查看: 2359|回复: 2
[前后处理] ANSYS用命令流提取刚度质量矩阵时候报错
发表于 2013-6-6 10:30 | 显示全部楼层 |阅读模式
用ANSYS提取刚度质量矩阵的时候报错,求高手帮忙看看
*** ERROR ***                           CP =      33.266   TIME= 10:21:02
Both structural and scalar master degrees of freedom(DOFs) are not
permitted in a reduced analysis.  Reduction of the mass and damping
matrices is not valid for mixed DOFs.  Use a full analysis or all
structural master DOFs instead.
*** ERROR ***                           CP =      33.359   TIME= 10:21:15
The model data was checked and there were errors found.
  Please check output or errors file ( C:\Documents and
Settings\123\chuiwei.err ) for messages.
下面附上命令流
/solu
   antype,substr             !substructuring分析类型
   seopt, massstiffness,2,1  !设置文件名称和刚度矩阵类型(刚度,质量) , 2 means extract mass and stiffness
   nsel, all                 !选择所有节点
   m,all, all                !定义所有节点自由度为主自由度
   /output, massstiffness    !输出到masstiffness文件名
   solve                     !求解
   finish
发表于 2013-6-6 21:44 | 显示全部楼层
什么情况?
发表于 2013-6-28 08:54 | 显示全部楼层
请问你的这个问题解决了吗,我现在也是面临需要提取总体刚度矩阵和质量矩阵的问题
GMT+8, 2025-1-23 02:19 , Processed in 0.069930 second(s), 17 queries , Gzip On.
