返回列表 发新帖
楼主: 池小乙
[Virtual.Lab] 运算时出错 请问是怎么回事
发表于 2013-5-16 15:35 | 显示全部楼层
XPR VERSION 11
Requested task is SYSNOISE sequential computation.
Working directory on server is C:\Users\Lab106\AppData\Local\Temp
Checking that the SYSNOISE launch script (C:\Program Files\LMS\Virtual.Lab.R11\VirtualLab\Sysnoise\5.6\bin\sysnoise_nogui.bat) exists on server...
OK
SYSNOISE log file on server is C:\Users\Lab106\AppData\Local\Temp\Lab106-293762-sysnoise.log.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxx JOB EXECUTION START
                System for Computational Vibro-Acoustics
SYSNOISE Rev 5.6  Windows_x86_64  MAR2013 DATE: 16-MAY-2013 15:24:55
PATCH LEVEL  O  (Build Date: 03-JUL-2012)
READING THE SET-UP FILE: C:\Program Files\LMS\Virtual.Lab.R11\VirtualLab\Sysnoise\5.6\bin\\..\res\SYSNOISE.STP
THE SYSNOISE PROFILE FILE NAME HAS NOT BEEN DEFINED.
STANDARD GRAPHIC DEVICE SET TO DEFAULT
PLOTTING GRAPHIC DEVICE SET TO SCREENDUMP
LICENSE CHECKING (LMS_INTL_LICENSE_FILE=@LAB106-PC)
MEMORY IN USE   =         800000
AVAILABLE MEMORY=     1530500000
FREE MEMORY     =     1529700000
CREATING DEFAULT SYSNOISE MODEL FILE default.sdb
SYSNOISE ANALYSIS OPTION :
      BEM INDIRECT VARIATIONAL UNBAFFLED FREQUENCY FLUID
OLVE PARAMETERS
MODEL:   1 - Exported VLModel
    MODAL Coordinates:          5 Vectors
    Saving DISPLACEMENTS every     1 steps
    Energy Calculation Enabled
    Surface post-processing on positive side
SOLVE PARAMETERS
MODEL:   2 - Exported VLModel
    PHYSICAL Coordinates
    Saving POTENTIALS every        1 steps
    No saving of RESULTS
    Quadrature info
       Proximity limits (multiplied by mean edge) :
         Near area <  2        < medium area <  5        < far area
       Selected integration quadratures:
                 Near region  :    2
                 Medium region:    2
                 Far region   :    1
       Quadrature Nr   Line  Triangle  Quadrangle
                   0   0-pt     0-pt       0-pt
                   1   1-pt     1-pt       1-pt
                   2   2-pts    4-pts      4-pts
                   3   3-pts    7-pts      9-pts
                   4   4-pts   13-pts     16-pts
                   5   5-pts   13-pts     25-pts
                  10  10-pts   13-pts    100-pts
                  16  16-pts   13-pts    100-pts
                  24  24-pts   13-pts    100-pts
LAUNCHING COUPLED INDIRECT BEM - FEM (Modal Coords - Freq) ANALYSIS
Building Structural FEM/Acoustic BEM interface
  Using Model      1 as Structural FEM Model
  Using Model      2 as Acoustic BEM Model
  There are  28936 interface node(s) on the Structural FEM side
  There are  28936 interface node(s) on the BEM side
ERROR in the interface definition, FEM Element  30466
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
ERROR in the interface definition, FEM Element  30467
错误
错误
我也出现这种错误,也想让主任给看看。。。。真心不知道怎么做了!!!
发表于 2013-5-16 20:22 | 显示全部楼层
zsfhappy 发表于 2013-5-16 15:35
XPR VERSION 11
Working directory on server is ...
你是用的直接声振耦合?
发表于 2013-5-16 21:15 | 显示全部楼层
superxjw 发表于 2013-5-16 20:22
你是用的直接声振耦合?
对啊,要不要发你源文件看看。。。。但是文件太大了。。。。
发表于 2013-5-16 21:50 | 显示全部楼层
32bit or 64bit?
发表于 2013-5-17 12:47 | 显示全部楼层
superxjw 发表于 2013-5-16 21:50
32bit or 64bit?
64bit的,您给个邮箱啥的,我发您还是怎么的
发表于 2013-5-17 21:29 | 显示全部楼层
我已经工作了。。现在上网的时间很少。仅仅从提示看,是耦合面的定义可能有问题。你做我提供的直接声振耦合教程,有没有问题?
GMT+8, 2025-1-11 14:04 , Processed in 0.074036 second(s), 19 queries , Gzip On.
