不懂呀,望各位大侠指教!!!
 楼主| 发表于 2013-6-25 19:22 | 显示全部楼层
求解答,求解答!
 楼主| 发表于 2013-6-25 19:23 | 显示全部楼层
GMT+8, 2025-1-23 01:02 , Processed in 0.079667 second(s), 17 queries , Gzip On.
