查看: 9624|回复: 10
[共享资源] [转帖]matlab下gabor滤波算法,可以提取图象纹理特征
发表于 2006-5-9 22:00 | 显示全部楼层 |阅读模式
  %%%%%%%VERSION 1
  %The Gabor filter is basically a Gaussian (with variances sx and sy along x and y-axes respectively)
  %modulated by a complex sinusoid (with centre frequencies U and V along x and y-axes respectively)
  %described by the following equation
  % 1 -1 x ^ y ^
  %%% G(x,y) = ---------- * exp ([----{(----) 2+(----) 2}+2*pi*i*(Ux+Vy)])
  % 2*pi*sx*sy 2 sx sy
  %% Describtion :
  %% I : Input image
  %% Sx & Sy : Variances along x and y-axes respectively
  %% U & V : Centre frequencies along x and y-axes respectively
  %% G : The output filter as described above
  %% gabout : The output filtered image
  %% Author : Ahmad poursaberi e-mail : a.poursaberi@ece.ut.ac.ir
  %% Faulty of Engineering, Electrical&Computer Department,Tehran
  %% University,Iran,June 2004
  function [G,gabout] = gaborfilter(I,Sx,Sy,U,V);
  if isa(I,'double')~=1
  I = double(I);
  for x = -fix(Sx):fix(Sx)
  for y = -fix(Sy):fix(Sy)
  G(fix(Sx)+x+1,fix(Sy)+y+1) = (1/(2*pi*Sx*Sy))*exp(-.5*((x/Sx)^2+(y/Sy)^2)+2*pi*i*(U*x+V*y));
  Imgabout = conv2(I,double(imag(G)),'same');
  Regabout = conv2(I,double(real(G)),'same');
  gabout = uint8(sqrt(Imgabout.*Imgabout + Regabout.*Regabout));
 楼主| 发表于 2006-5-9 22:01 | 显示全部楼层
回复:(suffer)[转帖]matlab下gabor滤波算法,可以提...
  %%%%%%%VERSION 2
  %%ANOTHER DESCRIBTION OF GABOR FILTER
  % -1 x' ^ y' ^
  %%% G(x,y,theta,f) = exp ([----{(----) 2+(----) 2}])*cos(2*pi*f*x');
  % 2 sx' sy'
  %%% x' = x*cos(theta)+y*sin(theta);
  %%% y' = y*cos(theta)-x*sin(theta);
  %% Describtion :
  %% I : Input image
  %% f : The frequency of the sinusoidal function
  %% theta : The orientation of Gabor filter
  function [G,gabout] = gaborfilter(I,Sx,Sy,f,theta);
  I = double(I);
  xPrime = x * cos(theta) + y * sin(theta);
  yPrime = y * cos(theta) - x * sin(theta);
  G(fix(Sx)+x+1,fix(Sy)+y+1) = exp(-.5*((xPrime/Sx)^2+(yPrime/Sy)^2))*cos(2*pi*f*xPrime);
  gabout = sqrt(Imgabout.*Imgabout + Regabout.*Regabout);
  %%%%%%%VERSION 3
  % 1 -1 x ^ y ^
  %%% Gi(x,y) = ---------- * exp ([----{(----) 2+(----) 2}])*Mi(x,y,f);
  %%% i =1,2
  %%% M1(x,y,f) = cos[2*pi*f*sqrt(x^2+y^2)];
  %%% M2(x,y,f) = cos[2*pi*f*(x*cos(theta) + y*sin(theta)];
  %% Describtion :
  %% I : Input image
  %% G1 & G2 : The output filters as described above
  %% gabout1 & gabout2 : The output filtered images
  function [G1,G2,gabout1,gabout2] = gaborfilter(I,Sx,Sy,f,theta);
  I = double(I);
  M1 = cos(2*pi*f*sqrt(x^2+y^2));
  M2 = cos(2*pi*f*(x*cos(theta)+y*sin(theta)));
  G1(fix(Sx)+x+1,fix(Sy)+y+1) = (1/(2*pi*Sx*Sy)) * exp(-.5*((x/Sx)^2+(y/Sy)^2))*M1;
  G2(fix(Sx)+x+1,fix(Sy)+y+1) = (1/(2*pi*Sx*Sy)) * exp(-.5*((x/Sx)^2+(y/Sy)^2))*M2;
  Imgabout1 = conv2(I,double(imag(G1)),'same');
  Regabout1 = conv2(I,double(real(G1)),'same');
  Imgabout2 = conv2(I,double(imag(G2)),'same');
  Regabout2 = conv2(I,double(real(G2)),'same');
  gabout1 = sqrt(Imgabout1.*Imgabout1 + Regabout1.*Regabout1);
  gabout2 = sqrt(Imgabout2.*Imgabout2 + Regabout2.*Regabout2);
发表于 2006-5-10 09:34 | 显示全部楼层
回复:(suffer)回复:(suffer)[转帖]matlab下gabo...
  我怎么不可以运行啊 ,可以举个例子来说明一下吗?
  麻烦你了
发表于 2006-5-10 09:42 | 显示全部楼层
我很苯的,您可不可以以一扶图举例一下啊
发表于 2006-12-7 16:44 | 显示全部楼层
自己试一下,不是笨不笨的问题,关键是怎么理解
 楼主| 发表于 2006-12-9 09:42 | 显示全部楼层
原帖由 ld1127 于 2006-5-10 09:42 发表
我很苯的,您可不可以以一扶图举例一下啊
注释里非常清楚了,自己好好琢磨一下
发表于 2007-1-24 17:19 | 显示全部楼层
回复 #2 suffer 的帖子
第二个版本里面的参数:
这两个参数都选 1
这个参数选择2,4,8,16
这个参数分别是0,45,90,135,180
作为汉字字符图像特征的提取,出来的结果简直惨不忍睹
都没有取到希望方向上的特征
请教一下是为什么呢 ?
发表于 2007-6-5 21:52 | 显示全部楼层
谢谢,刚刚学Gabor,一直看不懂。好好学习去
发表于 2009-1-11 11:01 | 显示全部楼层
感觉好像很有趣, 随意找了下! 原始资料是有例子转贴如下
I = imread('cameraman.tif');
[G,gabout] = gaborfilter1(I,2,4,16,pi/3);
figure,imshow(uint8(gabout));
转贴有其好处, 但原址或许亦有其他优点(许多人意见)
不过个人外行, 许多不会, 仅列联接有兴趣者或许有用!
http://www.mathworks.com/matlabcentral/fileexchange/5237
发表于 2011-5-10 16:13 | 显示全部楼层
怎么都是乱码 啊
GMT+8, 2025-1-10 11:13 , Processed in 0.090237 second(s), 18 queries , Gzip On.
