查看: 951|回复: 2
小弟菜鸟,问个有关编译器的问题
发表于 2006-5-9 01:08 | 显示全部楼层 |阅读模式
<P>现有几个M文件想把他编译成ExE文件,主要涉及到GUI和FUZZY,用MCC编译显示错误,应该怎么编译呢,是不是需要C++图形库支持?没用过编译器,请大家不吝赐教。</P>
发表于 2006-5-9 09:12 | 显示全部楼层
回复:(lxlylm)小弟菜鸟,问个有关编译器的问题
你用什么命令编译的?
 楼主| 发表于 2006-5-9 10:52 | 显示全部楼层
<P>我用的命令如下:mcc -B sgl fccad<BR>显示错误:lcc preprocessor warning: fccad.c:197 EOF inside comment <BR>Error fccad.c: 196  syntax error; found `end of input' expecting `}' <BR>1 errors, 1 warnings <BR> <BR>  MBUILD.BAT: Error: Compile of 'fccad.c' failed. <BR> <BR><FONT color=#cc5233>??? Error using ==&gt; mbuild<BR>Unable to complete successfully</FONT></P>
<P><FONT color=#cc5233>??? Error: An error occurred while shelling out to mbuild (error code = 1).<BR>Unable to build executable (specify the -v option for more information).</FONT></P>
<P><FONT color=#cc5233>Error in ==&gt; D:\MATLAB6p5\toolbox\compiler\mcc.dll</FONT></P>
GMT+8, 2025-1-18 20:26 , Processed in 0.079003 second(s), 17 queries , Gzip On.
